Question about Goodman Heating & Cooling
2 to goodman ac unit model a24-08
Outside unit runs but airhandler dont blog air u can here de frion runig i raplace capacitor thinking was de problen but was not what culd be tha prloblem
  • robertfiallo May 20, 2009
    thank's a lot u r good !!! that was the problem thank you !!!!!!!!
  • John Tripp
    John Tripp May 11, 2010
    So you say the fan blows air to house or not?
    Is the air coming off the fan outside warm. Have you checke the ductwork under the home has not come lose?
  • 3,361 Answers
Replace the fan relay switch in the airhandler(inside unit).
Posted on May 20, 2009
  • steve
    steve May 20, 2009
    Glad it worked out for you.
    Remember FIXYA' next time you have any problem at home.
We have a Goodman AC Unit and the pipe continues to freeze.
either the inside coil is dirty or system is overcharged.
May 14, 2014 | Goodman CLQ36AR49 Air Conditioner
Outside AC unit not blowing - Goodman dk-36-1d
1. check to make sure your 220volts is there at disconnect box.
2. check if you 24volts at contactor at the outside unit.
3. if you got it all check the capacitor.
Aug 05, 2012 | Goodman CKL36AR36 Air Conditioner
Airhandler in attic runs but blows little air
Hello, replace the capacitor to the motor, sound like it may be weak.
Jun 12, 2012 | Ruud Heating & Cooling
All the wires on the outside of my goodman airhandler
The wires on a Goodman Air Handler Red to R, blue or brown to c, yellow to y cool, green fan g, white to w heat
Dec 14, 2009 | Refrigerators
AC unit outside blowing out cold air, vents
Sounds like compressor not running. may be a bad capacitor, could also be low on freon.
Aug 30, 2009 | Goodman CLJ30AR32 Air Conditioner
I have a goodman furnace and ac unit the fan and heat work but every time i turn the ac on it blows the low voltage fuse ive replaced all low voltage wires to outside unit and thermostat i also replaced...
Look at the contactor on the condensing unit, remove the low voltage wires to the contactor and turn on the system. If the low voltage fuse doesn't blow, replace the contactor.
Jun 24, 2009 | Goodman CLQ36AR49 Air Conditioner
Goodman CKL60-1 Condenser Fan Runs OK, then stops
check connections tightness or if you just change the connector will solve the problem that is if the motor has not burn out yet
May 28, 2009 | Goodman CKL60AR60 Air Conditioner
Goodman CK60-1C model central AC unit blwing hot air
Clicking sound is the contactor engaging to start the outside unit. Check for a burnt off wire at the contactor. For some reason you are not getting power to the outside unit. If you find a burnt off wire shut off all power to it then remake the connection at the point of the circuit break.
Jun 26, 2008 | Goodman CKL60AR60 Air Conditioner
AC is on and blowing air. But not cool air. Outside unit is not working
It sounds like it is the exhaust fan motor and/or the start, run capacitor have gone bad. These units usually run 220volts so I will caution you to hire a technician.
Jun 17, 2008 | Goodman Heating & Cooling
Heating & Cooling Logo
293 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
