Can't open door on my fagor L2281f washing machine
  • 3600 Answers
SOURCE: Washing machine front loading door won't open.
that is the way it's made you have to turn it off before you can open it or water would go every where.
Posted on Aug 20, 2009
SOURCE: Question: FAGOR FE-1158 ELEGANCE WASH MACHINE
Ich habe die Waschmaschine FAGOR FE-1158 schon 7 Jare.Jetzt wenn voll beladen bei wasche stoppen und schlecht Wasser komt.
Ich bedanke vorher!
Mfg
30655 Hannover
Posted on May 31, 2010
blueextc3221
  • 15935 Answers
SOURCE: my innova washing machine has lost two of its
The following advice is for replacing the "Agitator Dogs" on Kenmore and Whirlpool TOP LOADER style washing machines. This simple repair can save you a fortune in repair costs as the replacement parts are very inexpensive at a cost of less than $10. The replacement kit part number is 80040. You can order on line at various appliance parts websites, or use this part number and go to your nearest appliance parts retailer.
What are "Agitator Dogs"? These are small plastic pieces (usually 4) that are located under the agitator center cap that grip the agitator and turn it during the wash cycle. They can (and do) wear out dependent upon the use of the washer. If you are in the habit of doing large load sizes frequently, or wash large items such blankets or afghans, this can wear the teeth off and reduce the life of the agitator dogs.
SYMPTOMS REQURING REPLACEMENT: The agitator fails to turn during the wash cycle, or will not turn with a heavy load. The timer will run normally through all cycles, and you will be able to hear the gearcase (transmission) engage and run. The washer will also drain normally. The only indication that something is wrong will be the agitator slipping or not turning at all. The result will be clothes that do not wash properly and will sit on the bottom of the wash tub.
To replace the Agitator Dogs, follow these steps:
1.Remove the agitator center cap by either pulling straight up or gently placing a flat blade screwdriver into a slot located in the cap.
2.If the agitator is equipped with an inner cap with a handle, remove this as well by pulling straight up.
3.Remove the center bolt of the agitator. You will have either a 7/16" hex bolt or a recessed square plastic nut. If you have the square recessed type, use a 3/8" to ½" ratchet adapter to remove.
4.Remove the agitator by grasping the bottom flange and carefully pulling straight up. Try to keep all the parts assembled while doing this, so do not pull too hard. This will make this repair much easier.
5.Place your hand over the top of the agitator and separate the upper portion of the agitator from the lower portion and turn the top half over in your hand. The agitator dog assembly will come out in your hand.
6.With the agitator dog assembly in your hand, lay the rest of the agitator aside. Pay careful attention to how the dogs are installed. Remove the worn dogs and reinstall new ones. It's that simple.
7.With all the dogs replaced and the assembly still in your hand, place the upper part of the agitator over the top of it, upside down, ensuring the inner assembly tabs align correctly.
8.Now keep your hand over the agitator top to hold all the pieces together and turn the entire assembly over (upright position).
9.Carefully align and reinsert the upper portion of the agitator to the lower portion. Again, making sure the two pieces align correctly.
10.Place the entire agitator assembly back on the gearcase shaft and reinstall center nut. NOTE: DO NOT over tighten the nut, or the agitator will not spin correctly. Just make the nut snug. Reinstall center cap and inner cap (if equipped).
These instructions should give you the basics on how to perform this repair. Since there are various agitator types in use by Whirlpool and Kenmore, assembly can vary.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 19, 2010
  • 6277 Answers
SOURCE: our fagor fwm714it washing machine
Sorry but I do not know your particular machine BUT I would suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters. The motor is unable to drain all of the water in the allotted time.
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and held in by a round cover/knob.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Posted on Feb 27, 2011
emissionwiz
  • 77499 Answers
SOURCE: front loader washing machine door won't open
try unplugging the machine to reset it.
Posted on Feb 28, 2012
How to clean inbetween glass on oven door.fagor double oven
take door off the hinges and then unscrew the 2 halves open, wash glass dry really well and reassemble . if you do not get dry it can cause the glass to break when it gets HOT
Mar 19, 2016 | Fagor Ovens
Not even distribution - fault code comes up on the screen and will now not wash anything.
could be a faulty door switch. with the door open the power will not go to anything. if you close the door and no light comes on then it thinks the door is open.
Sep 30, 2013 | Fagor Dishwashers
Fagor select fe-1046 manual
Does anyone have a manual or know where i can find a manual for a Fagor Select FU-1046 washing machine
May 17, 2012 | Washing Machines
Fagor Elegance FE 538 washing machine. A copy of operating manual pl.
i dont know how to use that machine.. FAGOR Elegant FE-538 ..
neet guide or manual ....
Jun 15, 2011 | Washing Machines
We have a fagor washing machine (model - FU-1148-IT) and cannot find a user manual for it anywhere, please help as we have a baby and it's not cleaning his clothes on the setting we are using
Have it on Number 3 for the wash, 5 is the best spin. It gets smelly quite quickly, so wash the drawer alot, and get the mould out from ALL the inside of teh drawer compartment, and wash it at 90 with washing machine service powder (Asda 3.50!)
Nov 26, 2010 | Fagor Washing Machines
Error F08 on a fagor washing machine FU-6146
F08 on my FAGOR means a new motor is required we've had 3 failed motors in the past 2 years , total rubbish machine , would never buy FAGOR again . Mr M Freeman.
Jul 14, 2009 | Washing Machines
We have a 1 yr old Bosch wash machine w/o problems till now. We have a problem with the centrifuge program-it does not start, although the machine can spin slowly. Is it a motor problem or a problem with the programmer? Thanx for the help in advance!
Oct 16, 2008 | Washing Machines
Washing Machines Logo
27 people viewed this question
Top Washing Machines Experts
