Question about DeLonghi PACA120E Portable Air Conditioner
Leaking from bottom
I've been using this unit for a while. Just recently, I've noticed that the carpet underneath the unit is damp. I've unplugged the unit, and have drained the water from the hose. But I still feel a dampness on the floor. Could the unit be leaking? There is no indication from the control panel that there is an internal problem.
Please assist. Thank you.
  • 767 Answers
SOURCE: Air conditioner unit is leaking water from the bottom
Hello my name is Heath it will be my pleasure to assist you. First use a level and make sure the unit is level front and back and sisde to side. Next be sure the drain hose is not plugged or stopped by any debris.
Posted on Jun 03, 2010
  • 4736 Answers
SOURCE: I bought a used K900
arianne, either the plastic tubing to the eater collect bucket is clogged or it has become disconnected.
I suspect the tubing is clogged. To resolve this, do the following:
Remove the water collection bucket and look up inside the bucket holder cavity. You will see either a drain hole or small tubing that drains the water into the bucket. Using an appropriately sized, 18" long, plastic Zip Tie, carefully insert the tip of Zip Tie into the hole or tubing. Continue to push it in until you reach a bend in the tubing. You will need to gingerly work the Zip Tie past this bend, until it either bottoms out or you run out of usable Zip Tie. Then slowly pull the Zip Tie back out while rotating (twisting) it. This will breakup any clogs. As you reach the inserted end of the Zip Tie, be prepared, as some water may follow. Reinstall the bucket, plug the unit in and turn the Master ON/OFF Switch to ON. Allow the unit to run, while you monitor it for any leakage.
NOTE: If you don't have a Zip Tie, you may use something similar ( i.e.a long pipe cleaner), but NO wire coat hangers
I hope this helps you.
Posted on Jul 11, 2011
jas247
  • 844 Answers
SOURCE: notice on back: no drip technology - never empty
Welcome to Fixya.
What cap are you referring to? Please point to the picture below.
The portable air conditioner (PAC T110P) should have a hose attached at figure #9 to facilitate the drip as you use it. The "no drip" technology does not mean that it will not produce water as you use it but rather it will be more convenient to use as it has other ways to deal with the dripping water like the "continous dripping hose" that you can attach to it. Figure #8 is also the water tank which you need to drain when full if you are not using the the dripping hose.
Figure H: water tank
Figure I: continous dripping hose.
Thank you for using Fixya. Have a great day.
Jas247
Posted on Jul 19, 2011
cardenderek
  • 783 Answers
SOURCE: DeLonghi Portable AC PACL90 --
just keep it unplugged and let it dry out as much as possible. Yes you can replace the hose contact customer service here.
800-865-6630
you may be able to purchase through this link check it out.
http://www.delonghi-accessories.com/index.php?cPath=61_49_264
Product manual purchase here
http://www.delonghi-accessories.com/product_info.php?cPath=184_185&products_id=572
800-865-6330 DELONGHI CUSTOMER SERVICE
FixYa Premium Support
Please accept solution and rate 1,2,3 or 4 stars Asked. Thank you.
Posted on Aug 01, 2011
  • 4736 Answers
SOURCE: I dont know where the reservoir is in my air
On the Air-To Air Model, the majority of the moisture is supposed to exhausted out the exhaust hose and out the window. However, if it is extremely humid, the water collection tank will capture what is not exhausted. There is no hose, To drain it, there is a removable drain plug on the back of the unit, down near the floor level. You can either drain it in a low sided pan, that is capable of holding at least 1 quart of water. Or you can disconnect the unit and roll it to a floor drain (if you have one) or out doors to drain the water.
I hope this helped you and thanks for choosing FixYa.
Posted on Aug 17, 2011
Chest freezer
check that the drain plug is tight in the bottom
go back to the retailer and ask for a warranty refund as chest freezes do not " sweat"
the machine is not fit for the purpose
talk with a lawyer if you have to
Jul 02, 2017 | Frigidaire FRS26ZSG
Water leaking outside of fridge
Do you notice if the water was coming from the dispenser door area or from underneath the unit? Did this unit recently go into a defrost cycle at all that you might know of?
Aug 22, 2012 | Frigidaire Gallery Series GLHS269ZDB 36"...
Cayenne wet carpets post huge service, which included new front brakes, replacement of AWS control module??? Never had issue until delivered post service. Please help!!!
If this happens when you're running the AC, the case drain is plugged. It is a flat looking rubber drain hose that lets condensate overboard before it wets the carpet. If it happens any other time, I'd look for a leaking heater core.
Apr 09, 2017 | 2006 Porsche Cayenne
My clothes do not seem as fresh as usual and some even smell damp rather than washed (some feel a bit dry too). The soap unit has gone really black from the back and the pipe underneath it is black from...
Mine does this too. I've also noticed that no water is visable through the door window and I'm sure the bottom of the drum should be submerged. I've been adding a bowl of water after the m/c has taken water in, which seems to help, but I don't know what the long term solution is. But definitely get a cloth out and clean the soap unit and housing!
Jul 15, 2011 | Hotpoint WMA46 Front Load Washer
Water leaking into passenger seat
you have a heater core leaking anti freeze and that is why it is running hot because it is low on antifreeze
Mar 24, 2010 | 1999 Kia Sportage
Bad smell in side car. smells somewhat like a mold or dampness problem.
Check the carpet on the passenger side and see if it is damp or wet. Also, have you noticed white smoke coming from your vents? Does your windshield etc. fog up rather than defrost? If so, you probably have a heater core that is leaking and needs replaced.
Hope this helps! Good luck.
Oct 14, 2009 | 2002 Chevrolet TrailBlazer
Sharp CV-P10NC AC unit it has a puddle of water coming down.
earlier models had a pan you had to empty .. your model has a small pump that is supposed to pump the water out the hot air vent (that goes thru the window} .. since its leaking it is likely that the pump inlet is clogged ... you might have to remove a panel to get at that ... it will be near the bottom of the unit (near the drainage nozzle) ... also check the hose that goes out thru the outside vent .. make sure its not cracked, clogged or smashed ... temporarily you can use the drain nozzle to drain off the water to a lower area (it cant drain up without the pump) ...
Aug 17, 2009 | Sharp CV-P09FX Air Conditioner
Unit is leaking underneath and onto my carpet....
Check your manufacturers warranty to establish warranty period and also Sam's customer service to see if they will support you. Hose and
connector need to be replaced to eliminate moisture. This can breed
mold if not properly addressed.
Aug 04, 2009 | GE APH10AA Air Conditioner
There is water draining from underneath the machine?
I have the same unit, I had to replace my drain pump and clean the entire machine out. THis unit has many design flaws however once they are corrected with new parts it is a good machine.
Mar 06, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Water leaking from wash machine
It is probably a seal that is on or near the bottom of the tub. Dirt and grim wears at this seal over time. The leak is slow so it is hard to visually see.
Dec 09, 2006 | Frigidaire MWS939Z Top Load Washer
DeLonghi PACA120E Portable Air Conditioner Logo
78 people viewed this question
Top DeLonghi Heating & Cooling Experts
paulcarew
Donni Steen
Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
