Question about Samsung RFG296HDRS 29.0 cu. ft. French Door Refrigerator with Spill Proof Glass Shelves, Humidity Controlled Crispers, Power Freeze/Cool, External Ice/Water Dispenser and Dual Ice Maker
A growlining noise from the water system
When water goes into the ice makers or you are gettin a glass of water the the growling noise occurs and the water pressure drops. This dosent happen all the time only on occassions. I have changed the filter and purged the water lines numerous occassions
2 Suggested Answers
fourtdollarm
  • 11 Answers
SOURCE: samsung refrigerators
if the filter is dirty enough to where it stops the flow of water then yes.a replacement of the filter should fix the problem for you
Posted on Aug 19, 2012
Does not make ice
Either the ice maker is not calling for water or the ice maker water valve is not working, there are many different types of water valves so its very dificult to tell you what to do without a model number or picture of the valve, but generaly speaking if you VERY CAREFULLY put 120V to a water valve it should open and alow water to flow, you can try this for the valve that has a water line going to the ice maker and see if it lets water go to the ice maker, sometimes there are two valves that must open, one main valve and then another for either the water dispensor or the ice maker. a better first test might be to test the water valve for resistance across the coil and compair it to another coil and see if its close-ish. also you can test some ice makers and see if they are putting 120V to the water valve by bypassing the bimetal and causing the ice maker to go into a cycle, but again a model number is required to know what kind of ice maker you have., even a picture would help
Feb 08, 2013 | Kenmore Sears Tempered Glass Shelf Refrig...
Hoshizaki ice maker am-50bae . Made ice regularily--- filled ice bin half way...next day-- all ice melted away with no more new ice? next day shut off for 3 hours now o new ice.
make a few quick checks. If there are water filters on the system, be sure they are not restricked. Could be clogged. Next, check the bin stat. It usually is mounted in the ice bin. If it breaks or goes bad, it shuts down the machine. Start there and let me know if I can be of any further help.
May 19, 2010 | Hoshizaki Freezer Commercial Ice Machines...
Ice maker tray over flows and clumps ice, water freezes in drain at bottom and water will come out of the front of freezer door. this does not occur all the time just when it gets a hankerin too. could it...
Good day,
The normal operation is for the ice maker to harvest a batch of cubes, and then just before competing it's cycle, to open the valve to add more water for 7 seconds then shut off smartly.
At least 50% of water valve problems cause an overfill problem, because of internal wear etc. that does not let the valve close on time. This causes an overflow problem to the ice maker, and all the problems you described.
It should be corrected as soon as possible, since they have been known to throttle open and never close. Should it be overnight or while away, the damage can become quite serious.
Feb 12, 2010 | Maytag Freezers
Ice maker will only cycle once then it goes to off position . It stop working due to ice build up in supply tube. I removed the ice maker and ran hot water over unit to clear out the ice that was lodged in...
That bar your talking about goes to the full up position just before the end of the harvest cycle then falls right at the end of the cycle. But on a good day it barely drops. Characteristic of that ice maker.
If you ran water over the ice maker try these 2 things.
1. Remove the ice maker and leave it on the counter for about 2 days to completely dry out. Then re-install and try again.
2. If no luck, hang a small weight to the middle of the wire to see if it will drop on it's own.
3. If no luck, you'll have to replace the ice maker. However,
if your commited to buying a new ice maker, first snap off the front cover and look for interference where the wire goes into the ice maker. You can actually remove the whole solid state front end by removing the 3 screws that hold it on and make a more detailed check.
P.S. pull the wire out of the ice maker before this last step. It simply pulls out.
Oct 28, 2009 | Whirlpool Freezers
My jenn air freezer is not making cubes. the
The water inlet valve may be staying open. You can swap the wires on the dual water inlet valve and disconnect the water line at the valve which goes to the ice maker. When you try the water dispenser the water will come out there. When you stop the water dispenser, if the water at the valve doesn't stop, the valve isn't closing so you'll need to replace it. If it does stop after trying it several times then the problem is with the ice maker.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze. You can take the water line off the valve and watch to see if it drips.
Jul 13, 2009 | Jenn-Air Freezer Jenn Air Clear Cube Ice...
My whirlpool ice maker makes a noise like its growling or like a
please switch off your refrigerator for at least 8 hrs. than again switch it on. if your problem is not cured than it is sure that your refrigerator have the blower problem because for this reason only, the problem arrises ....... please visit your service authority...........have a nice day:-)
May 15, 2009 | Whirlpool Freezers
Samsung RFG296HDRS 29.0 cu. ft. French Door Refrigerator with Spill Proof Glass Shelves, Humidity Controlled Crispers, Power Freeze/Cool, External Ice/Water Dispenser and Dual Ice Maker Logo
16 people viewed this question
Top Samsung Freezers Experts
Dan Webster
Dan Webster
Jay Finke
Jay Finke
ray gallant
Are you a Samsung Freezer Expert? Answer questions, earn points and help others
