Question about Remote Start System
Viper alarm 5706v won't let me start my car
My 2006 jeep commander had a viper alarm 5706v installed about a yr ago it has worked fine until now it will not let me start my car not even manually it is turning over but not starting what could be my problem I made sure the hood was shut completely and everything that the owners manual says.
  • 12 Answers
SOURCE: problem with my viper alarm system on my 98' odyssey
first, you need to manuslly disarm the alarm. open driver's door, put key in ignition, turn on ignition, an then within 10 seconds push the valet/program button for a couple of seconds. (it is the little spring loaded push button that they installed with your system. probably in the kick panel or under dash
Posted on Jan 15, 2009
jmgldsmth
  • 2005 Answers
SOURCE: need instalation manual
http://www.directeddealers.com/manuals/OG/Viper/G3901V_09-2007_web.pdf
Posted on May 03, 2009
  • 24 Answers
SOURCE: Replaced the battery in my car need to reset my viper alarm
Alarms are not supposed to shut down the engine while you are driving if it was installed properly. Could be another installed accessory or the car itself has a problem. If it was in anti-hijack mode, you would receive a warning like honking horn. You may have to visit a repair shop and maybe your local Viper dealer to have them take a look. DC
Posted on Nov 04, 2009
  • 171 Answers
SOURCE: disable viper alarm
Yes the best way is disarm the alarm and put in a Valet Mode
To activate the Valet Mode do the following:
There is a push button or toggle switch to disable the alarm (to engage the valet mode). Without knowing where this
switch is you won't be able to disconnect the alarm.
1. Put the key in the ignition and turn it to the "on" position.
2. Flip the toggle or hold the push button for at least 5 seconds.
3. The LED. light will stay solid on.
4. Turn the ignition off
5. Release the push button. If you have a toggle leave it alone in step 2
Posted on Jan 08, 2010
Boole5555
  • 160 Answers
SOURCE: Viper 5101 Manual Transmission - can't start
First off, is it in neutral? It can't engage the starter motor if it's in gear. Secondly, If it was professionally installed, why not just take it back and demand that they fix it?
Your wiring should somewhat match this.
Posted on Jan 13, 2010
I have a viper 5706v remote start/security alarm on my 2007 honda accord sedan. When I remote start my car no inside lights, ac/heat unit, or the radio comes on. Just the engine is running.
the accessory 1 and or 2 wires from alarm brain are most likely loose or not connected at all to the accessory wires on the ignition side... hence the lights and accessories not coming on but engine does...
if you installed it I would recheck those wires... if a shop installed it I would take it back to them...
Jun 28, 2016 | Viper Vehicle Parts & Accessories
Need install manual for a viper 4606 v
Same as the 5706v. Here is a current link for the quick install guide.
http://www.net-import.dk/images/viper%205606v%20installationsmanual.pdf
Also 5706v install guide available at "the12volt.com in the downloads section need to be registered to download.
Sep 25, 2014 | Remote Start System
Lost my remote viper remote starter. Car alarm goes off when open and car won't start. What do i do to disarm the alarm since the car won't start?
Common issue.
Open doorAlarm will be going offLocate the antenna (should be on the windshield)Find the little black push button on the antenna.Turn key to the ON/IGN position (where all lights are on)WITHIN 5 SECONDS push the black button 1 time and release (unless your installer changed the number of pushes it should be 1)Within seconds the alarm will ceaseStart your vehicle.
If any other issues, send me a message.
Aug 25, 2011 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
I purchased a avital 4103 remote start kit.i also have a viper 300 esp alarm system installed. my question is can i use the avital remote control to activate the viper alarm and start the car along with...
Avital and viper remotes even though they look the same, they operate at different freqs. Im a retired alarm installer i could never get them to interchange.
Apr 09, 2017 | Remote Start System
My friend has a 1998 chrysler sebring with a viper 160xv remote start. Everything has worked fine until a few days ago when it would not start. In order to start it you have to have the key in the on...
the problem isnt with remote starters, or with viper products. the problem is with under qualified persons attaining products they have no qualifications to operate.
TAKE THE CAR TO A DEALER(VIPER ALARMS) and they can fix the problem.
remote start was designed for people who want to start their car from afar and could actually comprehend that the multifunction remote was not only a keyfob to lock a door , or start a car, but it is also capable of remotely accessing certain programming features of the viper alarm, and whilst in some goofballs pocket........while he was sucking down goldslager was unintentionally reprogramming the viper alarm, and setting it into various modes of operation.
your lucky you didnt accidentally program it into carjack mode. lmfao
Jul 31, 2010 | 1998 Chrysler Sebring
The mfg alarm system on my 2006 jeep commander intermittently has started going off. How can I temporarily disable the system?
There's really not very much you can do because of it being a factory alarm you will have to take it to the dealer and have them check it. They may just need to reduce the sensitivity (if too sensitive cars driving by and set it off). If it is bothersome and you have to do something about it, you can disconnect your cars battery until you can drive it in.
Sep 27, 2009 | 1994 Jeep Grand Cherokee
Keyless Entry doesn't unlock my doors anymore
Did you get help? My problem is similar but not as bad. My viper550ESP no longer remotely unlocks the doors (well very, very occasionally it does). That is the only problem.
Jul 21, 2009 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
Need to disarm the alarm because the remote is not
i have an 02 WRX my alarm keepes going off and i cant start my car and it keeps honking and honkin this viper system cam with the car n there is no button to press my blue button is flashing n my car is honking loud ! help! RPN 473V
Jul 20, 2009 | Viper Vehicle Parts & Accessories
Remote Start System  Logo
718 people viewed this question
Top Viper Vehicle Parts & Accessories Experts
Kevin Daniels
oneStan
oneStan
jason
Are you a Viper Vehicle Part and Accessory Expert? Answer questions, earn points and help others
