Schiller Welch Allyn Cardiovit At 2 Interpretive Ekg Machine
Problem for Schiller Welch Allyn Cardiovit At 2 Interpretive Ekg...
2001 audi a4 CEL came on
By badben360 on May 19, 2009
hello i have a problem with my 2001 audi a4 1.8t quattro ...my engine check light came on flashing and the car run really rough and engine shaking like 1 of the cylinder is misfiring,,,the strange part is sometime it stays on steady and the car runs fine...very strange i had 3 coils change but 1 i havent change yet. could that last coil i havent change causing this problem ,,,i borrow obd2 from friend had code reading a misfire on cylinder #4 ,o2 sensor,ignition module and thermostat sensor ....so which of this is causing the misfire or CEL coming on.. i do not want to go to the dealer to fix .dealer will clean me dry...please i need some advised on what i should do.
Solution #1
posted on Jun 25, 2009
Not Rated)
njineer
Rank: Guide
Rating: 75%, 1 votes
Flashing CEL with rough idle indicates a misfire. Most commonly, this is due to a coil going bad. First, erase the codes and try swapping the suspected bad coil with a good coil in another cylinder to see if the misfire (and code) follow the suspected bad coil. If yes, replace the suspected coil. The other codes are likely other problems. I believe that the 1.8t had issues with bad coolant temperature sensors, so that might cause some of the other codes and/or the stalling.
Was this helpful?
Yes
No
Popular Solutions for Schiller Welch Allyn Cardiovit
Questions and Unsolved Problems for Schiller Welch Allyn Cardiovit
Do you recommend Schiller Welch Allyn Cardiovit At 2 Interpretive Ekg Machine?
Answer
Answer
the printer stop when you request to print out and in auto mode print only seconds time
Answer
welch allyn schiller cardiovit at-2 type CH-6340 need information how to install the paper
Answer
hello there i have a problem with my 2001 audi a4 1.8t quattro ...my engine check light came on... (More)
Answer
Answer
I changed the type of electrode and this made it better for only 1 EKG. Why will the machine not... (More)
Describe your EKG / ECG Machines problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top EKG / ECG Machine Experts
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
