Question about Panasonic Lumix DMC-FX12 Digital Camera
PLEASE TURN OFF CAMERA THEN ON AGAIN????
When you capture more than twice, my camera says PLEASE TURN CAMERA OFF THEN ON AGAIN.
why is it like that?
what should i do?
it wasn't like that before.
I had the same problem...it's something to do with the lens not focusing properly. I hit it gently a bunch of times and now it works. But don't hit it too hard! Or it'll break.
Posted on May 22, 2009
Why do i have to click my shutter button twice before it takes the picture?
First click is to show focus and 2nd click is to capture. its common in most camera's. Nothing to worry about.
Sep 20, 2012 | FUJIFILM S3300 S3350 Digital Camera
On my 5800 xpressmusic the camera quality is not good. even i checked the quality on 5233 which has a 2MP camera...pictures are much clear than my phone.. please suggest
I have Nokia 5800 as well, but camera quality is good so far. Check your camera setting. Open Camera > Option > Setting > Click Photo quality > Drag the quality level to 3M - High > OK/Choose > Back to camera. Try to capture a picture and see if your problem get solved. And don't forget to click twice on capture button. First one is half push (like in digital camera) rather long until you get green box in the screen means the focus is ready, then push harder to take a picture.
Hope this help and if this helpful RATE please.
Feb 02, 2011 | Nokia 5800 XpressMusic Smartphone
After I take a photo my camera says it's "busy, please wait" for about 10 seconds. I bought and formatted a new SD 4 GB card and it stopped doing that, so I thought it was good. After about a week, it...
I was having the same problem and contacted Casio. The issue seems to be that there are pictures/video on your internal camera memory which is conflicting with the memory card. Here is the fix:
Turn of the camera and take out your memory card Turn on the camera, click menu, setup, hit the up circle twice and click reset and click reset again until the camera resets
Then click menu again, setup, hit the up circle twice and click format, click format again until the camera formats
(This will delete the pictures from your memory card so make sure you have them saved) Turn off the camera and put your memory card back in, turn the camera on again. Repeat the format process for your memory card and you will be good to go!
Nov 02, 2009 | Casio Exilim EX-S12 Digital Camera
SONY Digital Camera DSC-W50 doesn't work. Lens goes in and out...
Hi!
Please try the under given troubleshootings:
(i) Please check if the Battery is fully charged.
(ii) Next, turn off the Camera, remove the Battery pack then press and hold the Power button for 30 seconds.
(iii) Then, reinsert the Battery pack and turn ON the Camera.
(iv) Next, try to access the menu options either by directly pressing the menu buttons or while reviewing the images.
(v) If the menu options are accessible while reviewing the captured images then reset the Camera to the original factory settings.
Please follow the steps given below to reset the Camera to the original factory settings:
(a) Turn ON the Camera.
(b) Access the menu screen either by directly pressing the Menu button or pressing the menu button while reviewing the captured images.
(c) If menu screen is accessible, then press the right arrow on the Control button to select (Setup) Settings, then press the right arrow again.
(d) Next, select the Setup 1 option by using left/right/up/down arrow on the control button.
(e) Then, select Initialize and OK.
(f) Finally, follow the on-screen instructions to set the clock in the Camera.
Performing the above steps will reset the Camera to the original factory settings. If the issue persists even after performing all the above steps successfully then the issue is related to hardware malfunctioning and service is required.
Please feel free to contact for further information or any clarification.
Aug 21, 2009 | Sony Cyber-shot DSC-W50 Digital Camera
How do I transferre my videos onto my pc to record them on dvd
  1. Plug fire wire into computer.
  2. Plug fire wire into Camera. If camera does not have fire wire you will have to use usb cable instead off fire wire.
  3. Turn camera on set to VCR/Playback mode.
  4. Most cameras will be controlled by computer edit / capture software.
  5. Start editing / capture software.
  6. If camera is controlled by computer click to capture footage.
  7. If no control rewind fotage at camera start playback Then pause playback. Start capture in software then release pause on camera.
