Question about Dell OptiPlex GX270 PC Desktop
I have a dell GX 270 that has orange light on mother board, shuts down randomly, seems hot, and says Alert! System battery voltage is low. The fan is running but doesn't kick out much air..
  • Michelle Audet
    Michelle Audet May 19, 2009
    It is the heatsink that is overheating.. The capacitors do not seem to be bulging, also I haven't cleaned the pc in a while.. It is rather dusty.. Should I try to clean it with canned air in case the thermal sensor is plugged? Thanks so much for your help! I have been reading that this particular model is prone to issues, I hope I can fix it so I can keep my data :)
    President:
  • 948 Answers
The battery message means you need to change the battery on the motherboard, it looks like a coin about the size of a nickel. Which fan is malfunctioning, the power supply fan, the case fan, or the processor fan?
Posted on May 19, 2009
  • Dick
    Dick May 19, 2009
    The heatsink fan is not hard to replace. Remove yours and take it to a computer store to get a replacement. If you can't remove it try taking a photo and posting it here.
Why does my computer dell optiplex gx 270 not fully support direct x 8.1
Your video card determines Direct X support. If you look at Newegg.com--find a newer video card and read the tech specs most of them now support Direct X 10 or higher.
I hope this helps!
Aug 10, 2012 | Dell Optiplex gx 270 heatsink & fan asm
My Dell optiplex gx 270 tower's chipset heats up and system shuts down and my friend's gx270 mother board is burnt due to same reasons
check the Cmos battery and computer RAM modules make sure they are securely seated with no dust built up or in the sockets on some motherboards cmos batteries are soldered in
check you CPU make sure its securely seated and has thermal grease might be getting to hot
another possible reason could be a memory dump you might be running to many programs at the one time putting to much strain on the CPU central processing unit
hope this helps
May 06, 2012 | Dell OPTIPLEX GX270 (Y1057) Motherboard
My dell GX 270 computer has amber mother board light,No display,processor fan runs,power supply fan rotates.
hi ansilesh
If the power light is steady amber - The computer is receiving
electrical power, but an internal power problem might exist.
Ensure that the microprocessor power cable is securely connected to the
system board.
it might also be a failed mainboard already since you are experiencing a blackout.
hope this helps
janc30
Feb 11, 2011 | Dell (002TR) Motherboard
How to chek which vga card is builtin in mother board gx 270
Visit the link given below.
http://support.dell.com/support/topics/global.aspx/support/my_systems_info/details?c=us&cs=19&l=en&s=dhs&~tab=2
Solution 1= Goto tab current system configuration and scan your computer configuration
Solution 2 = Enter service tag and click continue, factory loaded configuration list will appear.
May 29, 2010 | Dell OPTIPLEX GX270 (Y1057) Motherboard
Is dell optiplex gx 270 apligable for optiplex 270
i don't see any reason that you can't as long as you use the 260 drivers.
Nov 16, 2008 | Computers & Internet
Which sound card i need to instal
Here is a link to a diagram of the Optiplex GX 270 system board: http://support.dell.com/support/edocs/systems/opgx270/SM/EN/replbrd.htm
You need a sound card that has a PCI interface. On a Small Form-Factor board it goes into slot 10. On a Small Desktop system board it would install into the “riser board” which in turn is installed into slot 10. On a Small Mini-Tower system board the sound card would be installed into any available slot marked as 11.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Nov 16, 2008 | Dell Computers & Internet
Dell gx270 {switch}
My motherboard shows error thermal error and after 3 minut its power is close automatically
Apr 10, 2008 | Dell (4T274-DE) Motherboard
Dell motherboard {GX 270} over heating.
Hi
It seems the system is "dying" or already "dead". The initial heat issues suggests a faulty Processor (PRC) Fan. Faulty Power Supply Unit (PSU) Fan can have same effect.
Open the Base unit; disconnect everything (incluiding Keyboard, mouse, network) power-up and check that PRC and PSU fans are working.
Also check the QUAD Pack Diagnostic LEDs and compare the sequence with http://support.dell.com/support/edocs/systems/opgx270/en/ug/solve.htm#1235408.
This will help with identifying the cause. Try the Dell Suggested Resolution.
Reply if further help is needed
Regards
Mike
Mar 30, 2008 | Dell (4T274-DE) Motherboard
Dell OptiPlex GX270 PC Desktop Logo
728 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
