Question about Yamaha RX-V2600 Receiver
No Gui The Gui Top button on the remote will no longer bring up on screen menu required to control component mapping on the receiver. I have performed a master reset, but apart from resetting my component mapping to some form of factory default this has had no effect - still no gui. I now have a basic system working using the default mapping - but I can not change this. how do I get the Gui Menue back - In all other respects the RX-V2600 appears to still work fine. I'v also tried disconnecting & unplugging from the wall to no effect. Netless
  • 1 more comment
  • Brenda Cross
    Brenda Cross Jan 01, 2014
    Make sure amp/source/tv is set to AMP? The manual says that you can run auto setup from the front panel so you might try to find that.
  • John Louis
    John Louis Jan 01, 2014
    Hi Brenda Yes I certainly have the remote in the AMP setting & yes the manual does appear to indicate that you can run the automatic setup from the front panel - but gives no indication of how to do this. This would also only balance the surround speakers to the room configuration, not allow me to re-map my components. I thought that perhaps the on board video card may have died, but I still get the guitar screen background & text relating to the changed input setting - but no GUI. In desperation I tried connecting an old analog monitor [composite & component - monitor output terminals] to see if I could get the GUI - but no signal appears to be mapped to these at the moment - let alone the GUI Menu. But thanks for your help. Netless
  • John Louis
    John Louis Jan 09, 2014
    Problem Solved by useful technician at a Yamaha dealer. If you have lost the GUI menu on a Yamaha RX-V2600 AV Receiver, make sure you have not accidentally reprogrammed the IR for this button on the remote - as I had done. If you have simply use the clear function on the remote to reset all the AMP buttons on the remote back to the factory defaults as per the instructions in the user manual. Hope this fix helps some other RX-V2600 owners out there
2 Suggested Answers
SOURCE: Yamaha RX-V2600 I can not access my receiver's on
Perform a master reset :
Here's How -->Set the master switch to OFF. Press and hold the Straight (Effect) button behind the front panel, then turn the master switch to ON. This takes you to the advanced Setup Mode. Use the program selector knob to get to User Preset, switch this to RESET. Turn the unit off via the master switch. Next time you power the unit on, all the factory settings should be restored with the exception of system memory and auto setup settings.
Posted on Mar 18, 2011
Radio tuning
PIONEER VSX-D903S - A/V Receiver
PIONEER CU-VSX079 - Remote
Here's the basics: Make sure your receiver is in the Tuner mode, by selecting Tuner on either the remote (grey button), on the receiver, or from the GUI menu. (The display will also show TUNER.) There are a couple of different ways to tune a station. One method is with the remote. Use the Band button on the remote (or via the GUI display), or the FM/AM button on the receiver, to select the frequency type. Use the Freq/Ch buttons on the remote to tune, the number buttons for presets (30 presets total. Examples: Preset 5, simply press 5; Preset 15, enter 5-5; Preset 25, enter 5-5-5). You can also use the on-screen GUI menu and the remote to tune stations, using the lower grey buttons. If you want to tune directly, via the receiver, press Select, to switch between frequency tuning and presets (displays ST CALL) mode. Use the Multi-Jog dial to make your selection in either mode. The easiest way to program a station into a preset is to use the onscreen GUI menu. [NOTE: The GUI mode (TV Monitor Video Out, composite video) is active when an amber (orange) ring glows around the Multi-Jog dial (the GUI button on the receiver will also glow simultaneously). Use the remote lower grey buttons, or use the Multi-Jog dial and Select, to move the cursor and select commands on the TV. This A/V Receiver handles composite video/S-video, and Stereo/Dolby 3-Channel/Dolby Pro-Logic audio only. (Pre-ATSC/HD video, Pre-Dolby Digital/DTS multi-channel surround audio)]
Feb 07, 2014 | Pioneer VSX-D903S Receiver
Message volume fixed
