Question about Mitsubishi Heating & Cooling
Pipes frozen on outside of unit, inside unit does not work
9000 BTU split mitsubishi a/c. Pipes outside unit freezes up. Indoor unit does not work. Unable to shut down outside unit.
  • 36 Answers
Sounds like the compressor relay is stuck in the 'on' position .... hence the compressor will not turn off .... to fix it you will need to turn off the main power (unplug) and take off the front panel then look at the circuit board normally the largest relay on the board is the compressor relay ... sometimes you can snap off the cover or break it off at times and clean the contacts ,give it a little spray with some contact cleaner or lub like wd 40 and that should be it .... alternative to this is just changing the circuit board all together ....
Posted on May 19, 2009
Pipe to my concept 1000 air conditioner was frozen and no cool air was distributing, fan to outside unit is running and I removed frost off pipes what else do I need to check?
It has to completely thaw first. If indoor fan is running and the filter is clean it is freezing up because of a lack of refrigerant .
Jun 10, 2017 | Heating & Cooling
3 split units run from one compressor one is not cooling
If there is 3 indoor units from one condensing unit
(6 pipes at outdoor unit) this is classed as a multi unit
All units will run correctly as long as they all require same mode, cooling or heating, if one unit decides to heat it will shut down until master unit decides to heat then it will start, for each unit to individually heat and cool there would have to be 3 pipes to each indoor,
Dec 19, 2015 | Fujitsu 9RLS 9000 BTU Split System Air...
Comfort star
Make sure the indoor filters are clean. The outside unit will continue to run until the indoor reaches the temperature you have selected. Dirty filters can throw the temperature out. Its common for outdoor units to freeze up when on heating mode if the ambient air temperature is below 5 degrees Celcius.. The machine should however, defrost itself. There could be a problem with one of the pipe or air sensors on the outdoor unit.
Feb 23, 2014 | ComfortStar CHH012CD-13B Wall Mounted Mini...
Frozen pipes coming from my outside heat pump and going to my inside unit
Frozen in suction line (bigger pipe) line due to indoor coil,airfilter and blower wheel dust blocked. Service the unit.
Second reason is short of gas. -Find out the leak and arrest it. And then do gas charging after vacuuming.
Dec 26, 2010 | Heating & Cooling
Outside unit
Most probably you need refrigerant re-charging. This is one of its markers.
I hope it helps.
Jun 14, 2009 | Haier HSU09XCA 9000 BTU 10 SEER Rating...
Fujitsu ASU12C1 is freezing up
unit is freezing up because it either has too much freon or not enough. the pressure should be checked on both the low and high sides and corrected.
Jun 13, 2009 | EMI EHW 18000 Air Conditioner
Will Not Heat
On the outdoor unit the fan should not be running, on the indoor unit the fan should be running. If you then check the outdoor unit with fan not running, you should be able to hear clearly that the compressor is actually working. If this is all correct, it is possible that your fourway reverse valve is seeping and needs to be replaced.
Apr 15, 2009 | Fujitsu 18R1 Air Conditioner
Pipe sizes
depends on the distance between the source and the unit
Feb 27, 2009 | RTO Hubbard Supply Co 250 Up to 1" CTS...
Heating & Cooling Logo
162 people viewed this question
Top Mitsubishi Heating & Cooling Experts
D. E. Hev
MightyMikeJr
Are you a Mitsubishi Heating and Cooling Expert? Answer questions, earn points and help others
