Question about Coby MP-C582 MP3 Player
Wont charge or come on
I have 2 mp3 players and they wont charge or come on the battery flashes like its charging then when unplugged it wont come on
SOURCE: coby mp-c7095 mp3 player will not charge was working but not now
Just got Coby MP C7095 MP3 Player 2 GB for Christmas and the power would not turn on. I tried to charge it but still nothing happened.
Posted on Dec 28, 2007
I bought a Coby mp-c7095 and could not get it to turnon. I charged the battery for more then 24 hours and it still would not turnon.
The problem was easily fixed. The red battery wire was pinched during assembly and shorted to the back cover. I put a small piece of tape over the bare wire and carefully reassembled the unit. Now it works great!
Posted on Mar 19, 2008
SOURCE: coby mpc7095 mp3 player
try resetting the device while plugged into your computer... also some of the pins might be bent inside de port of the player, make sure they are correctly set with a flat, small tool, what do you have to lose?
Posted on Apr 14, 2008
SOURCE: I cant get my coby mp3 to charge?
That's because u didn't plugged in your computer. Your computer have to be turned on..
Posted on Dec 27, 2008
SOURCE: i-scream mp3 player (AV-1)
i have no problem with the charge on my i-scream av-1 mp3 player, but when i add songs from the computer onto it from the usb cable, as soon as i disconnect, and i try and listen to the music i just put on, it wont let me play it and it has deleted all of the other songs i had on before i added more.
Posted on Oct 27, 2009
Why will my sweex clipz mp3 player not turn on?
Perhaps you thought you were hanging the battery, but the battery already died. So to won't give any power. Try to switch it on while charging and then unplug it. When it switches on, you know the switch is still working. When it dies as soon as you unplug it, your battery must be replaced. (or buy a new MP3 player)
Jan 27, 2015 | SWEEX Clipz MP303 2 GB Flash MP3 Player -...
My sansa when its connected to my computer comes on works syncs and everything so as i disconnect it from my computer it' s dead and wont turn on
Three possibilities;
1) You have a dead battery because the battery is no good.
2) You have a dead battery because your Sansa is no longer charging the battery.
3) You have a dead battery because you didn't leave your Sansa tethered long enough to charge it up.
When you have the Sansa c250 tethered to the computer, you should see a tiny yellow lightning bolt flashing, and a battery icon that shows the amount of charge on the battery.
If you see the lightning bolt, but the battery does not charge after being tethered to a working computer or charger for 24 hours, you may need a new battery. You can get one on Amazon.com. Here's a link:
http://www.amazon.com/HQRP-Replacement-Battery-Universal-Protector/dp/B001NZ981S
If you see the lightning bolt, and the battery charges after 24 hours, AND your player works when unplugged--Problem solved! You just need to let it charge for a longer time.
If you do not see the lightning bolt when the player is tethered, and the battery indicator shows "empty," It's likely that the internal plug to your Sansa c250 has broken. Your Sansa is no longer able to charge the battery.
If you happen to be an electrical engineer, or otherwise have a shop full of electronics equipment (including signal injector, volt-ohm meter, needle-tip soldering iron, and stereo magnifying goggles with work lamps) you may be able to fix it yourself. Otherwise, forget it-- your Sansa is dead.
If it's still under warranty, try to get it replaced. Failing that, it's time to get a new MP3 player.
Hope that helps! Please post a message to let others know what happened to your Sansa player.
Nov 22, 2011 | SanDisk Sansa c250 (2 GB) MP3 Player...
The mp3 player wont charge. plug into computer and it shows charging but as soon as it is disconnected it shuts off and wont turn on.
Some mp3's don't expressly charge on the computer, that why when you connect it, the computer only sees it as a flash but is not actually charging it all this while and the battery is completely down. So try and get an external charger for it, the battery may be completely dead.Or probably you need to change the battery. Hope that puts a smile on your face.
Feb 04, 2010 | Samsung YP-K5 MP3 Player
My RCA Opal MP3 wont show up on my computer and it wont charge
This is battery problem, since it work with your computer directly, you no the computer power supply charge it directly so all you need do now is to get another battery and make sure you charge the new battery for some time before you power on.
Compliments and best of luck
Dec 25, 2009 | RCA OPAL M4001 MP3 Player
RCA MP3 M208 won't hold charge -- Only about a yr old
either the battery pack itself is bad, or the ribbon connection cable that attaches battery to main circuit board is faulty, broken, or loose. It is common.
Nov 11, 2009 | RCA M4208 MP3 Player
MP3 WONT TURN ON
The most common cause is a flat battery. There is a trick to charging the battery in these small mp3 players. It wont charge if it is turned on, and it won't charges if it's turned off. Here what to do...
1. plug the payer into your USB port. or wall charger
2. switch thje palyer on using the mechanical switch (on the side)
3. turn it off by either holding down the play button, or selecting "System" from the menu
4. The screen will go black and the battery will begin charging.
Oct 06, 2009 | RCA TH1611 MP3 Player
Unable to switch on
Sep 29, 2009 | Creative Labs ZEN Vision:M Digital Media...
My Mambo- Mano MP4-MP3 does no charge
it does not seems to charge / or turn ON either from the computer or when plugged to an electrical outlet to the wall. Red light is still ON after the whole night . What's wrong ?? Can you please HELP - CODY STELLER MINE IS A 4 GIGA BITE MP4 PLEASE HELP ONLY
Sep 01, 2008 | Kaser Corporation Mambo Mano Digital Media...
Mp3 player
Well, charging the battery alot may cause it to malfunction. So you have to charge your battery only when in is near zero (empty), and for no more than 8 hours depending on what device you use. Now your battery is dead, so you got to replace it. Goodluck
Feb 11, 2007 | Neuros (4010100) (128 MB) MP3 Player
Coby MP-C582 MP3 Player Logo
35 people viewed this question
Top Coby Audio Players & Recorders Experts
Gyula Lacz
Are you a Coby Audio Player and Recorder Expert? Answer questions, earn points and help others