Zone 2 Setup on the RX-V773 using the ZONE2/PRESENCE Extra Speakers The RX-V773 extra speaker terminals can power one set of speakers for Zone 2 or Presence speakers. If the extra speaker terminals are utilized then the RX-V773 cannot be set for Bi Amp (Surround Back/BI-AMP terminals). Setting the Extra Speaker Terminals Note: The RX-V773 remote control will be used to access the On Screen Menu of receiver. 1. Press the On Screen button on the remote control to enter the On Screen Menu. 2. The On Screen display should be displayed on the TV/Monitor. 3. Press the Arrow Down button on the remote until Setup comes up in the screen. 4. Press the Enter Button on the remote control. 5. The Setup Menu will come up across the TV/Monitor screen. 6. Use the Arrow Left & Right buttons on the remote to navigate to Speaker. 7. Press the Arrow Down button on the remote to select Manual Setup. 8. Press the Enter Button on the remote control to enter Speaker Manual Setup menu. 9. Speaker Manual Setup menu with Power Amp Assign highlighted will come up. 10. Press the Enter Button on the remote control to enter Power Amp Assign menu. 11. Speaker Manual Setup, Power Amp Assign menu will come up with Basic highlighted. 12. Press the Arrow Down button on the remote to select 7ch+1ZONE. 13. Press the Enter button on the remote to select 7ch+1ZONE. 14. Press the On Screen button to exit the on screen menu. To control Zone 2 using the RX-V773 remote, the switch at the upper left side (above the BD/DVD Scene button) of the remote must be set to Zone 2. To see the operations on the front of the Yamaha receiver you must press the Zone Control button on the front of the receiver. Note: Only analog signals can be sent to Zone 2. If you want to output the sound from Zone 2, connect an external component to USB Thumb drive, USB iPhone/iPod, Network, AV 5-6 or Audio 1-2 by analog connection. For AM/FM radio the antennas must be attached.
Aug 19, 2012 | Yamaha RX-V773
Pioneer VSX D903S ...HOW do i adjust the rear speaker volume....it is currently much too low
You make surround channel adjustments using the on-screen GUI interface. This can be done either by using the remote (recommended), or by using the appropriate controls on the receiver. [The GUI mode is active when the GUI button and the ring surrounding the Multi-Jog dial is glowing amber.]
Nov 07, 2011 | Pioneer VSX-D903S Receiver
Remote doesn't control on/off,volume or channels
Remote won't workThe most common reasons the remote won't work is that the batteries are dead or it hasn't been programmed properly. It's often easy to fix. Here are the steps to take to troubleshoot the problem.
Make sure you have a clear path between the remote and the infrared eye on your equipment. Clear any dust or debris that may be covering the eye.
Try unlocking the battery-saving mode. When a button is pressed for longer than three minutes, the remote goes into battery-saving mode. Press the SAT mode button at the top to unlock it. Your remote should work properly.
Check the batteries. When you press a mode button, does it light up? If not, you may be out of juice. Check to make sure they are in the right way, with the metal ends making good connections with the metal in the remote. If they're in correctly and you still don't get power, try replacing them. They may be dead.Learn about batteries
Check to make sure the remote is programmed properly, which basically means you reprogram it to work with your receiver, TV and any other components. Start with the receiver and work your way through programming each component that isn't working. We tell you how to program remotes in our guide to remotes.Learn about remotes
Still no go? You may have an internal problem with the remote. You'll have to talk to a Shaw Direct customer service representative. Call 1.888.554.7827.Be prepared to tell us:What components you have.All of the steps you've been through to try and solve the problem yourself.Can't change channels on receiverThis is almost always caused by a programming problem with the remote. Here are the steps to take to troubleshoot the problem.
Make sure you are in SAT mode. The receiver will only change channels when the remote is in the correct mode.Look for a timer. If you have a timer set, the receiver won't let you change channels. This ensures you don't miss recording a program with an external device. If a timer is set and you want to watch another channel, simply turn off the receiver and turn it back on.Learn about timers
Make sure the problem is with the remote and not the receiver. Try the buttons on the front of the receiver. Try to change channels. If your model doesn't have channel buttons, try to turn the machine off. If you can't change channels or power off, the problem is with the receiver. Try unplugging it for two minutes and plugging it in again.
