Question about Yamaha 2006 VK Professional
How to adjust gear chain on Yamaha VK pro
Adjustment of gear selector chain
    Problem Solver:
  • 18 Answers
Locate chain tension bolt.
Loosen locknut.
With 2 fingers tighten the lock bolt until it is tight.(not crazy tight)
Then back off the lock bolt 1/4 of a turn.
Hold bolt and tighten lock nut.
You are done now.
Posted on Sep 21, 2014
How to keep my gears from slipping
Firstly ensure the derailleur is in good condition and not bent so the chain is running perfectly in line with the sprockets. Ensure the stop screws limiting the extent of the travel of the derailleur are set correctly to prevent travel beyond the first and last sprocket.
A badly worn chain could need shortening or replacing in order to provide the correct chain tension or a loose chain could be a matter of a derailleur that hasn't seen the oil can for a while and is not tensioning the chain correctly.
If the bike has been involved in an accident the rear forks could perhaps need some adjustment so a straight edge laid alongside the main chain-wheel coincides approximately with the middle of the rear sprocket cluster.
At this stage it is also wise to ensure the gear cable is in A1 condition, smooth operating and properly oiled with no internal frayed strands causing problems.
If your gear selectors are of the modern style with detents the gear cable needs adjusting so the centre of each detent at the gear selector positions the derailleur precisely below the selected sprocket. Once this is done if everything else mentioned above is ok the gears should now operate smoothly and positively.
If adjustment doesn't work then the problem is likely to be with the basic requirements above.
Jan 26, 2015 | Cycling
How do i adjust a timing chain on a 1985 xj 900 yamaha
Hi, Anonymous for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
Cam Chain Adjustment
XJ900 Cam chain adjuster
Yamaha 95 XJ900S Service Manual
OEM parts for Yamaha
Yamaha diversion 900 XJ900S Owner Manual
May 28, 2014 | 1985 Yamaha XJ 900 F
Where do you add gear oil on a 2006 yamaha vk pro
There should be a dip stick on the chain case remove it and add oil there. until it is full on the shight glass.
Hope this helps.
Feb 15, 2014 | Yamaha 2006 VK Professional
How to adjust timing chain on 92 fzr 600
Hi, Anonymous sorry you can't find the first and best tool you ever bought for your Yamaha despair, not for a mere $10 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please visit the websites below. Good luck and have a nice day.
Cam Chain Tension Adjustment The FZR Forum
adjusting manual cam chain adjuster fazer 1000 01 05
https://www.tradebit.com/filedetail.php/2864660-yamaha-fzr-600-service-repair-manual-pdf
http://mybikemanuals.com/yamaha/yamaha-fz-owners-manuals
Mar 18, 2012 | 1992 Yamaha FZR 600
The gears are not changing to the right gear but i tried to change the gears to see if it will change back where it should be but it didnt. on my handle bars gears dile is saying 3 and 7 but the gears are...
Release your gear selector cables; position your chain on the 1st.or lowest gear
for both the derailer and, pedal gears.
Adjust your cables tighten and, test (some bikes use the highest gear to adjust from.
Jul 03, 2011 | Mongoose Exile 26 Men's Full-Suspension...
In the wheel gear adjuster for chain does not thighen chain when turning wheel like little gears are not matching up, what would be wrong?
The three hundred series saws have side adjust consisting of a small assembly, if the gears are worn it will require replacment, the hobby saw ( 235/236/240 ) had a plastic gear on the early models in the side cover, this has now been replaced with a metal gear, the semi pro saw has the assembly in the crankcase, this will require removing the clutch sprocket and bar plate to gain acsess to it.
Jan 22, 2011 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Yamaha hpdi 225 2 stroke throttle problems will engage in reverse but not forward
Your gear selector cable may only require a simple adjustment.They can and do stretch.Hope this helps
Aug 22, 2010 | Bass Pro Boating
Chain will not move on chainsaw
Normal 0 This will be the basic instruction for most common saws. Check that the chain brake is in disengaged position by moving the front hand guard towards the front handle if the saw is equipped with a chain brake on the handle. Loosen the bar nuts on the clutch cover. Loosen tension screw or other adjuster (thumbscrew) to allow the bar to be moved toward the engine. Some saws have this tension adjustment built into the bar. This will provide enough slack in the chain to able to reinstall it. It may be necessary to remove the side cover to gain access to the clutch/gear assembly on the side of the engine if the chain also jumped the gear here. Remove the cover, inspect for any debris or other obstructions in this area. If none, replace the chain back over the drive gear and in the bar groove all the way around the bar. It may be necessary to turn the bar adjuster screw more to provide enough slack in the chain to do this. Once the chain is in place reinstall the cover and bar lock nuts. Snug up the nuts but do not tighten these. Turn the bar/chain adjuster screw to tighten the chain on the bar (take up slack). I usually tighten to a point where there is no slack between the chain and the bottom of the bar and I can still turn the chain easily around the bar by hand. With experience you will get the feel for this chain tension. Once the chain is properly tensioned, tighten the bar lock bolts/ nuts on the side cover.
Some Poulan Pros have an adjuster screw on the front of the engine case right beside the bar, some have a tool less adjuster on the clutch cover, and some have a slot in the bar for adjusting the chain tension.
I hope this helps you out.
May 15, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Timimg chain tension
replace.
and when you replace, also replace gears, as a new chain will eat up the old gears, and vise-versa.
Apr 14, 2009 | 1980 Yamaha XJ 650
Yamaha 2006 VK Professional Logo
364 people viewed this question
Top Yamaha Winter Sports Experts
Arnie Burke
Arnie Burke
bazzz7071
bazzz7071
Are you a Yamaha Winter Sport Expert? Answer questions, earn points and help others
