Ace water softener manual RMI30-T - Washing Machines
Trying to find out Danby DDW1899WP's salt capacity?
don't fill it more than half, you want to see that the unit is consuming the salt, but filling it all the way sometimes leads to a hollow pathway in the dissolved salt under the pile, the water channels through the path and your softener will be sounding like it is working, but doing very little. Be aware that there are different types of salt depending on your water type... there are rust removers, etc... I don't see how importing salt from Finland is going to be much more efficient than buying the salt at ACE hardware- whatever floats your boat.
Nov 21, 2016 | Danby Dishwashers
Need to know how to set program on an water softener model RM130-T .it is a water ace
http://www.fixya.com/support/t14961935-need_know_set_program_water_softener
Mar 16, 2016 | Water Dispensing & Filtration
Program a water softner
water softeners have good operators manuals for down load in pdf version
go google and type in workshop manual for --(your make and model ) water softener
Oct 18, 2015 | Water Dispensing & Filtration
Will recharge/backwash clean out sediments
You can try several regenerations to see if it helps. But if the well guys did not "by-pass" the softener when working on the well and all that C!!##p got into the softener it is probably toast and either needs to be rebuilt or replaced.
RJH2O
Aug 12, 2014 | Kenmore High-Efficiency Water Softener
Need owner's manual or set-up instruction manual for Pentaier Structural Water Softener - Model #CH30127
That is only the softener tank. We need to know what water softener valve you are using on the tank itself for further assistance.
RJ
Aug 19, 2013 | Pentair 14 x 65 Structural 30785 Poly...
Water softener fills up with water
If you are referring to the salt tank filling with water, then the problem is the eductor assembly. This is where the brine is drawn from the salt tank. If it is plugged no brine or very little brine will be drawn during regeneration. You will need to clean the eductor assembly and manually regenerate the softener to regain softened water.
What model softener is it? It would help to bail most of the water out of the salt tank. How much depends on the model.
RJH2O
Jan 26, 2013 | Measuring Tools & Sensors
We are having trouble finding salt to use in our Ariston LL 64 S stainless steel dishwasher - can someone please tell us what type of salt that we need to buy, and where we can find it? We live near...
Salt in the dishwasher or the water softener?
Did you check with the dishwasher manufacturer? Do you have an instruction book?
If a water softener, you use rock or sea salt available at your local Ace Hardware or other fine retailer in your area. If your dishwasher is making soft water for your machine, probably the same ... rock or sea salt.
Thanks for your question at FixYa.com
Jan 09, 2010 | Ariston Technologies LI640S Dishwasher
Manual
May I get the model # to help you more
Feb 12, 2009 | NRS Fleck 5600 - 64,000 Grain Timer Water...
Salt for DDW1805 Danby
I use ordinary household water softener salt crystals, not pellets, or table salt. The table salt often is not as refined as softener crystals, and can damage the dishwasher's softener in time. Also, the water softener salt comes in a large bag (around 25-50 lbs) for about $6 US.
Jul 12, 2008 | Danby DDW1805W Designer Series...
Washing Machines Logo
252 people viewed this question
Top Washing Machines Experts
