Question about Panasonic Nn-sn797s Countertop Microwave Inverter Oven
Will not start unless you slam the door - Panasonic Nn-sn797s Countertop Microwave Inverter Oven
Microwave will not operate unless I slam the door shut then program to cook.
of course it is , most likely needs a new door switch .
Oct 21, 2015 | Microwave Ovens
Door came off. Can it be repaired?
perhaps someone that welds could fix it . should have done something a year ago
Jun 11, 2015 | Panasonic NN-SD797S Microwave Oven
Intermittent starting. imer will count down and you can hear a clicking. sometimes if you bang the side or slam the door it may operate again. may be a bad switch 11 years old thanks
Nick,
Usual life span of a microwave is 7 to 10 years. Unless you are going to try to attempt a repair yourself, I would recommend getting a new microwave. You will at least then be covered by a new warranty as well.
Jun 03, 2015 | Amana ACM2160A Microwave Oven
Hi, My Bosch built in microwave won't start when I close the door unless I slam it. I suspect the switch. Think so? Can I get at ithe switch to replace without removing the whole unit from the
You will need to remove microwave to access casing, remove casing and check door micro-switch. The switch activator will need adjusting to enable door interlock to activate.
Sep 29, 2014 | Bosch 500 HMB5050 Microwave Oven
Microwave power off, but will flicker when door shuts
Please inspect the plastic latches that should actuate the door switches. Sounds like you may have broken one when slamming the door too hard
Mar 20, 2014 | Samsung SMH9151 Microwave Oven
You must close the door hard or it will not start
The locking mechanism is not closing completely unless you slam the door because the plastic parts don't slide easily after a couple of years. We found that putting a small amount of vegetable oil on the 2 locking hooks in the door will allow the components to slide easily and close properly so the machine will function correctly.
Mar 02, 2014 | Panasonic Microwave Ovens
My r-1874 microwave unit will not run unless a small wood handle is put under the door. This has worked in the past but now this little trick does not work. Any idea the part that not working properly
I would say the mount for your bottom or top door switch is loose, misaligned, or broken. And you may have a failed door as well. See my help file on door switches here.
Slamming the door and opening the door while it's cooking instead of hitting the "Stop" pad before opening it both contribute to door switch trouble.
The service manuals covering this model are here and here.
You can order Sharp parts from Encompass here or you can call them toll-free at 866-779-5835.
Feb 16, 2014 | Sharp R-1874 Convection/Microwave Oven
Have to Slam Door to get it to work - Advantium 120
This is usually caused by either a bad door switch, a loose door switch mount, or a problem on the control panel.
Even though a door switch clicks, it may still be bad inside.
This can be caused by slamming the door or by habitually opening the door while it's cooking without hitting the Stop pad first.
If you or a friend decide to look into it, we have critical information on safety, disassembly and door switches at our site, linked here on Fixya: http://tinyurl.com/yzjozk
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Nov 26, 2007 | GE Advantium SCA1000H Convection /...
Panasonic Nn-sn797s Countertop Microwave Inverter Oven Logo
59 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
