Question about Garden
Stiga sp410 Chain does not appear to be getting lubricated . Task is full of chain oil.
SOURCE: husqvarna chain saw oiler
My Husky 36 did this. The oil pump drive gear was stripped and had to be replace. It's located under the flywheel/sprocket so you have to pull that. I couldn't find info on how to do that so had a local shop repair it for $70! Parts are cheap, labor is not.
Posted on Nov 11, 2008
slohry
  • 87 Answers
SOURCE: can i ajust chain oil flow rate, to lubricate bar,
No. It is an automatic oiler.
Posted on Apr 10, 2009
SOURCE: stihl 180 chainsaw,lack of oil to chain and bar
hi there i had this problem check bar studs make sure there tight bar must be flush on chainsaw body not on stud flange if bar is on stud flange there is a gap so oil leaks out near sprocket and not in bar oil channel
Posted on Apr 24, 2009
  • 23 Answers
SOURCE: if the chain is too loose on a stiga SP 510 how do you tighten it
When you give it throttle- does it rev up or bog down?
If it revs up:
Then you have a broken clutch, they are replaceable and some handy people have even repaired them in a pinch, replace it or find a handy person.
If it bogs down or dies:
:The chain brake is on (wrist guard handle forward) grasp and **** back to reset.
:The chain is installed improperly-believe it or not many people have installed their chain by inadvertently routing it over the anti-backlash bracket, reinstall properly.
:The chain is fitting to tight in bar due to lack of oiling and/or over heating you will need to replace bar.
Posted on Apr 29, 2009
  • 211 Answers
SOURCE: ryobi homelite 330 chainsaw
hi
clean the lines where oil goes.A spring activates the oil pump,it is attached to the crankshaft.
regards savumihai71
Posted on Dec 16, 2009
Need to know what kind of oil is used in 2.0 cid gas chainsaw?
Chain oil for the chain
STIHL Bar and Chain Oil - Chainsaw Accessories ' STIHL USA
www.stihlusa.com/products/oils--lubricants-and.../oils...lubricants/chainoi... Rating: 4.5 - ‎6 reviews Don't let friction cut down your chainsaw's performance. STIHL bar and chain oil is specially formulated to adhere to your chainsaw's bar and chain, providing ...
2 stroke oil for the engine
XP® Professional Peformance 2 Cycle Engine Oil 50:1 ...
www.husqvarna.com > ... > Accessories > Lubricants & Fuels XP® Professional Peformance 2 Cycle Engine Oil 50:1. Our best ... 610 00 01-31, 6.4 oz. bottle for 2 1/2 gal. mix (50:1 Mix), $ 3.29. 610 00 01-32 ... Chainsaws.
Oils and lubricants STIHL
Feb 08, 2016 | Garden
How to stop flow of oil on to chain?
Interesting.
Chain lubrication
is critical to the life of the bar and chain.
I'd be suspicious that you may not be using heavy viscosity chain lubrication oil.
Light weight oil will flow much faster.
Dec 03, 2015 | Garden
How do I make sure chain oils lubricating chain
You must start your chainsaw and hold the guide bar about 3 to 5cm from the ground and give it full revs. If you touch the surface, you can start sharpening again. While on full revs, a line of oil should show on the surface. If not, clean the guide bar and the hole where the oil should enter to lubricate the guide bar and make sure there are no blockages.
Oct 20, 2014 | Garden
What chain oil in RM1015P
Hello, The chain lubrication oil is called bar and chain oil. It is specially formulated to cling to the bar and chain to ensure maximum lubrication. You can obtain bar and chain oil at any hardware store or power equipment shop.
Jul 14, 2014 | Remington 10" Model Rm-1015p Electric Pole...
Lost operating and maintenance instructions. Need to know how much oil to put into the self lubricating chain reservoir and where it feeds the chain to make sure there isn't a blockage anywhere.
You are free to charge to the top if you think right to use a chainsaw. It is essential that the oil is clean. If you accidentally charge too much (full hopper) it is good the rest of oil put back in the oil bottle or to extend on the chain. It is important that it is not oil-free and should be cleaned around the chain for good lubrication.
Sep 05, 2011 | Garden
Oil not getting to the bar. Reservoir is full with chain bar oil. Unit is not new I purchased second hand.
take off the chain and bar remove the plate and you should see a small hole where the oil comes through to lubricate the chain its probably blocked with dirt, try blowing in it with an airline gun
Jan 28, 2011 | Garden
Hello, Sir, Good Morning, I am operating POULAN chain Saw model no 4016.( i bought it in 2007 from germany) and facing a problum with oil system.which is not lubricating the bar and chain.i start engine...
Are you using the correct viscosity oil? - It is quite important that the oil is not too thick to freely flow. I am assuming that you are pushing down on the oil tank actuator cap to try and get the chain lubricated? (This is a manual process and does not lubricate the chain automatically on this saw)
Failing that, it sounds like there could be a blockage internally within the oil tank that needs to be cleared.
If this is the case, the user manual (http://dl.owneriq.net/5/5050c27f-7f11-43a6-9bb9-0d77109d285c.pdf) suggests contacting a repair centre.
You could always try removing the bar and chain and carefully working a small piece of wire into the lubricant holes to try and free any clogged up oil.
If this helps, please leave feedback - if not, let me know and I'll try and help some more!
Jan 27, 2010 | Poulan 1630 16" Chain Saw
Need service manual for Homelite 16'' electric chain saw model UT 41320. Motor runs but chain stopped in middle of second cut.
chain is too tight on the bar or is lacking lubrication oil. loosen up the bar nuts and back off the chain tensioning screw a touch. make sure the bar oil reservoir is full and the chain is receiving oil when its running.
Oct 20, 2009 | Homelite Garden
It seems like the chain is not getting any oil earlier in the day the saw was fine. I had to replace the chain and started sawing on a tree and the chain just smoking and burning the wood. It does not look...
Are you using any oil in the oil resivour? The oil lubricates the chain on the bar. I would guess that you installed the chain backwards. If the chain moves freely on the bar it is getting lubrication. I have made that mistake before. check rotation and your new chain. Don't know what brand of chain saw you have, automatic oiler, manual oiler, ect. but would guess that the problem is with the chain itself. Hope it as simple as that.
Aug 23, 2009 | Poulan Garden
Chainsaw chain won't move on 16" Homelite bar
Sounds like th clutch brake is engaged. Try Pushing firmly foward on the hand guard in front of the handle. It should click to release the clutch brake.
Let me know if this helps.
Dec 29, 2008 | Homelite Consumer Products 9.0 Amp, 14 In....
Garden Logo
44 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
