Question about Sony KP-46WT500 46" Rear Projection HDTV-Ready Television
I have a convergence problem.
I have a Sony KP46WT500 Television Convergence problem. It bows and the alignment is way out. I replaced IC's and checked resistors and that didn't help the problem.
  • 36 Answers
Did you check the power to the IC's ... normally when either one of the IC's burn out it takes out the power supply ..... make sure there is both a positive and a negative supply present there ... possibly + and - 28 volts or so .... if any of the voltages are missing ,check the 5 amp fuses that look like little green resistors on the power supply board ... that should solve your problem ....
Posted on May 19, 2009
I have an older model rca rear projection tv. The problem with the tv is that the picture bends into curve after about 5 minutes after it has been turned on. Please help.
Check the convergence IC's for cold solders, check for leaking capacitors in the area. Check the voltage regulator with a Variac.
Usually these sets just need the 2 big convergence IC's replaced with new ones. Clean all 3 picture tube lenses, mirror and screen. Get the original RCA remote that came with the set and MANUALLY align the convergence.
Rarely the bow on the bottom of the screen is not repairable.
Jul 18, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
My screen to my RCA 56" HD TV is messed up. The picture seems to be bowed inward and the colors are all mixed up. I tried to do the convergence but it is not on the menu and I remember it being there...
t is the problem of convergence setting or convergence IC.
Comment by ready2helpu, posted on Oct 21, 2008 IF THE PROBLEM OF CONVERGENCE SETTINGS then check out this link
http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
if the problem of convergence IC THEN check out this link
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
you can do it manually.
thanks.
Oct 21, 2008 | RCA R52WM24 52" HDTV Projection Television
Problem with Sony KP46WT500: Each line on the
These sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks Distorted/3D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - makes a chirping sound.
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking screen
  • White looking sceen
  • Halos around objects
  • Red/Orange looking
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 16, 2010 | Sony KP-46WT500 46" Rear Projection...
I have a red shadow in 3d on my sony kp46wt500
Convergence is dead.Replaced the 2 convergence ICS and some or all it resistors.U know how to solders?Tries websites Tv tv repiar world.com,Tvrepairkits.com to buy convergence kit to repair it self.The shop will cost U $300 for parts and labors.
Mar 01, 2010 | Sony KP-46WT500 46" Rear Projection...
Cannot adjust convergence on Mitsubishi RPTV
as long as there is no bowing in the picture and the color does not want to move then there is probably just a bad resistor on the convergence IC that controls the color alignment , thus the resistors would have to be tested to find the low valued resistor on the IC
Nov 28, 2008 | Mitsubishi WS-55809 55" Rear Projection...
Toshiba 40who8b convergeance problem
Good Day, harri1234;
Sounds like a convergence problem.
Convergence Output IC Failure
Corrective Action: Replace the defective Convergence Output IC Part Number 23905094 (STK392-110) using the revised “T” version IC Part Number 23135090 (STK392-110T). When Convergence Output failure is
detected, it’s recommended that both IC’s be changed to the “T” type IC
version.
Good Luck, Big Irish.
Jun 23, 2008 | Toshiba 42H81 42" Rear Projection...
Sony kp-53s35 bowed picture on top and bottom
Good day, scotty1980;
Scotty, welcome to 2008. Hold onto your wallet, the has a convergence problem. Which means that the TV's convergence IC's are more than likely bad. The average cost to repair is about $450.00. Unless you are electronically friendly, I would call an authorized service dealer for repair.
Good luck, big IRISH. PS; Hope this was helpful.
May 04, 2008 | Sony KP-53S35 53" Rear Projection...
RCA P52937SG Convergence
Convergence amp ic bad
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Sony Convergence
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
http://www.techlore.com/article/19631/Sony-Convergence-Procedure/
Jan 29, 2008 | RCA P52937 52" Rear Projection Television
Red convergence out of range.
Replace STK393-570 convergence IC. located on center PCB.
re-check alignment........T.
Oct 24, 2007 | Mitsubishi WT-42311 42" Rear Projection...
Horizontal bow and shadow
Replace convergence IC's--then re-check convergence alignment in servicer mode,if necessary.
Sep 27, 2007 | Philips 9P5544C 55" Rear Projection...
Sony KP-46WT500 46" Rear Projection HDTV-Ready Television Logo
276 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
