Question about Stanley Camping, Backpacking & Hiking
How do I change the battery in a model sl500hl flashlight
How do I change the light
How to put batteries in flashlight
Ah, a 'flashlight'. I changed the category from Cameras for you. You said 40429t0ss 340 in last post :>)
What is the type of battery? Make and model of flashlight?
Reply by way of comment below my post
Dec 05, 2016 | Camping, Backpacking & Hiking
Can I buy a battery holder or frame for my NEBO Select flashlight?? My grandson dropped mine in the lake while changing batteries.
Given the cost and availability of those lights vs the expense for the battery carrier, you should just get a new light.
Feb 20, 2016 | Nebo Redline Select 310 Lumen Flashlight...
How do I access the battery compartment on model 06443
To change the batteries in your flashlight, unscrew and remove the base tailcap, as the end that doesn't have the light. Remove the battery holder, replace batteries and then replace the battery holder in the same way that it was taken out (spring first).
http://ledmuseum.candlepower.us/fourth/gled.htm
Feb 21, 2015 | Garrity Camping, Backpacking & Hiking
( Stanley spot light) need charger for model# SL500HL
checking Stanley's web site, what a joke. NOTHING?
Jan 29, 2015 | SPOT SL5W09 Spot Light
How do you open the Sylvania model no 72032 rechargeable flashlight to replace the battery and light bube?? Thanks
This is from the Sylvania site
  • Dimensions: 2.4" long x 1.7" diameter
  • Light Source: 0.4 watt non-replaceable LED
  • Internal Battery: Sealed Ni-MH 3.6V 110mAH rechargeable battery
This look like it is not replaceable - amazon sells them fairly cheaply
Oct 04, 2014 | Camping, Backpacking & Hiking
Model 7000 slide not working
I have a Defiant 7000 flashlight and took a look. When the light is closed, the top of the battery door (1) is right at the lip (2) that keeps the light from over extending. I couldn't get mine to close with the cover loose, but if you did you could carefully drill a hole (3) in the outer casing to see and push the battery door back into place. You could also remove the two philips screws under the rotating magnets on the base and maybe push hard enough to force the top out?
Feb 22, 2014 | Defiant Camping, Backpacking & Hiking
I have a Fenix TK15 that doesn' light up. I have changed batteries, still no light
Hi marlyn engaling...
Sounds like you need to replace your bulb, it may be burned out.
Also check the switch and also make sure the spring in the back of the flashlight is touching the battery tightly to make good contact.
Bud
Sep 18, 2012 | Fenix TK15
How do you change batteries stanley 3 in 1 tripod led flashlight
The unit is 3 individual flash lights. Pull one of the flashlights by the head (the light part) it will come out easily once you know what you are doing. The other two may be pulled out in the same manner. The bottom will then unscrew where you will be able to replace the AA batteries. Each flashlight will then go back into place very easily. Hint...test each individual flashlight before putting back together to make sure you have your batteries in the proper place and that they are useable batteries.
Dec 08, 2010 | Stanley 3in1 Tripod LED Flashlight 95155
Can't open the battery compartment.
i think you unscrew the light end of the flashlight .... not the **** end
Oct 25, 2009 | MagLite Mag-Lite& Flashlight
Camping, Backpacking & Hiking Logo
600 people viewed this question
Top Stanley Camping, Backpacking & Hiking Experts
Richard Lilja
Richard Lilja
Dave Reilly
Level 1 Expert
oldhess
Are you a Stanley Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
