Remove pulsator from washing machine model wpgt9360eoww
Model wpgt9360eoww
2 Suggested Answers
richroth
  • 9472 Answers
SOURCE: LG top loading washine machine pulsator asm does not agigtate and comes off.
What is the model number of the unit?
Posted on Nov 14, 2012
Replacement of cold water valve on ge model wpgt9360eoww washer
Is this a new development or has it always done it slowly? Before jumping to parts changing, make sure it isn't something simple like a kinked or obstructed hose or even something like someone nearly closed the supply valve!
Dec 02, 2014 | GE Washing Machines
How do I remove the agitator on my GE Spacemaker model GSLS1100?
Remove Pulsator (Blue) cap,Pulsator nut, Pulsator, and 2 washers and 1 nut. Pull up on the drum. But, 1st ask yourself WHY you want to remove the agitator!
Jul 02, 2014 | GE Spacemaker WSLP1100D Top Load Washer
How to remove coins trapped in a washing machine
firstly removed the pulsater which is found in the tub then see which screw is using unloose it with a srewdriver then removed the pulsater and the coin then replaced the pulsater and screw
Aug 18, 2013 | Sanyo SW-1150T Washing Machine
How to remove pulsator from machine
Hi raju_zade,
Quite easy. I take it you are referring to a top loading L.G washing Machine.
- Switch of the appliance at the wall, and open the lid.
- In the center of the pulsator is a small sieve cap, open it's latch
- Inside it, in the middle is a small screw, unscrew it
- Now simply pull the pulsator from the sides, this is sometimes difficult to accomplish due to washing powder buildup, but persist and it will eventually pull free.
I hope this has helped.
Kind Regards
JEDEMEYER1
* If this solution helped you, please rate it
Aug 16, 2011 | LG Washing Machines
Power comes on but will not start wash cycle justs sit there and humms
Try the steps below:
- try running it without any load to see if it still hums.
- if it does, see anything underneath the pulsating disk if there's anything stuck. (like a coin or a pin)
- if it doesn't, You can also try removing the belt between the motor and the pulsator to isolate if it's a defect in the motor or the pulsator.
After that, If the motor is defective, then you'd have to replace that or repair it if you know how to. If the pulsator is defective, check again if there's something stuck in the bushings. If you've used the washing machine for quite a long time, you may need to replace the bushings and bearings of the pulsator. You can also buy an assembly unit for the pulsator if there's one available in your area.
Hope this helps.
Jan 27, 2011 | Washing Machines
Hitachi SF-65PX Washing Machine
Hi just read your posting.As I understand from your posting, the center spline on your pulsator is stripped and you would like to replace only the center spline instead of the whole pulsator.Is this correct?Are you in Australia?If so then reply back and I can give you some contact details on where to obtain a pulsator from.I dont think you can buy just the center piece only the whole pusator.There are places that sell the pulsators secondhand which will save you some money.Please reply with additional information and I am sure I can help you further.Looking forward to your reply.
Jul 24, 2010 | Washing Machines
Displaying LE
Lg has a water pulsator which rotates while filling up with water. If pulsator is faulty, you will get this LE indication. Pulsator is found on bottom left hand side of unit when cover is removed. 2 clear water pipes are connected to it and there is a small plug in that has 2 wires. Remove plug in first then remove from the pipes.
Sep 21, 2009 | LG Washing Machines
Washing Machines Logo
20 people viewed this question
Top Washing Machines Experts
