Question about Kaito KA1103 SW/FM/AM Radio
Don't know how to recharge the batteries while they are installed in the radio.
Kaito KA1103 Cannot get it turned on.
  • 3 Answers
Had to repeat depressing the 'Reset' button at least 4 times before the set would come on. This may have been due to fact that the unit had not been used in almost a year. Also found that the set was shutting down when the status of the battery charge was checked. This was most likely caused by two defective batteries. Put in a new set of 4 rechargeable batteries and unit is now working fine.
Posted on May 21, 2009
Radio switches on for a few minutes with new batteries and then goes off
Usually because it will require a Security Code to be entered
Jun 14, 2010 | Kaito KA1103 SW/FM/AM Radio
Unable to use push button switches. All seemed stuck..
Check the obvious first, is the key lock on? If it is there would be a small key symbol on the screen. If this is not so then do a reset, use a small point as a pen tip to activate the reset button. You will loose all time setting but the memories should be fine. I have one of these and they are a good radio!
Feb 10, 2010 | Kaito KA1103 SW/FM/AM Radio
Kaito KA1103 Replacement AC Adapter to work in Australia
you can get on your electronics shop store near you, and antena also.
Jan 03, 2010 | Kaito KA1103 SW/FM/AM Radio
Need a replacement antenna
go to www.kaitousa.com for parts...
Nov 02, 2009 | Kaito KA1103 SW/FM/AM Radio
New KA1103 - no power
Have you depressed the 'Reset' button which is in the small hole next to the 'On-Off' button. Do that with a common pin or the end of a paper clip.
Feb 25, 2009 | Kaito KA1103 SW/FM/AM Radio
Battery Get Discharged within few Minutes even after Full Charge
I have the same problem, and for now an external charger is the best solution. Also try resetting 4 times. I also got a new power supply, but problem persist. Good luck!!!
jav
Nov 19, 2008 | Kaito KA1103 SW/FM/AM Radio
Kaito 1103 Shortwave Radio
I dont have this radio but I remember reading that you push the volume button then turn the tuning knob to change the volume.
Sep 23, 2008 | Kaito KA1103 SW/FM/AM Radio
DEGEN DE1103
I have the same problem .The controler has to be replaced .
Where to get one is my problem .
Jul 05, 2008 | Kaito KA1103 SW/FM/AM Radio
DE1103
you should try pushing the reset hole with a unfolded paper clip, or leaving the batteries out of the unit overnight
Jun 11, 2008 | Kaito KA1103 SW/FM/AM Radio
I can't get it to turn on.
First, make sure the batteries are good and capable of being recharged. Before setting the time, depress the 'Reset' then set the time. If set does not come on when the On-Off button is pushed or comes on and immediately turns off - depress the 'Reset' button a couple of times and then reset the clock and try the On-Off button again.
May 30, 2008 | Kaito KA1103 SW/FM/AM Radio
Kaito KA1103 SW/FM/AM Radio Logo
139 people viewed this question
Top Kaito Audio Players & Recorders Experts
xxxxxx xxx
Jean Philip
Jean Philip
Are you a Kaito Audio Player and Recorder Expert? Answer questions, earn points and help others