  8. Wait for end of footage Turn Camera off .
  9. Edit footage.
Feb 16, 2009 | Sony Handycam DCR-DVD108 DVD Camcorder
Canon SD1000 display is black while the camera in shot mode
After some inspecting of the camera it seen the issue lies with the lens, not the camera itself so don't go banging the camera up or you might damage some other part and the camera will be broken for real. Inside the lens is a closer which block the internal system from capturing image. The closer look just like the one you see before turning on your camera but it's smaller and it's inside the lens way in the far back. Look carefully and you'll see it - you will see the closer if your screen is black while in capture mode otherwise you will see a nice round glass (the internal lens for capturing image/video).
Think of if like this, imagine an eyeball with its eyelid close. That's what happened when the screen is black while in capturing mode.
HOW TO FIX IT: In order to fix the black screen while in capture mode and cost as little damage to your camera as possible, simply turn on the camera in either picture or video mode and look inside your lens, there should be a closer in the far back end. Gently hit the lens a few times until you don't see the closer no more and only a round glass and your camera should begins capturing image and video again.
Good luck to you all. And remember don't use anger to force your camera to works or you will regret it.
If you need further help, contact me via email y a j y e e (at) h o t m a i l (dot) com
Yee Yang
Canon PowerShot SD1000
May 13, 2008 | Canon PowerShot SD1000 Digital Camera
What do i do
If images cannot be downloaded from the camera to a Macintosh, check the status of the camera and the Macintosh and resolve the problem accordingly.
1) Check the status of the camera and Macintosh.
1. Connect your camera to the Macintosh and turn the camera on.
2. Open the "Applications" folder on the Macintosh HD.
3. Double-click "Image Capture".
* If the "Imaging device not connected" message appears, follow the steps described in [Checking the connection between the camera and PC].
4. Select "Preferences" from the "Image Capture" menu.
5. The procedure for using the Image Capture Preferences window differs depending on the OS version used. Use the correct procedure for your version of Mac OS.
- Mac OS 10.4: Click "General" in the Image Capture Preferences window.
- Mac OS 10.3: Click "Camera" in the Image Capture Preferences window.
- Mac OS 10.2: Simply proceed to the next step.
6. In "Items launched at camera connection", select "FPVBridge" and then click the [OK] button.
* If FPVBridge is not among the displayed items, follow the steps in [Displaying FPVBridge] below.
7. Quit "Image Capture".
If you implement the above procedure up to step 6, FinePix Viewer launches automatically.
* To stop FinePix Viewer from launching automatically, follow the steps in [FinePix Viewer Setup] below.
2) Resolving the problem
1. Plug the USB cable into the camera and Macintosh again.
* If you are using a USB hub, do not connect the camera to the Macintosh via the hub.
1. Select "Other".
2. Click the "Applications" folder.
3. Click the "FinePix Viewer" folder.
4. Select "FPVBridge" and click "Open".
5. Click [OK].
1. Launch FinePix Viewer.
2. Select "Automatic Save Settings" in the Settings menu.
3. Tick the "Auto save images when the camera is connected" checkbox in "Operation Settings When Camera Is Connected".
4. Click [OK] and close the "Automatic Save Settings" window.
5. Exit FinePix Viewer.
6. Turn the camera off and then on again to test whether FinePix Viewer launches automatically.
Apr 28, 2008 | Fuji FinePix S5700 Digital Camera
Anyone with this camera please read
FW upgrade is very easy: I have the same problem with the Display (after 8000 pictures) the LCD only works in Panoramic mode (or in remote capture mode when doing a remote capture from PC). In all other modes the camera LCD does not display anything. In order to upgrade the FW just connect the camera to your TV (using the cable that comes with the camera) The TV will the display the menu and you can do the FW upgrade. I upgraded the camera this way to FW 1.01 but unfortunatly the display problem still exists.
Aug 13, 2007 | Canon PowerShot A75 Digital Camera
Panasonic Lumix DMC-FX12 Digital Camera Logo
235 people viewed this question
Top Panasonic Cameras Experts
Computer Links
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
