Question about Jura Capresso Impressa Z5 Espresso/Coffee Maker
Jura Z5 Error 6 - Jura Capresso Impressa Z5 Espresso/Coffee Maker
4 Suggested Answers
EsWorld
  • 1618 Answers
SOURCE: Jura Z5 - no water being sucked up through the system
If you are holding the filled water tank in your hands does it leak? If no then the o-ring in the bottom of the hole on the machine where the tank sits is damaged.
If yes then check the spring and o-ring on the bottom of tank.
Posted on May 15, 2009
SOURCE: My Jura impressa Z5 shows an error code 6, what
how??
Posted on Jun 10, 2010
SOURCE: How do I fix our
Press the button to the right of the function wheel that should be lit, this will then purge air from the water pipes and fill the boilers, the unit should then operate as normal.
Posted on May 09, 2011
Jura impressa Z5 doesn't switch on anymore. A few days before just was displaying "maintenance" and then no more signs of life.
Search Results
    How to Fix Jura Z5, Z6 and Z7 - YouTube
    ? 16:03
    https://www.youtube.com/watch?v=HlCu5m9isT4
    Aug 18, 2013 - Uploaded by Parts Guru
    I changed the filter, pressing button for System Fill, get message System is filling. .... My Jura Capresso Z5's milk frother doesn'twork. When I ...
    Jura Capresso Z5 Impressa - No milk frothing - YouTube
    ? 1:05
    https://www.youtube.com/watch?v=_jF_8rNUn4A
    Oct 25, 2013 - Uploaded by Frederic Valiquette
    Hi all, My Jura Capresso Z5 Impressa is acting up. The milk frother doesn't work anymore. When I ...
    [PDF]Instructions for Use, Manual JURA IMPRESSA Z5 - Esperanza
    https://www.esperanza.ch/.../download_manual_jura_impressa_z5-gen2_...
    The IMPRESSA Z5 - Generation II Manual. The 'IMPRESSA .... 5 Preparation at the touch of a button. 40 ..... As coffee and coffee specialities are very important to JURA, we have compiled a ...... It doesn't matter whether whole milk or skim.
    My Jura Impressa Xs90 won't switch on and nothing is - Fixya
Jan 31, 2016 | Coffee Makers & Espresso Machines
It has error 8 on it what do u think?
Jura Capresso Impressa E8 Espresso/Coffee Maker Error 8 ...
www.fixya.com > ... > Jura Capresso Impressa E8 Espresso/Coffee Maker
Jura Capresso Impressa E8 Espresso/Coffee Maker, error 8 related issues. Get free ... We have just done a full disassembly, cleaning, and relube of our Jura Z5 ...
Bosch Benvenuto B30 Espresso/Coffee Maker Error 8 ...
www.fixya.com > ... > Bosch Benvenuto B30 Espresso/Coffee Maker
Jan 14, 2016 | Coffee Makers & Espresso Machines
Error 4
Unfortunately the error message 5 indicates that the thermal block and/or thermal sensor and possibly a control board need to be tested, and likely one or more, possibly all, replaced. My recommendation is to send it to Capresso ask what it will cost first. M
Aug 11, 2014 | Jura Capresso Impressa Z5 Espresso/Coffee...
How can I fix my Jura Impressa z5? I have an error 4 on the display of my Jura Impressa Z5 coffee machine and other than turning it off at the power it won't do a thing.
Error 4 is in Plain text a Temperature measurement error in steam cycle (circuit)
Causes / Remedy:
Sorted in order of likeliness !!!
1) Thermal sensor is defective. Determine the resistance value at 20 degrees C to be about 12kOhm. - Replace thermal sensor if not.
OR
2) Cable broken to the thermal sensor or oxidized contacts. - Replace / repair the cable.
OR
3) Logic board defective - replace electronics / replace EEPROM.
If you want to do the job yourself. Parts for repair solutions above are
1) Replacement Thermal Sensor with cable GBP 19.99 plus postage
2) if you can fix broken wire or oxidized contact no need for parts
3) logic board GBP 198.99 plus postage (there might be the possibility to have EEPROM on the board replaced at a fraction of the price. Defective board must be sent in first.
It also is possible to sent in the machine for repair.
Jun 11, 2014 | Jura Capresso Impressa Z5 Espresso/Coffee...
Jura f70 error 8 solution
There is a Jura Error Guide that says:
  • Turn machine off, turn the main power switch off and unplug machine for at least one minute.
  • Turn machine on again. If the error message comes up again, try one more time.
Dec 31, 2009 | Jura Capresso Impressa Z5 Espresso/Coffee...
Error 6 for jura impressa z 5 ? How can I fix it? Do you have a service hotline number for it at all? Many thanks.
Error 6 means that the automatic ceramic valve having a problem reaching the right position. This is usually related to the main electronic board and there is a chance that this needs to be changed. There could be a possibility that the multivalve is broken, but if you can hear it turning when you start up the machine, it`s probably ok. Contact your dealer for service, or call Jura hotline for your local servicecenter; +41 062 389 82 33
Sep 23, 2009 | Jura Capresso Impressa Z5 Espresso/Coffee...
Jura Capresso Impressa Z5 Espresso/Coffee Maker Logo
Top Jura Capresso Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Jim Goldsmith
Jim Goldsmith
Are you a Jura Capresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
