Sandstrom tv my s26hed12 built in dvd player won't load keeps rejecting the disc saying clean disc or make sure it is in the correct way around
HDTV GURU
  • 261 Answers
SOURCE: DVD player not working
It could be that the DVD player has a bad home switch in the dvd player or that it doesn't know that the door is closed. I have run into similar situations with CD Players years ago. Also keep in mind to unplug unit and let sit for 1 minute to let microprocessor reset. Let me know if that helps. Thank you ...Jay
Posted on Jan 31, 2008
  • 14 Answers
SOURCE: Built-in DVD player
Are you trying to play DVD's you've made or copied yourself or new one's you buy from an actual distributor? Because sometimes self-ripped Cd's & DVD's won't play on a LOT of DVD players. Otherwise it's bad DVD player and you should go get it swapped out if it's not too late.
Posted on Mar 02, 2008
  • 1779 Answers
SOURCE: have a Polaroid TDA-03211C tv with dvd player. Won't play DVDs
As long as you know a disc is not stuck inside I recommend taking it to your local svc center to be looked at.
Posted on Mar 04, 2009
  • 86 Answers
SOURCE: 32lg40 built in dvd player disk error
There definatley could be a firmware issue with that TV's DVD player if the model has just been released.  My suggestion would be to bring a couple of known to be working DVD's back to the store and try their floor model as well.  This will be easier than bringing back the TV for the second time.  If this is a problem with the DVD player's firmware, LG should be able to fix it under warranty so I would call them or swap out the TV for another brand instead.
Posted on Mar 24, 2009
SOURCE: dvd wont read discs dvd or cd
is the drive still recognised by the system of the tv? If so it may simply be a dist situation (that's what happened tro me recently) unless it was jolted heavilly just before it froze. I asume other disks won't read either. You could try a dvd cleaning disk but I found them to be pretty **** and an aerosol cleaner works a lot better. Get one from an electrical component supplier or even some department stores stock them. Be sure to use the right product, i.e. for blowing dust out of electrical systems, as you don't want to go spraying just anything in there. A friend of mine once used a car 'easy start' to try and do a similar job and he ended up buying a new cd player (it was an in car player). Like I said it worked for me.... I was ignoring my intuition for ages looking to get components replaced etc. Finally I gave in and ended up kicking myself for not having listened earlier!!!
Posted on Jul 06, 2009
DVD player not working!
The player uses a laser to check for a DVD. If the laser fails, the player acts like there is no DVD loaded and opens the disc tray so a DVD can be inserted. Sounds like a bad laser.
May 04, 2015 | Televison & Video
Dvd keeps rejecting
The player mechanism may have failed.
Apr 04, 2014 | Magnavox Televison & Video
Dvd player in combi 19"
Dear Concern, Please open the disc and clean it with very soft cloth and put some cologne in it.. not too much that i wont get dry .. or not so little that it doesnt wets the surface for little while. Clean the small lens part also..make sure your hands are firm and gentle.
Feb 24, 2014 | Sanyo LCE19LD40DV-B 19-inch Widescreen LED...
Disc keeps getting rejected
see the cause and remedies and fix it: God bless you
  1. No disc. - Load a disc into the tray.
  2. Disc has been loaded upside down. Place the disc with the label side up.
  3. Disc region code does not match region code of the player.
  4. Disc type is not the correct type to play.
  5. Disc is damaged or dirty. Clean the disc or try another.
  6. Moisture may be condensed inside the unit. Remove the disc and the leave the power on for one or two hours.
see the block d. attached.
Jul 20, 2012 | Televison & Video
I have an advent DV1418A and my built in dvd player wont work when i put a CLEAN WORKING disc in it says loading then it says "no disc" please help!
The READ head is dirty or damaged...very difficult to get to the back of TV to disassemble DVD player.. clean read (light diode) head with light cleaning fulid or don't take apart & use official cleaning DVD disc. Look on web site for CD\dvd cleaning disc.It looks like a CD but has 'fuzz' or a very thin " rug" on 'read' side of disc.
Aug 08, 2011 | Recoton Advent Advent DV1418A 14 in....
Dvd player won't work, says no disk
Greetings,
I do not have good news for either of you. These are notorious for having cheap lasers in them and their original purchase price usually makes a repair cost prohibitive. If you are having an intermittent problem where the disc will freeze - then play - then freeze - then play this is often the first indicator that the laser is failing. One easy way to confirm this is to play a compact disc in the player. CDs are easier for the player to read than DVDs are. If it plays CD and you continue to experience problems with DVDs this usually indicates a laser failing. Remember, when buying a consumer electronic product, the price of a thing usually reflects the quality of that thing.
As for cleaning discs; if a laser has enough residue built up on it to prevent the error correction system from overcoming it, then the microfine brushes on a cleaning disc will probably be ineffective at removing that build up. Cleaning discs are akin to the old VCR cleaning tapes, usually ineffective.
Sorry for the bad news,
Rob
Nov 10, 2008 | Polaroid TTM-2003 Combo
Sony dvd recorder gx210
Without much more info the only thing I can think of is the lens is not homing correctly. If you are comfortable opening the unit, check to make sure the lens can move freely (from center to outside of disc). It's OK to gently move the lens with the unit unplugged.
MM85
Jul 25, 2008 | Sony RDRGX210S DVD Recorder
DVD player does not read discs anymore
the Laser is most likely defective. most likly it will need replacement. There is no correction that can made to correct the problem except to that of a replacement of the laser
Apr 06, 2007 | Toshiba D-VR4 DVD Recorder/VCR
Televison & Video Logo
22 people viewed this question
Top Televison & Video Experts
Electro Med Services...
