Question about Panasonic 42 TCP42S30 42 Plasma TV
Tv won't turn on, blinks 7 times stops then blinks 7 more times
  • 63 Answers
SOURCE: TV power blinks 7 times, but won't turn on
Marine on a mission here! To help every one that takes the time to post their problem. Times are tuff. PPL need to put food on their tables and not worry about calling in a tv repair man and spend hundreds. Took me a year to get the fix. Fixed 2 50" plasmas for 80 cents. After being told it would be better to replace than repair. BS! I held out glad I did. This is free advise, it will cost your your time and some pocket change.
Semper Fi
Gunny
Posted on Feb 12, 2009
dsacco86
  • 1077 Answers
SOURCE: TV power light blinks 7 times but it won't turn on
Most people call this "The blinking light of death".(part went bad)
Your TV when into protection mode to prevent further damage.
The repair shop may cost over $100 for someone just to look at it.
Or if you know someone with electronic repair knowledge, they have a service manual at nodevice.com
Most replacement parts you can get a shopjimmy.com ( go there to just to get an idea of what the parts costs).
Good Luck
RixsFixes
  • 2200 Answers
SOURCE: panasonic hd tv light blinks 7 times
Unfortunately this appears to be a common issue developing with these Panasonic sets i.e the '7 blinks of death'!
Several customers are complaining about it. The problem is caused by one, both, or all of the following boards: SC board, SD board, and SU board.
Most commonly, the SC board is the one that has failed and because Panasonic have received so many complaints about this issue they are now agreeing to replace the SC board under extended warranty.
However this is not widely known amongst the general public and Panasonic have kept it very quiet.
I would suggest that you make contact with the Panasonic Concierge service centre. Make them aware that you are aware of the SC board issue and that there is an extended warranty on this and ask them to replace it.
However if it happens that one of the other boards has failed be aware that Panasonic are not covering these under warranty and you will be charged for the repair in this case.
The Panasonic Concierge service is available from here
Thanks for using FixYa.
Posted on Jul 09, 2010
SOURCE: TV power light blinks 7 times and won't turn on
your sc bord is shot replace board and do firmware upgrade will coast about 400
Posted on Dec 17, 2010
lovejoy91
  • 691 Answers
SOURCE: TV will not turn on. Power light blinks 7 times,
If you are a DIY then you will need to try to unplug the SD board and reconnect and try again, if it stills shutdown with 7 blinks then the SD board is bad and maybe the
Physically disconnect the SU board and the SD board. (See precaution # 5)
Plug in the TV and turn it on.
Does the TV shut down and the power LED
blink 7 times?
Yes
No
Replace the Panel and the SU board.
(See precaution #3)
Reconnect the SD board only.
Yes
No
With the SU board and the SD board still disconnected, remove connectors SC2 and SC20 from the SC board (See precaution # 6)
Disconnect the SD board and reconnect the SU board. (See precaution # 5)
Yes
No
Replace the Panel, SD, and SU board.
(See precaution #3)
Replace the Panel and the SD board.
(See precaution #3)
Replace the SC board.
(See precaution #3)
No
Replace the D board.
(See precaution #3)
blink 7 times?
blink 7 times?
Posted on Jan 11, 2011
TV won't turn on
Here is a link with the codes for this set and others like it:
http://www.scribd.com/doc/43529880/Sony-Blinking-Codes
Personally I would suspect the high voltage block for this set is bad.
Nov 03, 2012 | Sony Kp-Fx432M91 43" Projection Wega...
What's your problem? won't turn on..... yellow/orange light continually flashes three times...
Toshiba Regza 37in - 37HL17
TV will not turn on - Yellow power ind. Light blinks three times...
Fixed with a firmware update (hard to believe, but true). Search Google for a file named: 2007SEN069.zip (don't worry if the page you find it on doesn't mention the 37HL17 - it worked fine). Unzip the file, and copy the 3 folders and 3 files to the root of a small SD card. The SD card MUST be 2GB or less in size (I used a 1GB card), and it MUST be formatted with FAT-16 (not FAT-32). Mine was pre-formatted as FAT (FAT-16). The SD port is on the back of the TV behind a cover plate near the power cable. You do NOT need to remove the back cover of the TV, just the small cover plate (1 screw). UNPLUG the TV; remove the cover plate; insert the SD card (prepped as explained above); Plug in the TV; Watch the yellow lights blink, then turn blue, then go dark; UNPLUG the TV; remove the SD Card and replace the cover; Plug in the TV; Yellow lights will blink a few times (this is normal); when blinking stops, turn on the TV and you should be good to go. :-)
Pictures attached are from a Toshiba software upgrade bulletin I found online.
09adb97e-8925-4d59-b218-7443a6e64989.png 82ea33aa-2353-4e13-a5db-8be13ba85711.png
Aug 06, 2012 | Toshiba Regza 37HL17 37 in. LCD TV
My Sony KV-32HS420 won't turn on -- blinks 7 times, pauses, blinks 7 times. I've seen the same problem described on this site, and the answer seems to be that 2 ICs on the DZ board need to be replaced. I'm...
The 7 blinks on this model indicates that the horizontal section of the TV has stopped working. Horizontal Deflection Stopped
Occurs when either:
1) a +B overcurrent is detected (IC5007), or
2) overheating is detected (Thermistor TH5002).
I have the serrvice manual if you need it. Let me know where to send it to.
Dec 16, 2010 | Sony FD Trinitron WEGA KV-32HS420 32" TV
Tv will not on. No picture no sound
buy a new one. or bring it to the store you bought it at
Jun 21, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Sstandby light blinks & doesn't turn on.
Unplug TV from the power outlet and let it sit for a few minutes, then plug it back. It sould work normally after that.
Apr 28, 2009 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Sony projecting tv kp-57wv700
Based on service manual info, it cant blinks 7 times as per symptoms, please count again blinks. It can be 5 times.
If its 7 times blink, Horizontal Deflection stopped in this case. If you want to repair it at your own, please let me know to guide you further but it is necessary you should have knowledge of electronics.
Aug 18, 2008 | Sony KP-57WV600 57" Rear Projection...
TH-42PX80U
i have the same problem but i have 11 blinks
Aug 13, 2008 | Panasonic TH-42PX60U Television
Panasonic PT-50DL54 problems
there actually was a class action law suit on these tv's due to the bulbs.
1 | Load Shortage
2 | Over Volage
3 | Fan Sos
4 | Main 3.3v
5 | Lamp Disable
6 | Gc3fm-Iic
7 | Gc3fs-Iic
8 | Gc3i-Iic
9 | Color Wheel Stop
there is the list of codes so yours is 7. Hope this helps.
Keep me posted.
Thanks,
Lee
Jul 21, 2008 | Panasonic PT-50DL54 50" Rear Projection...
Blinking Standby Light
KV32hs500 tv won't turn on. Standby light blinks 7 times, stops and then 7 more times, etc.. The tv will usually come on after about 2 hours or so of being off. Plays fine when on but once it gets turned off the problem happens again. Any suggestions? T.V. is 5 years old.
I have a similar problem . mine blinks 6 times or 7 sometimes also,and comes on with sound ,no picture for about 2 seconds then shuts off. Anything?
Jan 31, 2008 | Televison & Video
Panasonic 42 TCP42S30 42 Plasma TV Logo
55 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
