Question about HP OfficeJet 6210 All-In-One InkJet Printer
I have problem with my printer Hp 3920... the color cartridge didn't... i have buy a new color cartridge but it didn't work too... please help me!
    Sergeant:
    Champion:
  • 240 Answers
Try to wipe it in wet cloth to identify if there is a ink comes out from the cartridge and also to clean the nozzles...and then run a maintenance page ..
Go to your printer panel ..
select maintenance ..
and print maintenance page or clean printhead option..
I hope it helps...
good luck..^_^
Posted on May 19, 2009
My HP 3920 is showing error of "The following print cartridge is not intended for use in this printer Tri-color" and Status is : paper jam. Any body can help me how can i fix it?Thanks
If you know you have the right cartridge, and it is inserted correctly, you might try opening and closing the paper jam door in the back of the printer. Sometimes the printer gets "confused" as to what the real problem.Or, at least my HP printer does.
Dec 13, 2009 | HP DeskJet F380 All-In-One Printer
Hp 3920 deskjet printer
Please check for the cartridges and try to make copies.
Aug 03, 2009 | HP DeskJet 3940 InkJet Photo Printer
New tri-color cartridge has a problem. I can't see what.
I have an HP Photsmart C4100 printer. I purchased remanufactured ink cartridges (both black and tri-colored) from Vivasmart. The black one works fine, but when I installed the tri-color, I got an error message that says "Print cartridge problem" The following print cartridge has a problem:
Tri-color.
And I can't print. The screen on my printer says "Remove and check color cartridge." I have done this several times and it still won't print. I have turned off the power, removed the cartridges, and unplugged the unit, but it still didn't help. Any suggestions?
Jul 21, 2009 | HP PSC 1510 All-In-One InkJet Printer
3940 blinks and cant pritn
hello lotsaprint, ipang
Few days ago i had the same problem with my hp 3920 color photo printer. All i did is removed the cartridges one by one and the problem was solved. Try removing the color cartridge first, then switch on the printer see i the problem is solved the cartridge contacts must be dirty. clean it with soft tissue (dont use any liquid) and reinsert the cartridge. If the problem persists u may need to replace the cartridge. Check with a new one if u can borrow one from anyone b4 u buy.
Repeat the same procedure with black cartridge if necessary. If u r new and need guidance for removing the cartridge, then do the following.
1). Switch on the printer.
2). Open the front cover. The cartridge will now move to the
center.
3). Switch off the printer and remove the power cord.
4). push the cartridge gently downwards to detach.
Close the cover when u r done with above mentioned.
For more info see the user guide u go with the printer.
Hope this was helpful
anishpillai2
May 05, 2009 | HP DeskJet 3940 InkJet Photo Printer
Install HP Deskjet 3920 printer
Here is download page from HP
HP Deskjet 3920 Printer - Download drivers
Chose language and OS version. After downloading the file, double click on the downloaded file to start printer setup wizard.
Keep printer unplugged when you start installing files.
Sep 03, 2008 | HP DeskJet 3930 InkJet Printer
Wont print
some printers share the ink from color to black but you can select if you wants to use only black just go to printer than properies than select to use only black but you probably have to remove the empty color one
Dec 18, 2007 | HP DeskJet 3940 InkJet Photo Printer
Not printing text
CLEAN THE BLACK INK CARTRIDGE AND THEN NEEDED REPLACE IT.
THE PROBLEM SEEMS TO BE DUE TO A CLOGGED BLACK INK CARTRIDGE.
Dec 12, 2007 | HP Deskjet D2360 InkJet Printer
HP Deskjet 3920
same is my problem and now i feel that refilling caused it all!
please try using original and NEW cartridges for your HP printer!
the refills are normally low quality and often have some problem with them that may make your printer burst!
Nov 12, 2007 | Office Equipment & Supplies
HP Deskjet 3920
Does the printer go like crazy from side to side hitting hard on each end?
Oct 13, 2007 | HP DeskJet 648c InkJet Printer
HP OfficeJet 6210 All-In-One InkJet Printer Logo
81 people viewed this question
Seeker5211
Seeker5211
