Question about Paini Spa Rubinetterie LaToscana Slide Bar Kit With Shower Head and Soap Holder
La paini shower valve too hot or too cold
The temperature of water is either too hot or too cold. La pain by toscana
2 Suggested Answers
  • 3 Answers
SOURCE: I have a Paini La Toscana hand shower w/slide bar
I had the same problem appear after 3 years of use. I changed the hose (found on eBay, Chinese knock-off, brushed nickel sleeve) which gave up after 2 months. I think the problem is with the handle, giving too much back pressure. No hose will with stand that much pressure for too long. I changed the handle yesterday.
Posted on Aug 06, 2010
Shower force
Are you wanting to change/switch the hot and cold range of the shower or the temperature max and min? As for the range, the Monitor pressure balance valve may be having build up or problems. This valve controls the mixture of hot and cold water. To fix this, you will need to turn off the water supply, take the pipes apart and clean out the valve (I would recommend a professional). As for the max and min, you may just need to check the water heater pressure in your house. It may not be the faucet at all.
Elisa Jed ' http://www.ryansallglass.com/
Feb 18, 2014 | Delta Home
Why do I only have hot water in the shower
sounds like either the cold water that feeds the other half got shut off, or the mixer in the valve for controlling the water temperature is broken....most likely the water got shut off. better go to the water source and trace the cold water feed pipe ,looking for a shut off valve....it could also be behind the shower panel, then turn or rotate the valve the other way and go test the water to see if you can adjust the temperature now.....if not, then replace your hardware.......in the mean time, you could turn the temperature down on the water heater so that you won't scald yourself in the shower til you have time to fix it properly.
Apr 26, 2012 | Moen Home
I have a hudson reed Twin Concealed Thermostatic Shower Valve. It was working fine for a couple of years. My brother used the shower and adjusted the water temperature valve but since then the water has...
Sounds to me the diffusor is stuck or broken in the position to allow only hot water through it.Looks to me tou have a mixer valve on it. Might have to replace it.
May 31, 2011 | Hudson Reed Home
When turning on the hot water on dedicated hot water faucets, the water is almost scalding. However, when turning on the shower and tub that has only one faucet handle (mixes cold and hot) and put the...
Pull apart the front of the valve and there is a limiter that is set to limit hte hot water, you need to adjust that limiter. I find many valves are shipped with teh setting too cold.
Oct 09, 2010 | Delta & Single Handle Shower Faucet
Temperature too hot on bristan art deco mixer shower even on lowest temperature setting.
if the water is that hot then lower [adjust] the temp of your hot water heater -if need to adjust the shower you can adjust the mixing by removing the handle and on the valve stem are the adjusting clips the red [hot] and blue [cold]plastic clips can move them around to adjust the mixing of hot and cold water
Jul 23, 2010 | Home
I have a Paini La Toscana hand shower w/slide bar that I purchased and had installed about 4 years ago. The system works great except the hose has sprung a leak. Where can I purchase the 78" replacement...
Jan 04, 2010 | Paini Spa Rubinetterie LaToscana Complete...
Shower water temperature regulation
The temperature is adjustable. The valve has a disc you pull off the front of valve and then rotate the seat I believe counter-clockwise. If you get the paperwork for this valve from moen it is very explanatory. I can help further if needed, Let me know!
Nov 10, 2009 | Moen & One Handle Tub & Shower Faucet
WATER IN TUB HOT, THEN TEMPERED
It sounds like you have an anti-scald mixer in the system that needs to be adjusted.
Jul 26, 2009 | Paini Spa Rubinetterie LaToscana 3 Piece...
Not enough hot water, has to do with a shower valve
Hello, first if any water supply hot or cold is turned off, you will experience trickling as you mention. You must have both cold and hot in order to adjust the temperature on your valve. if you had a plumber intall this unit you should ask him to adjust it. Otherwise here is how:
Rotate the handle counterclockwise to stop and let water run till cold water is purged, check
temperature. Rotate handle to off, remove handle parts (see Disassembly in your manual) and temperature limit stop, rotate clockwise to decrease and counterclockwise to increase maximum hot water temperature, reinstall temperature limit stop and handle (TIP: Do not screw handle in until desired maximum temperature is achieved) Repeat steps until desired maximum
Feb 21, 2009 | Moen 3175 Legend One Handle Shower Faucet...
E70
thank you, that was the problem, we had the hoses swapped. i appreciate this site! mike and pam
Dec 05, 2006 | Frigidaire GLTF2940ES Front Load Washer
Paini Spa Rubinetterie LaToscana Slide Bar Kit With Shower Head and Soap Holder Logo
27 people viewed this question
Top Paini Spa Rubinetterie Home Experts
Donni Steen
Tom Chichester
Are you a Paini Spa Rubinetterie Home Expert? Answer questions, earn points and help others
