Question about X2Gen MG19MY 19" LCD Monitor
Black out My X2GEn mornitor can not turn on at all. It just stay on energy saving mode, which mean the power light is keep blinking.
    President:
  • 1,197 Answers
Even i had this same problem.....its two 220uF25V capacitors and one 47uF35V capacitor located on the backlight inverter chip covered by a plastic shield. It works just fine now. Be sure you get the polarity right when soldering in the new capacitors. It is marked by a shaded in half of the outline on the board and a line on the new capacitor. This was on x2gen 19inch wide screen though so check the specs of the capacitors on yours first. They all together cost around $5 at Radioshack.
hope i was helpful thank you
hav a nice day
Posted on May 19, 2009
LG TV Goes Into Hibernation (I Think)
This could be two things 1- a power saving mode in the TV... go into settings on the TV, look for either "power save settings" or "energy star settings" go in and turn that off. 2- it could be a screen saving mode because the TV has lost signal...some HDDVR receivers such as Direct TV DVR etc...have their own power saving mode, after a couple our of inactivity, they turn off, which kills the signal to the TV...so the TV shuts down because it has no signal coming to it.... if that is the case, you need to go into the settings on your cable/satellite settings and also look for a "power save mode" or "energy star saving", and turn that off.
Mar 21, 2014 | Televison & Video
I have a Dell Dimension e521 desktop that has gone into energy save mode after I ran Norton security check.. Pressing any key or clicking the mouse doesn't do anything. The screen is black and says...
you may find you have the screen resolution set to high, try changing to 1024x768 and try again. if this works it means your monitor ain't up to the job of your better machines.
Nov 15, 2013 | Cars & Trucks
I have a Dell Dimension E521. When I cut the power on everything comes on including the monitor, but the monitor will stay black. It does say something about power save hit any button but the screen
A solid green light means the computer is operating normally.
A solid yellow light indicates the power supply is operating normally but the computer is not processing data.
This could mean there is a problem with the CPu or another component on the motherboard.
((A blinking yellow light indicates the power supply is receiving power from the wall, but not functioning properly.
This generally means the power supply itself is bad and should be tested or replaced.))
A blinking green light means the computer is in standby mode.
You should consider visiting Dell Support and downloading the manual for your
your Dell computer. So use the LED power light codes if your Dell computer has them.
hope this helps
Sep 10, 2012 | Dell Dimension E521 PC Desktop
What would cause your power button light on the monitor keep blinking and the screen is black and you have trouble getting the light to stay on and get the picture back on. what is the problem. thanks,...
If the button on monitor is blinking, it means your computer is either turned off or in standby mode (or in hybernation).
You should push the power button on your computer to restore it from standby (or hybernation).
Aug 09, 2009 | Acer Computers & Internet
Screen goes black but power light stays on
Hello. I had the same problem with my X2gen 19" (model MW19R)monitor. In my case, the monitor would turn off after 20 seconds or so but the blue power light would stay on as well. I had to replace a high voltage capacitor located in the backlight power supply board. There are 4 blue capacitors on the board which are identical and they are marked as 27J 3KV. Fortunately, I only had to replace one of these capacitors ( it was turning a yellowish brownish color ). Hope this helps.
May 30, 2009 | X2Gen MG19VT 19" LCD Monitor
X2gen mw19u 19'' widescreen monitor going black
Try your monitor cable connections on both your pc and into your monitor.
Make sure they are TIGHT and level.
Also, it could be your video display card is faulty or your video display drivers are corrupt.
Try setting your desktop to a lower resolution, like 800x600 and see it that helps.
Nov 19, 2008 | X2Gen MG19MY 19" LCD Monitor
Monitor in sleep mode
I think it maybe time to buy a new monitor
Aug 09, 2017 | X2Gen MG15VT 15" LCD Monitor
Green blinking light on Mitsubishi WS-55813 HDTV
generally this means a bad digital module.. as a techinican the first thing that we would check are what is know as standby voltages. if they were there we would replace digital module.! question. Does it blink for more than 70 seconds. This unit comes with a lockout feature. to unlock press and hold menu down for 10 seconds on front panel.
Jan 08, 2008 | Mitsubishi WS-55813 55" Rear Projection...
X2Gen MG19MY 19" LCD Monitor Logo
282 people viewed this question
Top X2Gen Computers & Internet Experts
Sandy Moore
Sandy Moore
William Alequin
Are you a X2Gen Computer and Internet Expert? Answer questions, earn points and help others