If you can change the channels or power off, the problem is with the remote. Press any mode button on the remote. It should light up. If not, you probably have low batteries. They should be replaced.
Try unlocking the battery-saving mode. When a button is pressed for longer than three minutes, the remote goes into battery-saving mode. Click on any of the mode buttons at the top to unlock it. Your remote should work properly.
Try re-programming the remote to talk to your receiver.Find the manual for your remote control
Check to see if your Shaw Direct Receiver is using the same remote control address as your remote control.If you are using the DSR 319, HDDSR 505, or HDPVR 530 receiver press the Options button on the front panel of your Shaw Direct receiver. An options menu should appear on your screen. Using the direction keys on the front of your receiver navigate to 6 - System Setup and then press the Enter button on the front panel of the receiver. Using the same directional and Enter buttons go to 4 - System Setup. Then 3 - Installation Settings. Followed by 2 - Remote control Address.If you are using a legacy receiver such as the DSR 315, DSR 405, or any other receiver with front panel buttons, press the Options button on the front panel of your Shaw Direct receiver. An options menu should appear on your screen. Using the direction keys on the front of your receiver navigate OPTIONS and then press the Enter button on the front panel of the receiver. Using the same directional and Enter buttons go to 6 - Change System Settings. Then 3 - Change Installation Settings. Followed by 2 - Set Remote Control Address.Follow the on-screen instruction to reset the remote control address on your receiver and remote control.Check the back of your remote, if you own the IRC/URC 550 or RT-U50 remote controls you will need to enter the remote control address differently from what is displayed on screen. To program these remotes, hold the ENTER and MUTE button on your remote at the same time until the mode buttons at the top start to illuminate then enter the last three digits of the number displayed in "Current Address" column on the screen, then press the MUTE button to lock in the code. For example: If the remote address on the screen displays 0002, you would hold ENTER + MUTE until the mode button illuminated and then enter 0 0 2, followed by ENTER on your remote control.If you own the IRC 551 or URC 551 remote control you can follow the instruction depicted on the screen, but you must substitute the follows numbers in place those specified: 00869 for 0000, 01870 for 0001, 01871 for 0002, 01872 for 0003, 01873 for 0004, 01874 for 0005, 01875 for 0006, 01876 for 0008. For example: If the remote address on the screen displays 0003, you would hold the SAT button until it flashes, press 01872, then ENTER, to lock in the new code.Still no go? You may have an internal problem with the remote. You'll have to talk to a Shaw Direct customer service representative. Call 1.888.554.7827.What components you have.All of the steps you've been through to try and solve the problem yourself.Can't control TV volumeThis is almost always caused by a programming problem with the remote. Here are the steps to take to troubleshoot the problem.
Press the volume button on the remote. The TV mode should light up. If not, you probably have low batteries. They should be replaced.
If the SAT button lights up, you are in the wrong mode. Press TV and try again.
Try re-programming the remote to talk to your TV.Find the manual for your remote control
Still no go? You may have an internal problem with the remote. You'll have to talk to a Shaw Direct customer service representative. Call 1.888.554.7827.What components you have.All of the steps you've been through to try and solve the problem yourself.Thank you for using Fixya, Hope this will help your problem.Don't forget to rate me.thanks,Reymond
Oct 18, 2011 | JVC AV-27850 27" TV
How do I change the radio station on my pioneer vsx-d903s
Welcome to FixYa.
You need to use the remote control to access the radio station frequencies.
Follow the instructions below:
Thank you for using Fixya. Have a great day!
