Question about Dacor Preference PGR30SS Gas Kitchen Range
Pgr30s dacor oven temperature issue
The oven won't go higher than 135 degrees
SOURCE: Oven Temperture adjustment
On my Epicure, you are supposed to press the bake selector pad then press the + button to set the temperature to 500 degrees or higher.  Then hold the bake button for 5 seconds.  The temp display is replaced by 00.  Release the bake pad and use the - or+ buttons to adjust the temperature in 5 degree increments.  When finished push cancel (or just do nothing).  Good luck.  I tried this and my oven kind of went haywire.  It decreased the temp by much more than the 10 degrees I had set it too.  May be something else wrong with my oven though?
Posted on Dec 20, 2007
SOURCE: dacor rsd305
yes, you need to open the panel (in the center of the front of the oven when you open the door on the top) and press the reset button, there is a site that gives step by step instructions, but i can no longer find it
Posted on Aug 25, 2008
SOURCE: REALLY long to preheat ...
I had the same problem; replace ignitor
Posted on Mar 10, 2009
walesarumi
  • 6993 Answers
SOURCE: Hi - the Dacor ERD
Read the troubleshooting tips on the below link as it might be helpful in solving the problem;
http://www.partselect.com/range-stove-oven+Element-Heat-Incorrect+repair.htm
I hope the above helps. If it doesn't, please let me know so that I may direct you further.
Good luck.
Posted on Jan 04, 2011
SOURCE: My Dacor PGR-30 oven won't heat. It stays on 135
Called Dacor with same problem. They said the high temp switch needed to be reset but wouldn't tell me how to do it.
Looked at another site and found out how. On double oven remove grill that latch sticks out of. There should be 6 screws. On left side is a switch with a red button that faces inward. Press this button until it clicks. Test oven by turning on to see if this fixes problem. It did for me.
Rescrew grill back on being careful that the latch continues to line up with the door.
Posted on Oct 05, 2011
Oven won't heat
quite possibly the element burnt out .
Sep 22, 2017 | Dacor MCS230SS Millennia Electric Double...
Can not raise temperature above 350
500 degrees farenheit is 260 degrees celcius (metric)
any chance the display is set for metric ?
Jun 28, 2012 | Whirlpool RBS305PDS Electric Single Oven
PCS 127 does not heat up. Fan and preheat start.
We were able to unscrew the plate that sits behind the latch. 6 screws I believe. Look towards the middle back-right side you will see a red switch. Click it twice. Before we put plate back we tested oven and it worked!!! Hope this info will help you. Dacor oven has been a real problem and I'm a kitchen designer. Will never recommend Dacor anything to my clients after many oven issues.
Jan 25, 2010 | Dacor Ovens
My Dacor PGR-30 oven won't heat. It stays on 135 degrees. There are no codes set.
Nov 12, 2009 | Dacor Preference PGR30 Gas Kitchen Range
Dacor Double Oven
HI - I just had the same problem - repairman came and reset the breaker in the oven which "tripped" (even tho I havent used the lower oven in months).  Read posts here on other Dacor ovens which explain how to get to the reset switch to avoid having $150 in repair costs - I have not tried that myself tho but good luck!
Nov 08, 2008 | Dacor ECD230 Epicure Electric Double Oven
Jan 16, 2008 | Dacor Preference PGR30SS Gas Kitchen Range
ERD30 will not reach or maintane setpoint
read your owners manuel and follow the instructions for adjusting the oven temp set it 15 degrees higher
Dec 31, 2007 | Dacor Epicure ERD30 Dual Fuel (Electric...
Nov 18, 2007 | Dacor Epicure ERD36 Dual Fuel (Electric...
Dacor Preference PGR30SS Gas Kitchen Range Logo
21 people viewed this question
Top Dacor Kitchen Ranges Experts
Dan Webster
Dan Webster
240cpa
Jaime Hernandez
Are you a Dacor Kitchen Range Expert? Answer questions, earn points and help others
