Question about Home
I need installation instructions for the Attwood 4142-1, 750 GPH shower sump
4 Suggested Answers
goofduck
  • 490 Answers
SOURCE: I bought an attwood fuel/water separtaor but it
in the fuel line between the tank and the motor
mount it someplace convenient and from the tank to the inlet side of the separator then out of the separator to the motor
Posted on Apr 16, 2009
  • 7 Answers
SOURCE: Appropriate size inverter for sump pumps
First...you need to find the amperage on the pump...your inverter is rated for 6.25 Amps...(750/120)...you will need an inverter bigger then the pump..I would suggest at least 1.5 times the size of the pump..bear in mind,..the inverter wasnt designed to start motors...so oversizing is needed..
Hope this helps
Posted on May 07, 2009
  • 35 Answers
SOURCE: installing lift station. have 30 gal sump bucket
Depending on local codes, you may need to vent a 2" line separately out the roof. Otherwise, you may tie this vent into the other house vent line, but it should be a 2" vent conected to another 2" vent line. Again, you will have to check local codes. The drain connection should be made with a 2" connection into the top of a 4x2" wye 10' from any other connection. This follows most plumbing ordinances.
Posted on Nov 19, 2009
Pump is flowing at 1/3 capacity. I replaced the fuse after it blew not it runs buy very slow....I replaced it with the required fuse
the fuse is only a circuit protecter, it will not cause your problem. have you tried replacing filter? check voltage at pump for correct volts. my system has 2 wires, 1 is low speed, 1 is high speed.
Jul 18, 2011 | Attwood Tsunami Cartridge Pumps Tsunami...
The is no water in the hole where the sump pump so why is it still running?
The float that turns the pump on and off is bad or stuck...
Pull the pump out and check the float... if it shuts off the find out what was holding it up...if it still runs the float is bad and will need to be replaced...
heatman101
Mar 23, 2011 | Genius Switch Submersible Sump Pump...
Not sure how to get the water heated. I've turned on the enterior switch and the switch on the back of the unit and tried to light the pilot but don't here any gas coming through at all.
OK this systems has a safety system and it will not let gas pass threw without the pilot light working correctly. first off near the pilot light there is a thermal coupling. this sends a signal to the main valve to open up. this thermal coupling need to get to a set temp. (hot) this is probably why you don't hear the gas. check if there is a manual bypass valve for maintenance. check if you can light the pilot rite away if you power the system on. it also has a time delay so the pilot won't give gas out if not fired on. sometimes there is a manual nozzle you have to press and hold till the gas pilot warms up the thermal coupling. hope i help some. thank you.
Jan 14, 2011 | Attwood 12V Shower Pump System 750 GPH...
HOW TO INSTALL SHOWER IN BASMENT WHEN GRED BELOW
You will need to pipe the shower to your sump well if you have one or get one of those ejector pumps to pump it to your main line. Tap into main might want to consult plumber if intimated by such a project but with some piping knowledge you can do it yourself. Do your homework first, don't be afraid to ask questions. Make sure to put check valve in line also, so no shower water returns to your shower.
Oct 09, 2009 | Smart Solar Sun Jet 150 Fountain Pump
Flotec 3200a sump pump sensor not working
Check the connections in the float switch (sensor). Give it a bang it may be stuck
Jul 02, 2009 | Flotec FP0S3200A-01 1/2 HP 3,200 GPH...
Recently purchased a vista pivot shower door - there are no included instructions 1505D-36NG06
instructions for shower door installations are very important to have,..i have installed over 100 of them and i still wouldn't attempt one without instructions,.your totally best to do the research it takes to get the instructions needed for this job,...there are certain cuts and measurements that are very dependent on specifications given by manufacturer to be right,....one wrong cut domino effects the whole job,....good luck
Jun 11, 2009 | Sterling Plumbing 1500D-31S VISTA PIVOT...
I bought an attwood fuel/water separtaor but it came with no installation instruction. How do you install the separator
Apr 16, 2009 | Boating
Home Logo
54 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
