Question about Biddeford Blankets Biddeford Heated Mattress Pad - White Full
Does not work after losing power
Lost power at house power came back on now blanket does not work
Installed new starter. Has power. Turn key and it won't start and lose power. If I remove & reinstall battery cable the power is back but it starter still won't work
stock engine?
i did not decode that, at all.
has power? (what 12vdc power or engine power)
turn key it wont start but does it crank.??????? fast..
and lose power, what power is lost 12vdc power or engine runs but lost power?
the power is back what power? name something, specific,
like 12vdc power, starter power, engine power.
the starter wont work, i take that its silent?
or
starter spins but engine dont?
or starter clicks
or starter, is weak
or ???? try to be clear,
no engine stated.
no transmission.
if stick shift the clutch switch must work or the starter will be dead.
does that help
ever hot wire a starter, see this.
http://www.fixkick.com/nocrank.html
if engine will not crank, say that.
then say sounds. it makes if any.
Mar 15, 2015 | 1988 Suzuki Samurai
Why does the light keep flashing red on my sunbeam electric blanket control remote? It just keeps flashing on high I try ed unplugging from the outline and the blanket nothing works. It started doing this...
There is a problem with the blanket. Since it started doing this just after washing (as per instructions), I suspect that somehow - running it thru the washer caused the problem.
Since it is an electrical device, if allowing to air dry thoroughly doesn't let it work as expected, you should stop powering it - and use it only as a non-powered blanket or discard and replace.
Feb 03, 2015 | Miscellaneous
What does the light flashing on a sunbeam electric blamket controller mean and why wont the blanket heat up
The flashing red light is designed to notify you in the event that
a problem has been discovered by flashing the light on the base unit.
Before resetting the unit. First, check the blanket/mattress
pad for visual damage.
If no visual damage is found, unplug the system from wall outlet.
Check that the base unit is well connected to the module. Plug the power cord into the wall outlet. Set the base unit to "On." If the system still does not operate after two or three times trying to reset, disconnect the power cord and get it checked out by a specialist!
Nov 02, 2014 | Home
Why does my JVC KD-DB95BT car stereo lose power?
Power lost on two units in one car is a little unique. Does it lose power in the middle of a trip or when you first get into car? I would recommend bench testing to direct 12v unit to see if car is causing voltage loss.
Jul 25, 2014 | JVC Car Audio & Video
What sort of bedding should I use for my Dogs Kennel?
You can use old blankets to line your dogs kennel as long as they don't get wet. Blankets tend to retain moisture and can become cold and smelly. You should try to air the blankets as much as possible too by hanging them on the laundry line.
May 13, 2012 | Dogs
I bought a queen dual control warming blanket . I barely used it the first time I bought it a year ago. I put it into my closet for storage after the first winter. I put it on the bed today getting ready...
The flashing lights usually means theres a problem and the blanket has shut itself off so it wont cause a problem...Like burn down your house.
I love electric blankets but I have had little luck with them. Its only a matter of time before they get like this. I have never gotten one to work again after it has started to blink.
If you still have the box maybe there is a warranty.
Sep 21, 2011 | Health & Beauty
New heated mattress pad won't warm up. Controls keep blinking.
i've lost my control for a king size electric blanket. it had dual control-can u tell me where i can get one and the cost. thx
Dec 13, 2008 | Sunbeam SG7621SP Grill
My Sunbeam electric blanket controls blink when I plug the control cable into the blanket. I cannot turn the controls on or off.
Same problem, but now it is ok.  I emailed Sunbeam and was told that if my blanket was not plugged directly into a wall outlet it was not getting enough power and I needed to plug it into a wall outlet taking these steps:
1) Unplug from the surge protector/extension cord 2) Unplug from the blanket 3) Plug back into the blanket 4) Plug into a wall outlet
Jul 21, 2008 | Heating & Cooling
Biddeford Blankets Biddeford Heated Mattress Pad - White Full Logo
51 people viewed this question
Top Biddeford Blankets Furniture Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Biddeford Blankets Furniture Expert? Answer questions, earn points and help others
