Question about Marantz VP15S1 Television
Projector over heating
Overheating after new bulb installed
My 99 cadillac deville over heating new water pump / radiator,thermostat it's still overheating what to do
Hi Curtis, The link below is a youtube video showing a few different reasons a car over heats, Also there's videos down the right side that might help as well........CHEERS..
How To Fix A Motor That Over Heats
https://www.youtube.com/watch?v=evpaTW2WJ5Y
How To Fix An Overheating Car
Apr 28, 2016 | PERDE 94-99 Cadillac Deville Concours...
Overheating after new water pump and t-stat
was the thermostat installed correctly
( bulb to the head or block)
did you bleed the air lock from the cooling system
Jan 16, 2016 | Garden
Why does it work for 10 min, then turns off?
U might have a thermal issue or better still, a false overheating signal being generated. If you have one of those small 8 inch desk fans, put it on full blast and give the unit the mother of all blow jobs while turned on to see if it shuts off. If it still shuts off something else is wrong. If it continues to work then ........................
Sep 06, 2015 | ViewSonic PJD5123 3D Projector
My 73in Sony TV shuts off by itself every 10-15 mins and there's blinking. Then it turns back on and repeats. About a week ago I installed a brand new bulb. Could it be the bulb assembly or what? Please...
that sounds like the control board is overheating and the graphic chip is getting fault and keeps shutting down.Or the power supply as a bad capacitor, and that can do the same thing .
Thanks
Nov 22, 2013 | Televison & Video
I have a Sanyo PLC-EX20 projector which shuts down after five minutes, what could cause this?
There are 2 possible causes.
The first may be due to overheating. Most projectors have a "air filter" that can be removed and cleaned. If it gets clogged with dust over time, the projector can't breathe and shuts down.
The second cause may be your lamps life hour clock. Most projectors keep track of the amount of time that their bulbs have been active. Once a preset # of hours has passed the projector will limit functionality until a new bulb has been installed AND the lamp life clock reset. Most projectors do not automatically reset the lamp life clock after a new bulb is inserted.
There should be instructions on how to reset the lamp clock in your users manual, and info on cleaning the air filter. Unfortunately I went to the Sanyo website and was unsuccessful in locating a PDF of the user manual for you.
Mar 04, 2011 | Sanyo PLC-XE20 (Chassis XE2000)...
New bulb, fan working, after 10 mins of operation get posterized image; suspect overheating; dust has been cleaned out; has not been taken apart
Hi!
Is the projector placed in a box or an area where it could generate overheating? Is this projector still within warranty?
Please feel free to update me. Cheers!
Feb 04, 2011 | Optoma TX1080 Projector
Infocus IN72 - blinking RED light
firdt off, did you reset the lamp counter? did you clean the dust out of the projector? it may be overheating as well. if the lamp looks ok, you may have just blown the ballast. try projector doctor online.
Mar 03, 2010 | InFocus IN72 Multimedia Projector
How to replace a front light bulb on 2001 stratus
REACH BEHIND HEAD LIGHT ASSEMBLY.ROTATE THE SEALING COVER COUNTERCLOCKWISE TO REMOVE IT FROM THE HEAD LIGHT HOUSING.REMOVE THE BULB LOCKING SPRING. DISCONNECT THE BULB ELECTRICAL CONNECTOR.PULL STRAIGHT OUT ON THE BULB TO REMOVE IT.BY BULBS BEING HALOGEN.DONT TOUCH WITH BARE HANDS. OIL FROM HANDS WILL CAUSE BULB TO BLOW BY OVERHEATING.HANDLE BULBS WITH CLEAN GLOVES OR NEW CLOTH GLOVES.
Oct 31, 2009 | 2002 Dodge Stratus
Projector overheating and turns off after 20 mins
I have a HP VP6111 projector that works fine on a table top but overheats ( overheating ) when turned upside down and hung from my ceiling. My solution...I went to Circuit City and bought two 80mm computer fans. I also purchased a 12V power supply from Radio Shack. I put one fan on front of my projector and the other on the back of the projector and wired them into the 12V power supply. I mounted both fans with velcro. The front fan pushes air and the rear fan pulls air. The projector now runs fine without shutting off. The fans are 12V and push 34 cubic feet per minute of air. I am very happy with this solution.
Oct 25, 2006 | Compaq Microportable 2810 Multimedia...
Marantz VP15S1 Television Logo
Top Marantz Televison & Video Experts
 Grubhead
Grubhead
Are you a Marantz Televison and Video Expert? Answer questions, earn points and help others
