Question about Kenwood Food Processors
Nexian fp 333
Drive shaft
I don't have an instruction manual (wasn't in the box) and I don't know how to use the slicing/shredding blades or the additional smaller bowls.
A manual for the FP-14C series which the Cuisinart site indicates is applicable to your specific model is available online:
http://www.cuisinart.ca/pdf/ibs/en/FP-14DCC_en.pdf
See page 8 for assembly instructions. Beginning on page 20 is an included recipe section.
For future reference available Parts & Accessories are listed here:
http://www.cuisinart.ca/cuisinart_parts_accessories.php?product_id=328&item_id=281&cat_id=7
Aug 13, 2011 | Cuisinart FP14DC 14 Cups Food Processor
Kenwood Compact FP180 instruction
Go to the following link and download
http://www.kenwoodworld.com/uk/Products/Processing-Blending-Mixing/Food-Processors/White-Food-Processor-with-Liquidiser/
Though the instructions are for FP 190 and FP 196 but considering the machine is the same and the fuctins remain the same this will be helpful to you
Oct 17, 2010 | Kenwood Food Processors
Breville Model FP 1A Kitchen Wizz plastic sleeve for spindle
I have the same model -Breville Kitchen Wizz I have the bowls and blade accessories if anyone still wants them- I'm finally giving up on it even though the motor is strong the plastic casing is all cracked with age. Greta
Jun 13, 2010 | Food Processors
The drive shaft extending vertically from the motor base has developed a crack. This runs from the top of the shaft down to almost where the shaft enters the motor base. The effect is to make the...
I just called Cuisinart customer service. Depending on your model, it sould be under warranty. They sent me a new shaft sheath immediately with no expense.
Dec 09, 2009 | Cuisinart Little Pro Plus LPP 3 Cups Food...
My Hamilton Beach Food processor model # 702-1 has a BROKEN plastic gear that attaches to the motor drive shaft (it threads onto the shaft). It meshes with another plastic gear that turns the spindle that...
my suggestion is that watever spare part u replace, get it replaced by the original manufacturer to avoid future problems. take it to the shop you have bought it from, ask them where u can get one. they may help u better with contacting the manufacturer. i know its time consuming! good luck!!
Oct 14, 2009 | Food Processors
Cuisinart DL 11: Cracked plastic drive shaft
If it is in warranty, it can be sent to Cuisinart for repair. If it is out-of-warranty, it will cost more than a new food processor to repair.
Dec 11, 2008 | Cuisinart DFP-11 Deluxe Food Processor
Part removal and replacement
The black plastic clutch has a left-handed brass threaded insert. Temporarily remove the motor to hold the shaft and remove the brass insert by rotating clockwise.
Dec 26, 2007 | Cuisinart BFP-703 SmartPower Duet Food...
Food processor stopped working
hi there is no reset switch follow these instructions and it suppose to work http://www.useandcaremanuals.com/pdf/FP1300-1400Series791.pdf when you used it did you smell a burned stench? is the unit smells still from it? then probebly the coiles are burend - sorry cant help.... http://www.blackanddeckerappliances.com/customercare/home.jsp good luck
Mar 21, 2006 | Black & Decker FP1300 Quick N Easy Food...
Food Processors Logo
24 people viewed this question
Top Kenwood Food Processors Experts
tfelton3
 Mikey
Mikey
Are you a Kenwood Food Processor Expert? Answer questions, earn points and help others
