Question about Siemens SpeedStream 2624 Router (936-2624-001 kit)
My speedstream 6520 will not let me log in using the default logins.... it keeps saying i have a username error but 'admin' is already coloured in there!!?? Cheers Mags
  • kalbarritc May 20, 2009
    Thanks for that info, however there is no reset button on the 6520
    Scholar:
  • 58 Answers
Only way is to reset the Router to Factry settings.
Press the reset button on the bottom. But it has two modes one is just a reboot and the other is return to factory settings.a short press reboots it, if you hold it down for a few seconds until the power LED flashes between green and red, then release it, that will factory default it.Then you will be able to login.
Posted on May 19, 2009
How do I log in. reset password
Nearly all routers will have the password printed on the bottom. If it doesn't say password it may be just a series of letters and numbers with the login being admin as the default. Older routers use just admin for the login and password for the default password. Some it's admin and admin for both. To get to the login screen you would need to enter your gateway IP in a web browser, that is the same as your IP address except ends in a 1. Example http://192.168.1.1 will give you the default page on many home routers. Once logged in it is mostly self explanatory. With newer routers being much better. Without details on router brand and model or version of operating system you are using this is as close as it gets.
Dec 25, 2014 | Computers & Internet
How do i find the wep key on the 6520 router
Login using username and password->click "Wireless Security" and Select "WEP" as the security encryption type.
Set the default transmit key to "1."
Type in a passphrase and click "Generate". This generates random passkeys.
You can note down your network's SSID (listed on the security page) and the first WEP key.
Aug 26, 2012 | Siemens Efficient Networks SpeedStream...
I am trying to login as admin, to be able to change the default password and secure the signal, but the default username does not let me log in. I'm using 192.168.0.1, login-admin, password-(blank). H
Looks like you wil have to do a facotry reset. You can do a factory reset by logging into the router using you browser. Go to the settings and perform a factory reset
If you forgot the router password, you ill have to do a factory reset by locating a small hold on the back of the router and insert the tip of of paper clip for about 10 seconds while the power is on. The router will be reset to out of box status and then you can ssets-up form scratch.
Dec 14, 2011 | D-Link DIR-615 Wireless Router
Forgot username & password for netrouter wgr614v7
How do I log into my router?
To log into a NETGEAR router:
  1. In your Web browser, navigate to the router login page. By default, one or all of the following URLs should work:
    • http://www.routerlogin.net or http://www.routerlogin.com
    • http://192.168.1.1 or http://192.168.0.1
    Note: You can sometimes find the login URL on a sticker on the bottom or back of the router.
  2. Enter the username (admin) and the password.
    • The default password is password, or for older routers, 1234.
    • If you have already changed the default password, use the password you assigned the router. Passwords are case sensitive.
    • If you have already changed the password and do not remember it, you have to reset the router to factory defaults in order to use the default password. Resetting a router to factory defaults erases all changes you have made to the router's configuration files.
This information is extracted from www.netgear.com, for learning purpose only.
Hope this will be useful for your question.
Good luck. Remember to rate my answer please.
Jul 13, 2011 | Computers & Internet
I HAVE SPEEDSTREAM 6520 AND WANT TO CHANGE MY WIFI PASSWORD BUT THE PROBLEM IS I LOST MY ADMIN PASSWORD IT IS ASKING WHN I WANT TO CONFIGURE HOW DO I GET MY PASSWORD BAC AND GO FURTHER WITH MY CONFIGURING...
The only way to get in to the router without password is to reset it to factory reset. RESET will bring all the settings back to what it was when you got it out of the box. Any custom settings will be lost and you will need to input them back in to settings (like your wireless network name or SSID, password and any open ports). Reset is done by pushing is little reset button (little round hole) that is usually on the back of the router and most times it says reset or it is different color than color of the router. You can use a pen or little screw driver but make sure not to press too had so you don't damage it. Router needs to be on and then when you push in the reset you need to hold it in for 30 seconds (make sure it is 30 per clock not just your count to make sure it worked). Once time is up just remove the pen or what ever you used and you can now log in to your router with default user name and password. This is probably on the paperwork you got with the router. If you don't have it just Google your model and most times you can find it there. If not you might have to call support and just ask them. Hope this helps.
Apr 09, 2011 | Siemens SpeedStream 2624 (SS2624) Wireless...
When using set up system is asking for a password for linksys G
have you tried entering a blank username i.e. enter nothing? and use admin as the password
if that doesnt work look on the label on the bopttom of the router your isp might have configured it with there own username and password
if you find this info useful please vote
Feb 23, 2011 | Linksys Wireless-G WRT54G Router
I need to retrieve my password on the Speedstream 6520 Router so I can log in wireless with my iphone.
not possible to retrieve a password! that's why they are secure... if you have your ISP ADSL setup details you can reset the router to factory default and reprogram it from scratch, or call their help desk BEFORE you do it and ask them to email you the connection details before you start. then WRITE the password on a label and stick it to the router.
Mar 25, 2010 | Siemens SpeedStream 2624 (SS2624) Wireless...
Need to find out the password to get onto the speedstream we did not get a password when it was set up for us
You don't mention what model Speedstream you have. Assuming the installer left the default admin password on it, you can refer to http://www.routerpasswords.com to find out what that default password is. For most (but not all) models of Speedstream, the user ID is admin, and the password is admin. If the installer did not leave the default password on it, there's no way to find out what it is short of actually asking him.
Nov 17, 2009 | Computers & Internet
Username and password
if this is fresh from the box, the factory default will be (username - admin) and the (password - admin). but if this already configured by the user before, all you have to do is restart it so that it will back into factory default.
simply press the "reset button" for 10 sec...
then try to login as a factory default then configure it again
Mar 22, 2009 | Actiontec GT704WG Wireless Router...
Speedstream 6520 wireless router
log into the firmware by the following steps
1 open browser and type 192.168.2.1
2 goto advanced
3 user name and password should be admin and admin
4 click on home networking modem
5 click on reboot
6 click on reset to factory defaults
7 click reboot
once rebooted repeat step 1 this time it will ask about setting it up make sure to select router only configuration
reboot modem and setup wireless cinfiguration
Feb 23, 2008 | Computers & Internet
Siemens SpeedStream 2624 Router (936-2624-001 kit) Logo
464 people viewed this question
Top Siemens Computers & Internet Experts
Prashant M
Prashant M
john smith
Are you a Siemens Computer and Internet Expert? Answer questions, earn points and help others
