Sandstrom tv my s26hed12 built in dvd player has stopped reading the dvd
  • 14 Answers
SOURCE: Built-in DVD player
Are you trying to play DVD's you've made or copied yourself or new one's you buy from an actual distributor? Because sometimes self-ripped Cd's & DVD's won't play on a LOT of DVD players. Otherwise it's bad DVD player and you should go get it swapped out if it's not too late.
Posted on Mar 02, 2008
javswr
  • 44 Answers
SOURCE: DVD input channel reads "no signal" when I try to play a DVD
First I would run a dvd cleaner in unit! Second you could take tv apart and look to see if signal cable is loose. the power wire seem fine as it powers up, and accepts an eject dvd.
Posted on Feb 28, 2009
SOURCE: dvd wont read discs dvd or cd
is the drive still recognised by the system of the tv? If so it may simply be a dist situation (that's what happened tro me recently) unless it was jolted heavilly just before it froze. I asume other disks won't read either. You could try a dvd cleaning disk but I found them to be pretty **** and an aerosol cleaner works a lot better. Get one from an electrical component supplier or even some department stores stock them. Be sure to use the right product, i.e. for blowing dust out of electrical systems, as you don't want to go spraying just anything in there. A friend of mine once used a car 'easy start' to try and do a similar job and he ended up buying a new cd player (it was an in car player). Like I said it worked for me.... I was ignoring my intuition for ages looking to get components replaced etc. Finally I gave in and ended up kicking myself for not having listened earlier!!!
Posted on Jul 06, 2009
dave1645
  • 834 Answers
SOURCE: Won't read DVD player
these unit are known for bad DVD deck
there is a place in Haverhill Ma that will fix it for you Tops Electronic service
Posted on Sep 20, 2009
  • 30 Answers
SOURCE: Built-in DVD player in tv stopped reading discs
try to clean the laser lens with rubbing alcohol and a q-tip. be gentle
Posted on Sep 26, 2009
Get RCA DVD Player to work.
ok on dvd player u wann use hdmi cable direct to tv ok then select input hdmi on tv remote to see picture
Feb 02, 2008 | Thomson Lyra PDP2860 Digital Media Player
Coby tv with built in dvd player stopped working no sinal
Check its input selection. With wrong input selection, either picture or sound will come out.
Jul 04, 2013 | Televison & Video
TruTech tv with built in DVD player not playing DVD's
the possible of dvd, its lince, its possible damage, specialy when use dvd has scrahts. try to clean useing cotton bads only, clean smothly, then try to use,
Apr 17, 2010 | TruTech PLV16190 Television
Sep 24, 2009 | Televison & Video
I have a large screen TV with a built in DVD player. How do I switch from the DVD player to TV? After using the DVD player I cannot get the TV to come on. Thanks.
Most likely there is a TV button on the remote.
Try turning it off then on.
If all else fails, try pressing Stop about 3 or 4 times.
Then it will stop the movie and the DVD player mode.
Jul 04, 2009 | Tvone 1TPC1280HD
T.V. shuts off when I try to play a DVD in the built-in player
Try putting in a VCR tape let it load and hit stop. If the set stays on it's the VCR deck causing the problem. It will be either be bad sensors or LED or possibly the mode switch. Let me know if this helps.
Oct 15, 2008 | Philips Magnavox 27MS343S 27" TV
Open Questions:
I'm hoping to get some clarification as to whether the below is correct or whether I have been taken for a ride. My LG was picked up by a repair service because it started displaying horizonal lines with the picture hazily in the background. I undertook some research and learned that in most cases of the boards needed replacing and it wasn't a panel issue (usually panel issues are associated with vertical lines). After having my TV for 5 days the repair service advised that it required a new power board and a small repair required on another board. They repaired the small repair and I was going to purchase a new power board however the TV has been returned to me dead. It now doesn't even turn on. The power/channel/indicator lights at the bottom flash on then switch off automatically. After getting consumer affairs involved, I finally received a call from the sub contractor and aside from a number of different excuses given based on my questioning of each explanation, all were contrary to the initial diagnosis discussed with me in early June. I documented the conversation which I summarise as follows: - he contacted numerous times however I never received any voicemail. I asked why - after "numerous phone calls" he didn't send a txt msg to which he replied that he's not allowed to send messages. - he initially alleged that the power board was repaired and video board needed replacing which I was quoted for. I corrected him advising that I was told and quoted for a new power board ($530) and the video board was to be repaired. He then changed his story agreeing with me and alleged that found and apparently quoted me $445 for a generic power board but I declined....Just to clarify, I never received this 2nd quote which is evidenced within the emails and messages I sent after receiving no response over a number of weeks. - he continued to claim that the TV now has panel problems and is now not repairable. - I recited the discussion the owner had with me which was consistent with the information when he provided me with the original quote of $530. He then altered his story replying that "this is a rare case... The owner doesn't know what he's saying". - When I challenged why I was quoted for a power board when he is now claiming there are panel issues, his response was that a new power board was to test if the panel was cracked!! - I replied saying that the TV was delivered to them with horizontal lines and even after testing should've been returned with horizonal lines however is now dead. - his excuse changed again advising that during testing he short circuited the TV and replacing the power board would continue to short circuit the video board..When I again questioned WHY then was i quoted for a new power board (as per the owners conversation with me) he returned back to stating that it was a rare case! - I told him about the screws missing in the back panel to which he commented that "they" wouldn't have put them back in because "they" assumed I would just dispose of the TV. What I find interesting is that this was his understanding whilst I was led to believe the TV was repaired (pending a new power board). It now makes sense as to why the driver who delivered the TV literally dropped it off and ran advising that he didn't know anything. I never received a service report and asked for it again however am yet to see it. Based on this information, can anybody shed light on what they've done to the TV? Prior to them taking the TV the horizontal lines were consistent with had a faint picture in the background and didn't alter at all. They're claiming that they did nothing and the TV - claiming that the reason why the panel doesn't turn on is because it was kept on while they were testing.
Sep 25, 2017 | LG Televison & Video
Televison & Video Logo
43 people viewed this question
Top Televison & Video Experts
Electro Med Services...
