Question about Arris Nvg510 At&t U-verse Modem Gateway Wireless Router Kit Nvg-510
Lites on modem
Ethernet lite and wirles lite flash no wi-fi situp lite.
Is it possible to connect a standard DSL modem - without Wi-Fi (with 1 Ethernet port) and a DSL modem - Wi-Fi (with 4 Ethernet port) to broadcast Wi-Fi singles
Does the non wifi modem give out DHCP addresses?
Can the wifi modem be set up to receive it's IP address from DHCP?
If the answer to both these questions is Yes then that's what to do as a first step. Make sure the wifi modem DHCP service is disabled as it must NOT give out DHCP addresses.
Connect the ethernet port of the non wifi modem to one of the LAN ports of the wifi modem and NOT the DSL/WAN port. The wifi modem is not participating in any DSL connectivity at all so it's DSL light will remain off. The non wifi modem is doing the DSL duty so it's DSL light should be correctly illuminated.
May 01, 2015 | Computers & Internet
I have T-Mobile 4g galaxy avant android phone. I do not have coverage n my ares 4 the Internet. Cam I hook WI-FI up 2 my desk top and accessories the inn tenet via my home wi-fi
You can get WI-FI anywhere WI-FI is available with a smart phone.
But if you only have a modem at home and an ethernet cable from the modem to your computer to get internet, then you may not have WI-FI at home.
You'll need to get a wireless router to have WI-FI at home.
Once you do that, you can continue to have your desktop hooked up by the ethernet cable, but you can also install a WI-FI adapter card in your desktop. It will have an antenna on the back of your computer and then you can set it up anywhere in your house and have internet without an ethernet cable.
Mar 16, 2015 | T-Mobile Cell Phones
Hi how do you connect your nintendo ds to usb wirless
Hi Ds lite use w e p encryption and I guess your wi fi will be w p a/2
You would have to change your modem/router to the w e p in your wi fi settings but this type of encryption is not secure
DSi and above use w p a and can access intenet www Better
Hope this helps
Oh and they're is no way to change from w e p on your ds lite console I'm afraid
Apr 27, 2014 | Nintendo DS Lite Console
How to get wi fi on the ds lite
you need a wi-fi enabled game. you would go into nintendo wfc, and then tap configure (in the game)
Jul 04, 2011 | Nintendo DS Lite Console
How do you get the wi-fi on the ds
To set up a Wi-Fi connection on your DS Lite you have to use a Wi-Fi enable DS game. Wi-Fi enable DS games have a Wi-Fi symbol on the front of the box it came in. Simply play the game and you should see options to set up a Wi-Fi connection.
Apr 21, 2011 | Nintendo DS Lite Console
How do you activate nintendo wi-fi connection
The DS Lite doesn't have built in Wi-Fi. Some games have Wi-Fi built into them, and they have to be activated from within the game itself.
The DSi and newer have built in Wi-Fi. www.nintendo.com has a guide on how to activate it on them.
Good luck,
Mark
Apr 01, 2011 | Nintendo DS Lite Console
I am trying to get wifi on my nintendo ds lite ,
The DS's Wi-Fi capabilities are not up to par and can unfortunately be a little fickle sometimes, and many people would rather buy another wi-fi device before trying to set it up, but if you do want to attempt to obtain your wep key so you can have wi-fi I am happy to assist you.
What you must do is get on to a computer that is hooked up to your wireless modem. From there you should be able to bring up on your system settings the information about the modem. Depending on what type of modem it is, you may have to flip through the more advanced information to find the wep address.
Once you do, you will have to put that code into the DS and pray that it works, because much of the time your DS will still not be able to connect.
May 14, 2010 | Linksys WRT160N Wireless Router
How do you set up wi-fi on a ds lite
You have to be playing a Wi-fi enabled game. Go multiplayer, then Nintendo WFC and edit your settings under this tab
Apr 05, 2010 | Nintendo DS Lite Console
Nds lite not working
Youve damaged the top screen cable - nothing to do with wifi block
see www.dsdoctor.co.uk
Jan 31, 2009 | Nintendo DS Lite Console
Ds lite modem broken???
Read the Wi-Fi connection booklet, or look on the Nintendo website for troubleshooting. You will most likely find your answer.
Jan 02, 2008 | Nintendo DS Lite Console
Arris Nvg510 At&t U-verse Modem Gateway Wireless Router Kit Nvg-510 Logo
Top Arris Computers & Internet Experts
bobkoure
Level 1 Expert
Suddenlink Help
Level 1 Expert
Are you an Arris Computer and Internet Expert? Answer questions, earn points and help others
