Question about Frigidaire Model: FSC23F7HSB
Kenmore Refrigerator Model 25377132791, freezer builds ice
The freezer has stopped being cold enough and large deposits of ice have been forming from a cut thur hole in the inside back of freezer where you can see some part of the coolant system. I have been scrapping off the ice as it acumulates, but it won't stay cood enough anymore to keep the food at a safe temp, besides unplugging it and defrost which I am doing now, what else could i check/ be the problem? thanks ;)
  • 36 Answers
Your defrost heater isn't working .....could be that its burnt out or not getting supply from the defrost timer or it could be simply that its cracked since many are made of lime glass and when ice falls on it durning defrost cycles it cracks the glass .... to fix it , defrost the unit and take out the screws at the back ... there you will see a coil of aluminium and at the bottom of it you should see the heating element ... there are two wires coming out of it ,one on either sides ....its normally bout a foot or so depending on the size of the fridge......
Posted on May 19, 2009
Frig & freezer not cooling enough. Ice forming in back of bottom freezer.
You need to have the defrost cycle checked.( heater, limit stat, timer) If the frig can't defrost air can't move across your coils to cool properly. To temporarily get by until you can get a repairman, use a blow dryer to melt the ice build up. Once melted it will work normally for about 2 days till it freezes up again.
Nov 13, 2013 | Kenmore 73502 / 73504 / 73509 Bottom...
Freezer side not cold enough, similar temperature as Refrigerator side
It could be many things. My first guess would be the defrost. The coil that gets cold in your freezer builds ice on it and the only way to get the ice off is to run a heater near the coil long enough for the ice to melt. All freezers have something built in to defrost and domestic are typically just an electric heater on a timer. When your freezer stops working again, you may want to pull open the panel of your freezer and see if your coil (a heat exchanger that probably looks a lot like your car radiator) is covered in ice. If it is, it could be the timer or the actual heater that is bad.
Nov 12, 2013 | Refrigerators
Freezer is cold, refrigerator is not cold, also not cold enough for making Ice
See if the condenser fan motor underneath is running.Maybe completely filthy with dust build-up underneath refrigerator.May need to rake the coil.
Feb 07, 2011 | Kenmore Refrigerators
Freezer is too cold, ice crystals. Refriderator
I'm not sure which one you have, but try this: Look for the area where the air passes from the freezer to the refrigerator side, in the wall somewhere between them. Make sure that there isn't something blocking the passage. This is a good place to start.
Regards,--W/D
Jul 10, 2009 | Kenmore Refrigerators
Ice maker stopped working, plus fridge not cold, but freezer o.k.
I would check that fan motor in the freezer section is running. it distributes cold air from freezer into refrig section also if this motor is running the top portion of freezer will not get cold enough to allow ice production. the motor is easy to repl and is mod# specific you should be able to buy one online.
Jan 21, 2009 | Kenmore 64802 Top Freezer Refrigerator
Kenmore refrigerator model 46-66812 ice build up on the bottom shelf of freezer
Had the same problem. I noticed that the fan in the freezer never shut off so I suspected the thermostat. I ordered and installed a new thermostat (about $30 and 15 minutes to install), the fan now cycles correctly and the ice build up is gone.
Mar 21, 2008 | Refrigerators
Kenmore Coldspot Model 71182101
I have the same problem. The refrig and freezer are cold but not freezing and not cold enough. I have a friend tell me it probably is the relay. His did the same and that was the issue.
Jan 09, 2008 | Kenmore 72073 Top Freezer Refrigerator
Freezer
no its a defrost problem if you will send me a model num ill walk you through checking it but don't rate me till we are done
Jan 02, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Refrigerator Not Making Ice, Frost in Freezer and Refrigerator Not Cold
It has a defrost problem.  Most likely cause would be the defrost thermostat which clips onto the evaporator behind the back panel in the freezer.  Next most common would be the defrost timer.  Third would be the defrost heater.  Let me know if you want to try to test these parts.  If so I will need the entire model # from the sticker in the fridge or on older models on a plate at the bottom front below the door.
Oct 10, 2007 | Kenmore 53542 / 53544 Side by Side...
Frigidaire Model: FSC23F7HSB Logo
304 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
