Question about Margaritaville Mixed Drink Maker Home MD3000 Party Bar Man Cave NBMGMD3000 NBMGM
Valve is sticking on beverage container
Is there a way to lubricate the bottom valve on the beverage containers?
How can i attach the milk container
Add a little Petrol-Gel Food Grade Sanitary Lubricant to the two O-Rings on the machine were the milk container connects. If you do not have that available, wet your fingers with water and rub on O-Rings prior to inserting milk container. O-Rings dry out and go bad, they need lubricant. You can get Petrol-Gel at a restaurant wholesaler or Amazon.
O-O
Jun 25, 2014 | DeLonghi ESAM5500
Drain gas out gas tank
  • PROCEDURES
FUEL TANK DRAINING PROCEDURE
TOOLS REQUIRED
  • J 42960-2Fuel Flapper Door Holder
  • J 45004 Fuel Drain Hose
CAUTION:
  • Never drain or store fuel in an open container. Always use an approved fuel storage container in order to reduce the chance of fire or explosion.
  • Place a dry chemical (Class B) fire extinguisher nearby before performing any on-vehicle service procedures. Failure to follow these precautions may result in personal injury.
  1. Remove the fuel filler cap.
113355819
  1. Install the J 42960-2 into the fuel fill pipe in order to hold the door open.
  2. Insert the J 45004 into the fuel tank until the hose reaches the bottom of the fuel tank.
IMPORTANT: Lubricate the fuel drain hose with J 36850 Transjel Transmission Assembly Lubricant or equivalent to aid in hose insertion. Do not use an unapproved lubricant.
  1. Use an air operated pump device in order to drain as much fuel through the fuel fill pipe as possible.
© 2014 ALLDATA LLC. All rights reserve
Feb 07, 2014 | Chevrolet Uplander Cars & Trucks
Are there any surgical lubricants that contain an anaesthetic?
Lignocaine gel is a surgical lubricant that contains an anaesthetic. It is often used for inserting catheters and other procedures that might be painful without the use of anaesthetics.
Apr 24, 2013 | Health & Beauty
Do flavored malt beverages contain gluten?
Malt is made from barley, which contains gluten. If you are allergic to gluten, you should avoid drinking flavored malt beverages.
Feb 07, 2013 | Wine & Spirits
The milk doesnt heat up or froth but the button flashes red
We had the same problem with burn marks on the bottom and flashing red light etc. Now we just rinse the container out with cold water each time we use it - do not dry, just leave it wet and then add your milk. Heats up perfectly each time. The water lubricates the base of the container, preventing burning. Nice hot coffee every time now. Hope this works for you too!
Apr 20, 2011 | Nespresso Aeroccino Automatic Milk Frother
Check engine light comes on. Was told the purge valve soliniod may be sticking. Is there anyway to lubricate it?
It has been my experience that the purge solenoid assembly on most vehicles is a self contained unit and can only be replaced if problematic. Good luck
Oct 16, 2010 | 1997 Subaru Outback
Transmissiom shifts hard from 2 to 3 and no overdrive
This stuff works GREAT! You can buy it at any local auto part store for about $12. I added it to my 2001 Sonata that was shifting had from 3 to 4 (on the highway). I copied this info from there website. Google it and you'll find tons of reviews, all of which are good.
What Is Lucas Transmission Fix?
Lucas Transmission Fix is a thermal stable blend of petroleum extracted additives. It contains no solvents or anything else that would be harmful to an automatic transmission. It contains a seal conditioner to help stop leaks around seals. It contains a polymetric film which is designed to stop worn bands from slipping. It allows the the transmission fluid to run cooler and controls foaming. It mixes with all automatic transmission fluids. It also contains lubricity agents for smooth, precise shifting. Lucas transmission fix extends existing transmission fluid life up to 3x.
What can Lucas Transmission Fix do for my vehicle?
  • Stops automatic transmission slip
  • Cleans and lubricates sticking valves for smoother shifting
  • Stops leakage around seals
  • Extends fluid life up to 3x
  • Extends the life of your transmission substantially
  • Protects your transmission under all severe service applications
How much Lucas Transmission Fix do I need?
One 24 ounce bottle is all you need. Lucas Transmission Fix will not fix a mechanically unsound transmission. If you have slipping and/or shifting issues this product will help.
Sep 29, 2010 | 2001 Hyundai Sonata
How do i flush the hydraulic steering system
You really can't flush out the steering system fluid other then siphoning the fluid out of the steering pump reservoir. This is the easy way.
The hard way:
Remove the filler cap from the top of your power steering system then disconnect the reservoir's hose. It should be located on the bottom of the reservoir. The hose can be tough to remove, so make sure you have plenty of patience.
Replace the reservoir's hose with another hose. It should lead to an empty container. You'll use this container to store the old power steering fluid as it leaves the reservoir. Lift the front end of your car off the ground by using a car jack.
Add new power steering fluid to the reservoir. As you add the new lubricant, it will force the old lubricant into the tube you've connected to the bottom of the reservoir.
Climb into the drivers seat and rack your steering wheel back and forth. The wheel should be locked in place, allowing only a slight range of mobility. This will help the extra lubricant within the power steering system to drain.
Watch the empty container. It should fill with old lubricant. Once the old lubricant has been flushed and you see clean fluid replacing it, you've finished the hard part.
Disconnect your hose and move the container. Replace the original reservoir hose. Pour new, clean power steering fluid into the reservoir. Rack your steering wheel a few more times to squeeze out air that might be trapped in the lines. Replace the filer cap and close your done.
Thank you for suing fixya and good luck
Jun 11, 2010 | 1993 Chevrolet Camaro
532 ice maker works, but dumps water into ice container with ice.
Do you still have a manual or can tell me the watts power consumption of the 532?
I'll look into your question. Sounds like a sticking icemaker water valve, but I'll have a look.
Mar 03, 2009 | Sub-Zero 632 / S
Margaritaville Mixed Drink Maker Home MD3000 Party Bar Man Cave NBMGMD3000 NBMGM Logo
698 people viewed this question
Top Margaritaville Wine & Spirits Experts
Don Hart
Dave braun
Dave braun
Don A
Don A
Are you a Margaritaville Wine and Spirit Expert? Answer questions, earn points and help others
