Question about Sony Grand WEGA KDF-50WE655 50" Rear Projection HDTV
Tv won't turn on; bulb is just a few months old and looks ok. green light is on
  • 668 Answers
SOURCE: hi just relaced the bulb 6 months ago Now tv
If you do not hear anything trying to come on, no fans, or relays clicking, you probably have a Thermal Fuse that has opened. Do to the dis-assembly that is required to replace it I recommend you have a qualified Service person come out to verify the symptom and repair the set. If that is what it is I estimate 400.00 or less to repair the set.
I hope this helps
Skyassoc
Posted on Oct 28, 2009
ladywinn
  • 5138 Answers
SOURCE: 42" red light on, dim light appears on screen. bulb just replaced
Sony has had alot of problems with the light engines
and your set is DLP. Call Encompass Parts Distrubtion for Part number and Price then go to E-Bay look under Electronics tpye in part number .I have found same Parts Alot cheaper on Ebay,some by as much as $300.00
you can Google website or call 1-800-638-3328
Posted on Mar 17, 2010
welcomejee
  • 10594 Answers
SOURCE: tv is 4 years old
Green tint indicates problem with optics unit (light engine) and it is costly fix, a serious problem as optics unit (light engine) will be replaced to solve green tin issue in tv.
Thanks.
Posted on Nov 07, 2010
vinceisaac
  • 2432 Answers
SOURCE: tv won't turn on the green and red light keep flashing
tried to check first the power supply if no any sign of bulging electrolytic capacitor this was a common that we encountered trouble.
Posted on Jul 19, 2012
SD Tech
  • 14553 Answers
SOURCE: Green tint on screen especially with dvds. picture also cuts out for a few minutes every hour or so on our sony kds-50a2020
Usually in this set if screen gradually changes to something other than black and white the optical light engine is the problem---major part.
Google the model number with "problems" or "light engine" to learn more.
Posted on Aug 29, 2012
Toshiba 62hm84 dlp
Sounds as though the system may have overheated. Do you regularly check the filters and clean them? An airduster can also help to blow dust out of hard to reach places.
Apr 14, 2014 | Office Equipment & Supplies
The power light is red and the bulb light is blinking red
OK...Did you replace the lamp with a Sony original? If you did, then carefully check that the door is closed properly.
May 28, 2010 | Sony KDF-E55A20 55 in. LCD Television
TEMP or BULB light aren't on and Bulb isn't burnt out So whats causing the TV not to turn on
Probably the ballast if lamp is ok.If there is not even a standby light the the power supply.
Apr 25, 2009 | Panasonic PT-40LC12 40" Rear Projection...
Projector turns on but no light or image from lens.
The bulbs do not always look broken when dead. You say it is used often. The life of a bulb is around 1400 hours I believe. This normally equates to a year or two depending on your usage levels. Did you notice your image getting dimmer in the months before it stopped working? This would be a good sign it was in need of replacement. Are the lights flashing very rapidly or blinking slowly? If they are flashing very rapidly this indicated the bulb will not fire and needs replacing.
Jan 16, 2009 | Dwin TransVision 3 Plus Multimedia...
Mitsubishi tv model wd-62531 less than 2 years old
It sounds to me like your bulb has burned out. Look behind your TV for where the bulb housing is and pull the bulb out to check if it's burned out or not. You'll know when you look at it if it's toast.
Dec 10, 2008 | Mitsubishi WD-62531 Projection Television
Sony Wega kdf-55wf655 rear projection set keeps turning on and off
If picture quality is poor, be sure you aligned the bulb in the correct manner and be sure the cover for the bulb is not loose. Also, you might want to re check you picture setting as it might have gotten reset when you pulled the plug (I hope you pulled the plug when replacing the bulb).
Heres another solution (maybe temporary) to the problem of no picture and no sound for 30 seconds. I had my tv's power saving setting on "standard" before. After I switched it to "reduced", the problem was fixed. It has been almost two weeks without the problem. I think its a good fix until the new bulb comes in the mail.
Jan 18, 2008 | Sony Grand WEGA KDF-55WF655 36" Rear...
Sony tv KDF55WF655
same problem... tv turns on and off repeadly while the green light flashes. seems as if the tv keeps restarting. please help.
Dec 13, 2007 | Sony Grand WEGA KDF-55WF655 36" Rear...
Vivitek tv
I have a 56" model that I have had a similar problem. My bulb burned out in <90 days. Warranty was 90 days on the bulb itself. When the TV picture goes out, the indicator LEDS blink on and off.
Here is what you have to determine:
1) First cover the left LED with a piece of paper so that you can't see it blinking. I don't know if your layout is the same as my TV. You may have to switch the paper blocking the LED.
2) Pay attention to the other LED and READ its' flashing code. In my case, the code was 2-3. It would flash 2 times, pause briefly, then flash 3 times. This meant code 23. That indicated the bulb was burned out.
3) If you look in the manual, It does have a code list of some sorts to tell you of the codes and their meanings. Hope this helps.
Nov 20, 2007 | Vivitek V37835 46 in. LCD Television
Sony LCD projection TV - bulb problem
Hi! sweet123,
Please answer this question. Were the 4 bulbs visabley bad; say broken or did they have a milkey look, or broken wire inside? In other words did the bulbs you replaced look as good as a new unused bulb? Please reply.
toprol
Nov 15, 2007 | Televison & Video
Sony Grand WEGA KDF-50WE655 50" Rear Projection HDTV Logo
66 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
