Cd changer doesn't work panasonic sa-pm19
How do you setup the correct starting positions of the disc platters
tech48
  • 624 Answers
SOURCE: Panasonic SA-PM19 Disc Changer
If this is under warranty just take it in and get it repaired. If so, I feel sorry for the technician who must fix it.
If it is not under warranty, just RUN, run as fast as you can away from this machine. Panasonic made several models with this same mechanism in it and they all have major problems. They are the hardest CD mechs to repair. A mechanical nightmare. Most places will just replace the entire mech, but that would make the repair cost about $150. It may be better to just get a new one.
Your problem is a very common one for these. I am very sorry you got stuck with Panasonic's worst CD player ever. I work at an authorized Panasonic repair center, I am being totally honest with you about this. I really do feel bad for you. How could you know that this design was the worst they ever made? You couldn't!
This is the CR16 mech (that's what panasonic named it) yo ucan call any authorized Panasonic service center and ask somebody who fixes them if they have ever heard of that mech and I would be shocked if they had anything good to say about them.
let me know if you need any more help.
Dave
Posted on Jul 01, 2008
SOURCE: panasonic stereo (model sa-pm19)
I still need help!
Posted on Aug 02, 2008
SOURCE: panasonic sa-ak20 5 CD changer does not work
hi i heared about you cd changer problem. i have a same hi-fi system an i have the same problem. it seems it appears when you hit.move or turn upside down the cd changer. you can solve it by unscrewing the top of the hi-fi with a regullar screw there should be 5 screws on the back and 4 on the sideways after this take the top off by pulling it upwards then you should plug in the hi-fi at the outlet and try to change the cd if it doesn't work try seeing if any of the cd is stuck in there if it is try to push it with your fingers but watch your fingers and do not touch any metallic part if in doesnt work like this eithertray looking if the cd-reader is stuck in any way......try to free it with your fingers but watch your fingers too if it doesnt work try to contact me at :tavi0815@yahoo.com il help you with any sound-sistem problem :D ;)
Posted on Jun 20, 2009
caroldon
  • 17129 Answers
SOURCE: Panasonic SA-AK29 Disc Drawer won't stay closed.
It is quite possible that the timing within the mechanism had changed. Since the timing is quite important to activate the mode switch to triggerr the sequential action of the mechanism to proceed accordingly, a small change in any of the links can change the mode to keep away from resetting. Please open the set and check if there is any foreign particles lodged into the dirve mechanism. Clean and proceed. Check carefully for any sensors that are out of sync.If you are not sure do not attempt but try tomake a small correction to complete the loading so as the complete the mode. If so the fault might clear. Hope this helps you out.Good day
Posted on Jul 20, 2010
SOURCE: Panasonic SA-PM19 5 disc player jumps around,
Could be a CD defect, but probably just dust inside. Try canned air, or connect IPOD after you convert CD's to MP3's or other player to AUX port as a connector as a work a around. Splicers available online if you already have a TV connected.
Posted on Aug 05, 2010
My panasonic sa-vk72d disc changer wont work.. The system hangs because the disc changer wont work properly
CD loader mechanism fault. Contact any service technician. This repair can't be done by a normal user. Gopakumar Gopalan Google
May 08, 2014 | Audio Players & Recorders
Panasonic SA-PM19 5 disc player jumps around, starting at or near first track, plays a little, then jumps a good chunk, plays a little more etc, until it reaches (quickly) the end of the disc. It does this...
Mar 20, 2010 | Panasonic Audio Players & Recorders
Why wont my kenwood cd player work ? It wont play open or do anything it wont let me do anything .
First you do is to unplug the cord of your CD unit for 5 hours in order to drain the stored current,the purpose is to reset the unit. After the 5 hours plug the CD see to it if it open If not,just try to press down on the stop button and pressing eject button at same time and it will unlock the tray .Then the other option is to open the cover of the CD unit and unplug the unit again to avoid electricshock . When open already look for the disc platter moved it outward while driving the gear or simply push out. The drawer or door of the CD player and you will see a small circular disc which is often called turntable or disc platter.When the disc platter is out push it back and push it out you do this three times so the slider mechanism align it properly.If you do already what i said then plug it again and if works already closed the cover. The slider mechanism, depending on the age of the unit and the manufacturer, consists of the small chrome rail, a drive motor, a small gear assembly, and (in some units) a small belt that drives the slider unit via the motor. This small belt causes all sorts of problems. If the belt is broken or slipping, it can cause skipping, dropouts, or simply no start up at all. Also, if the belt breaks in the middle of the disc, the drive mechanism gets hair or dirt wrapped up into the gears, or the pick-up assembly doesn?t return to the start position (called home), the unit will (99% of the time) refuse to release the disc, causing it to become stuck inside the unit. There?s a little micro or leaf type switch located at home position that sometimes gets dirty or breaks and, causing this problem also. Hope it may help you;
Regards;
VOTIT
DONT FORGET TO RATE;
Jul 02, 2009 | Kenwood CD-403 5-Disc CD Changer
Loading a CD
First you do is to unplug the cord of your CD unit for 5 hours in order to drain the stored current,the purpose is to reset the unit. After the 5 hours plug the CD see to it if it open If not,just try to press down on the stop button and pressing eject button at same time and it will unlock the tray .Then the other option is to open the cover of the CD unit and unplug the unit again to avoid electricshock . When open already look for the disc platter moved it outward while driving the gear or simply push out. The drawer or door of the CD player and you will see a small circular disc which is often called turntable or disc platter.When the disc platter is out push it back and push it out you do this three times so the slider mechanism align it properly.If you do already what i said then plug it again and if works already closed the cover. The slider mechanism, depending on the age of the unit and the manufacturer, consists of the small chrome rail, a drive motor, a small gear assembly, and (in some units) a small belt that drives the slider unit via the motor. This small belt causes all sorts of problems. If the belt is broken or slipping, it can cause skipping, dropouts, or simply no start up at all. Also, if the belt breaks in the middle of the disc, the drive mechanism gets hair or dirt wrapped up into the gears, or the pick-up assembly doesn’t return to the start position (called home), the unit will (99% of the time) refuse to release the disc, causing it to become stuck inside the unit. There’s a little micro or leaf type switch located at home position that sometimes gets dirty or breaks and, causing this problem also.
Regards;
VOTIT
Feb 01, 2009 | Sony CDP-C305 5-Disc CD Changer
The platter got stuck in the open position.
Drive belt for door and for platter need replacing
Jan 06, 2009 | Harman Kardon FL8385 5-Disc CD Changer
Remote control does not work
Sounds like a bad IR sensor in either the remote or the unit.
Dec 29, 2008 | Audio Players & Recorders
Dave
Jun 24, 2008 | Audio Players & Recorders
Panasonic stereo with 5-cd changer
Hi, I have a Panasonic SA-ak25 system. I played one cd then inserted a second. When the second cd had finished it ejected but the first cd is still in the player, When i try to eject it the lights start to flash and it always stops on no (4) can anybody help. Bob.
Jun 15, 2008 | Audio Players & Recorders
21 people viewed this question
 Grubhead
Grubhead
