Immovable Cartridge & Printing problems
I have a Canon iP1000 printer that has the following problems:
a) When I open the door of the printer, the cartridge doesn't move.
b) When I try to print a test page, the following message is received "The waste ink absorber is full" and the "colour tank is running low". My black ink tank is full and I only want to print in black, so why am I unable to do so even though my colour tank is low? Also, how do solve the problem with the waste ink absorber?
  • wtm Oct 30, 2007
    i can see the waste tank but i dont see where i can soak up the waste ink..
    can you help?
  • ubfor2000 Jul 01, 2008
    When i try to print anything, my printer window show "your ink tank is running low". Nothing is printing from my printer.
  • 42 Answers
Try to remove the front cover of the printer is 2 screews or 3 and a few clips and whit a clean cloth absorb the waste ink from the waste tank, and this is o quik fix that i use.
Posted on Oct 18, 2007
  • push inside a pice of toilet paper whit a screwdrivwer and if is geting black is ok, reapeat the move until is no more waste ink.
    let me know that worcks
My canon ip1000 printer show error "print head not available". but head already fix in place
The print head may not be proper electrical connection. Remove the print head and clean the electrical contacts on the ink cartridge and in the printer with methylated spirits, replace the print head and hopefully this will fix the problem.
Feb 02, 2013 | Canon PIXMA iP1000
Service 5100
this problem caused by your cartridge cariage has problem to move
follow this step to fix
open printer door, the cartridge will move to the left
then close again
look at computer is the error still displayed
if yes
open printer door again, and gently move the cartridge cariage to the right, then move to the left again
and close the door
Mar 15, 2011 | Canon PIXMA iP1800 Printer
I have error 5100 pixma ip1000
Turn off printer.
Remove both the cartridges from the printer. Use a clothe moistened with alcohol to clean the surface contact on the cartridges where the terminals inside the printers touches.
Return the cartridges and turn on the printer.
Error 5100 means that the cartridge can not be detected by the printer.
Hope it helps!
Dec 21, 2010 | Canon PIXMA iP1000
My Canon Multipass F50 has a "check printer" error and won't print. The ink cartridges will not move when you open the door (as if to replace). It won't even turn off to cycle it to clear the error,
I had a similar problem. Go to this page http://www.fixyourownprinter.com/forums/inkjet/29693 and try the codes they suggest to reset the count for the waste tanks. Good luck.
Jun 01, 2009 | Canon MultiPASS F50 All-In-One InkJet...
Canon pixma ip1000 problem
you have to reset your printer
1. Unplug AC (and usb just for good measure)
2. Hold Start while plugging in...
3. While still holding Start press Resume twice.
4. This then allows for Removal of Ink Cartridges(if you are past the limit)... a very important step apparently.
5. Now repeat Step 1... Step 2
6. Now press the Resume 4 times (only blinks for 1st two presses !)
7. Should be ready...
Sep 26, 2008 | Office Equipment & Supplies
Canon pixma ip1000
I try this to my customer canon printer and it is working even i used only the step one method.
Here's the steps for reseting "Waste Ink Full" problem at iP1000
Step 1: Manual for Service mode (1st method)
1. Unplug POWER and USB cables.
2. Open door of the printer, PRESS and HOLD the POWER button.
3. Connect the POWER cable.
4. Close door, then release POWER button.
5. Power ON your printer a usual (It should not blinking anymore)
Step 1: Manual for Service mode (2nd method)
2. PRESS and HOLD the POWER button,
3. Release the the POWER button
4. Power ON your printer a usual (It should not blinking anymore)
Step 2 : Software for Permanant (1st method)
1. Reconnect the USB cable and turn ON your Printer
2. Open "General Tools for iP1000",
http://www.printersiam.com/data/download/iP1000%20Service%20Tool.zip
3. Select (USB PORT)
4. Choose (SET DESTINATION 1)
It should be reseted already, but somehow it start blinking again if you ever unpluging AC POWER cable. So try the 2nd method by using ServiceTool for IP1500
Step 2 : Software for Permanant (2nd method)
2. Open "General Tools for iP1500",
http://www.printersiam.com/data/download/iP1500%20Service%20Tool.zip
4. Choose CLEAR WASTE INK COUNTER - MAIN
5. Choose CLEAR WASTE INK COUNTER - PLATEN
It should be working, coz my printer now now work normally
Apr 23, 2008 | Canon PIXMA Photo Printer
Canon Problem
Well, you have to open the entire printer and reach out on that area to free the cartridge, it is caused by an obstruction on the gears of the head cleaner... remove that and have to wash it with water and then let it dry... place some grease to the gears so movement becomes smooth and last longer.
Keep me posted if you still have problems.
Hope this Fixya the problem.
Feb 04, 2008 | Canon PIXMA iP1600 Printer
Canon PIXMA iP1000
i need to install ip1000 to my computer and dont have the disc
Jan 31, 2008 | Canon PIXMA iP1600 Printer
Canaon pixma ip1000
i need driver for pixma ip1000
Sep 22, 2007 | Office Equipment & Supplies
216 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