Jas247
Jul 23, 2011 | Audio Players & Recorders
Remote control not working with tv
The remote control is an acess to the TV device for example only from a distance. A remote controll for functionality would require to insert batteries a power source making possible communiction with devices requiring reception transmittion of signals. The remote is handheld pointed to the direction of TV requiring signal before button pressed woudl achieve response. a common button to start the remote control experience is pressing on the power button, that displays a signal on the TV. The TV should momentarily produce a sound and lighting effect,, and displaying on the dark screen a light blue screen. The initial signal response from remote control to TV indicates devices are functioning as required. Additional buttons on the remote controll could perform functions of several available.
The remote control has master button, menu on which every additional function is deriveable. Once the menu button is pressed with remote pointed in the direction of TV, should dicplay a list of options on the blue screen already established by power button. Every additional remote control device functionality is achievable by only after the first two buttons have been powered and pressed to display option results on a screen of TV. The remote controll buttons remaining perform complementary functionalities. For example, the arrow keys on remote control make movement of the options displayed on the screen, where a comfrimation button or identified as select allows to confirm remote functions displayed on the screen. A remote control could have several functionalities only accessible once made to display in screen. The three most common buttons on a remote control are First power button that powers on the TV, menu button that displays a list of functionalities on the powered on bl;ank blue screen, and using the arrow buttons on the remote would moves an indicator arround the screen area options. The selection button makes confrimation of the option.
Dec 02, 2010 | Philips Televison & Video
Can't use remote to change dish channels batteries are working fine
Hello my name is Michael Hurst with DISH Network. Sounds like your remote may need to be reprogrammed to the DISH receiver. You can press the Menu button on the receiver and that will get you to the System Info screen. Once you have this screen then press and hold Sat button until all the buttons on top of the remote flash red. Let go of the Sat button and pick a number between 1-15. Once the number is selected then press # and then Record. Watch the remote code number on the System Info screen. If this doesn't work then unplug the reciever from power outlet for 10 seconds and perform the step again.
Jul 03, 2010 | DISH Network IR Remote Control
My dish network dvr625 tv2 remote will not work with receiver. I just bought it used to operate a third tv. Does it need to be programmed?
Bring up the System Info screen (Menu 6-1-3, or System info button on front panel). On the lower right hand side you will see the address of the UHF (TV2) remote. On the new remote press and hold the SAT key 'till all the top buttons light once you release the button it should it flash. Then press the number on the key pad the receiver is set to, then the # key. The Sat key should flash three times locking the new code into the remote.
Jul 10, 2009 | Televison & Video
I need to program my new dishnet work remote
Turn the receiver off using the front panel power button and then press the channel up button and hold it until the unit powers on. This will bring you to the system info screen. There you will see the remote address the remote needs to be programmed to- usually 1. Now press and hold the SAT button on top of the remote until all buttons on the top lite up and release. Now key in the two digit number shown on the screen - numbers under ten will be preceeded buy a zero. Now press the pound sign on the bottom right of the keypad. The SAT button will flash three times and then you will need to press the record button . YOU SHOULD BE ABLE TO MANUEVER THE HIGHLIGHT ON THE SCREEN AND EXIT OUT OF THE SCREENS . Thanks for using Fix Ya. ---and if you can not bring up the system info screen perform the steps on the remote itself until you reach the correct number that will control the receiver- 01 thru 16. if you need further assistance please let me know.
Mar 28, 2009 | DISH Network 301 DTV Receiver
I try to use the remote and it does not work the SAT button, always turn red TV or VCR buttons. Batteries are new.
The remote may not be programmed to the correct remote address. If this is at the receiver location press and hold the SAT button until all buttons on top light up. Then key in 01 and press the # key. The SAT button should flash three times and then press the record button. You should be able to control the receiver now. If not and you have a receiver with front panel button behind the right pop out door press menu-menu to get to the system info screen where you will find the remote address for the remotes. Perform the same steps again but this time key in the number on the system info screen next to tv1 and complete the steps. This should resolve your issue. Thanks for using Fix Ya and let me know if I can be of further assistance.
Dec 11, 2008 | DISH Network IR Remote Control
Yamaha RX-V2600 Receiver Logo
85 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
