Question about Insignia Radio Communications
Caliber axiom setup - Insignia Radio Communications
Axiom 49 not detected by reason 5
Open preferences. Go to Control Surface tab.
Click Add. Select M-Audio as manufacturer.
Choose Axiom 49
Make sure the ports are set right.
Controls IN Port = Axiom 49 Hypercontrol In
Keyboard Port = Axiom 49 USB A In
Controls OUT Port = Axiom 49 Hypercontrol Out
if it hasn't detected yet then restart Reason.
Make sure the power on the Axiom is on.
If you still have issues the USB port on the Axiom could be bad.
Oct 01, 2017 | M-Audio Axiom 49 49-Key Semi-Weighted USB...
Lost my manual for isuzu axiom 2002
check on ebay or go to a junkyard and see if the have any axioms you can go look at, check the glove boxes.
Oct 07, 2011 | 2002 Isuzu Axiom
How can I get my Roland Dp-10 damper pedal to work with my novation remote sl and axiompro 61 again? I use a mac and logic studio and it has been working fine up until recently.
Look for a setting "pedal polarity" someplace either in the software or in the units.
Read section 2.4.2 of the Axiom manual. Also Appendix E where sustain is documented. The sustain is controller 64. I would use method 1 of the 2.4.2 writeup. You actuate the control (pedal) which arms the unit to accept setup sequence for that particular input.
You want to turn on MIDI output for the sustain pedal. Now remember that a Roland pedal has revese polarity of MOST others and that may needs to be setup. It is NOT clear from the documentation if the Axiom recognizes the reverse sense of the pedal, but it should. It SHOULD sense the pedal is normally closed and when you actuate it sense the change so you can configure it.
Some of the software MAY try to configure the Axiom and ASSUME the pedal is the more common polarity and undo the programming you have done.
Apr 04, 2011 | Roland Dp-10 Damper Pedal-new
How do you do a hard rest with the m-audio axiom 25 generation 2 ? DirectLink stopped working, I need to find a way to fix it.
Hold down the LOAD and SAVE buttons while powering on the Axiom will do a hard reset. This will erase any presets you've set up and restore the Axiom to the factory defaults.
Hope this helps,
Stewart
Mar 01, 2011 | M-Audio Axiom 25 G2 USB MIDI Controller
My axiom 61 dont want to work anymore but it comes on says something about my usb connection
Where do you see the error about USB, on the Axiom display or on your computer? Can you give me the exact error? Is the Axiom connected directly into the computer or into a USB hub? (My Axiom 49 only works connected directly) Try restarting both the computer AND the Axiom with ONLY the Axiom plugged in.
Feb 21, 2011 | M-Audio Axiom Pro 61 Advanced 61-Key USB...
60 gb hdd does nor allow repartition
If you are reinstalling your system, it is possible that you need to change something in the BIOS settings. If your HDD is SATA, it is very likely that you need to go to BIOS setup, HDD setup, and change it. There are several options of how it may look, so whatever it is, just switch it to an other option (there are only two options every time). Try then
Nov 14, 2009 | Axiom Audio Axiom 80GB for Dell Inspiron...
Leaking transmission fluid
How can I check transmission fluid on a 2002 Axiom - dipstick!
Jul 21, 2008 | 2002 Isuzu Axiom
Radio Communications Logo
Top Insignia Radio Communications Experts
Skyken
Level 1 Expert
woodzowl307
Are you an Insignia Radio Communication Expert? Answer questions, earn points and help others
