Question about Pioneer FH-X700BT
X700bt Illumination too bright
The dashboard illumination is dim and won't go bright also the Foglights will not turn on and also the stereo is dim. Changed the light switch but still the same
is it adjusted by the light switch left on bright right dim all when lights are on all dash lights will dim thats normal
Apr 19, 2016 | 2008 Volvo XC90
Trying to install the fh-x700bt into my 2005 gmc envoy. I am using the GM1590AB and the GM05B + Red Wire. I was able to connect all of the speaker wires correctly. I'm having trouble beyond that. The red...
The amplifier is in the passenger side rear quarter panel.
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: The radio harness does not provide a switched power source. Run a wire to the fusebox or ignition switch harness for switched power.
Car Radio Ground Wire: Black/White
Car Radio Illumination Wire: N/A
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
Jun 29, 2014 | Pioneer FH-X700BT
How to remove paired devices on pioneer fh x700bt
Push and hold the phone button until you get a display, now using the big round button in the middle turn to your right until you get to the Bluetooth set up it will say program or delete and you delete the the paired device, and that takes it back to the factory reset.
Jun 13, 2014 | Pioneer FH-X700BT
HOW TO INSTALL FH-X700BT IN 2004 FORD EXPLORER STEP BY STEP
Wal- Mart should have the installation bracket for your model, you also have to buy the harness for the hook up, very easy to install.
Mar 15, 2014 | Pioneer FH-X700BT
Just installed FH-X700BT in 2003 chevy impala and have no sound - everything else works...
Have you found a solution?? I am having the same problem but with an -08 chevy equinox ...
Mar 02, 2014 | Pioneer Double-DIN Car Stereo With...
Need wiring diagram for the FH-X700bt
Page 16 of the owners manual tells you the color and function of the wires from the stereo are: http://www.pioneerelectronics.com/StaticFiles/Manuals/Car/FH-X700BT_OwnersManual112712.pdf
Oct 21, 2012 | Pioneer FH-X700BT
Pioneer FH-X700BT Logo
130 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
