Question about RCA HD52W59 HDTV Projection Television
RCA HD52W59 HDTV it keeps turning off. It will not let me change channels. When you try it turns off. You can go to menu. And Menu works. You can get it to a channel through the menu, but then it goes off and it starts at channel 1.(Which is a blank channel) It keeps turning off Plus the Power Butten seems to be hard to get to work Then you try the channel butten and it just turns off (And starts back at channel 1) Even when you go through menu and get a channel working, it turns off in a very few min and starts back at channel 1
  • autosafety May 19, 2009
    I just put a DVD Player on the frount hookups.
    It did the same thing. Played for a few seconds and then turned off
    then back on.
    and went right back to channel 1 (The blank channel)
  • autosafety May 27, 2009
    I went and got a Can of Air
    I blowed the dust out
    Now it will not come on at all
    And the Power Butten Blinks
    It Blinks 9 Times and then 5 Times
    Then 9 Times agan then 5 times agan
    over and over andf over agan
  • 184 Answers
SOURCE: MENU SCREEN POPS UP, TV CHANGES CHANNELS, TURNS SOUND DOWN
Yes. Its probably a stuck button on the TV's front panel. Try pushing or wiggling each button on the panel. It could be the channel up/down buttons or volume up/down, menu, etc.
When there is a button that is making slight contact, it keeps the microprocessor busy attending to the command its erroneously receiving from the offending button and may not allow other functions to work when this occurs.
It doesn't matter which button is stuck, any of the symptoms you describe can happen.
michtech
Posted on Feb 17, 2009
Slinteriors
  • 8617 Answers
SOURCE: Convergence menu not available on my RCA HDTV. Model R52WH74YX58
Itsalmost that simple, But you will need to replace the FL231, DL231 and CP230 and that should take care of your problem. You can get the replacement parts at the following link under their RCA Parts category. The total cost is around 13.00 and shipping is free and they even send detailed instructions with pictures that show how to do the repair which is very easy.
http://servicemanuals.vstore.ca/
Posted on May 28, 2009
rsweet598
  • 19 Answers
SOURCE: TV works for 5 min then shuts off and power light blinks green
check your sleep mode...
Posted on Jun 20, 2009
johnnydiode
  • 647 Answers
SOURCE: TV RCA HD52W59 NO VIDEO
Sound like convergence supply problem (small fuse near flyback will be open.
Posted on Sep 19, 2009
tlm931
  • 273 Answers
SOURCE: RCA D52W23 HDTV; WHEN WE TURN T.V. ON THE GREEN
most likely its the smsp /deflection board for the shut down
there are some caps in the power supply cp 140 cp120 cp114 look at them and see if there puffed up
they will need to be replaced
this could also be a flyback transformer that has failed or a ribbon connector
this where you will have to look for caps first the trouble shoot through it
then you you can addresse the cmp1 issue but id guess thats the ribbon connector causing that one
Posted on Nov 11, 2009
My rca hdtv model hd52w67 has picture but no sound
The model indicated rarely has sound problems.
General things to check:
If using a cable or sat box is sound muted or turned way down?
In set menu are speakers on or off?
Some versions have a slide switch either on the back or in the menu for internal or external speakers.
Does the set have sound with a DVD etc hooked to a rear input?
If no sound only on a few channels SAP may be on either in the set or a box.
If none of these help it has a audio circuit problem.
Mar 28, 2012 | RCA HD52W59 HDTV Projection Television
When I'm watching tv start changing channel and the tv menu start pop up.
Thats a very common problem which is usually caused by the small signal board. You can get a replacement small signal board from www.tvrepairworld.com
Nov 08, 2010 | RCA HD52W59 HDTV Projection Television
I can get a picture , but no sound on the TV . What am I doing wrong?
Many RCA TV sound problems are caused by SAP function being activated by TV station equipment that converts Analog TV signals to HD signals. Accidental pressing of the wrong buttons on your remote can also cause this problem.
The incorrect conversions causes the Audio settings to be changed from Stereo to SAP by the received signal.
Solution is to go to Audio set-up in customer menu and change settings from SAP to Stereo. If you find that settings are wrong, change them to "Stereo". Do channel scan if you are using the TV tuner/remote to select channels. Turn off the TV and unplug for 60 seconds. Check the settings again and reset if required.
This problem may re-occur when you select the VHF channel, satellite channel or cable box channel that is causing the problem. It is not a TV fault that can be repaired. The problem is caused by the incorrect incoming signal.
SAP is Second Audio Program, used for second language transmissions.
Second cause may be that the speakers have been turned off in the audio set-up menu.
easyab
Apr 22, 2010 | RCA HD52W59 HDTV Projection Television
How do I access the Factory or service menu?
while the TV is on, turn it off for 10 seconds, after 10 seconds hold the vol down and channel down buttons on the front of the set for approx 10 seconds until set turns on. The service menu will be displayed
Feb 07, 2010 | RCA HD52W59 HDTV Projection Television
Sep 17, 2009 | RCA HD52W59 HDTV Projection Television
I HAVE A RCA HDTV SCENIEM AND IT DOES NOT HAVE A PICTURE OR SOUND TURN IT ON AND THE LIGHT LITES BUT THATS IT CAN YOU HELP
try changeing the input selector if you have a dvd player put it in turn it on and play it then run threw the menu also make sure you have not changed the channles it recives the signal on like 3 or 4
Jun 27, 2009 | RCA HD52W59 HDTV Projection Television
Menu comes on, but tv wont display any video source.
If you hook up jacks on back for video 1 then turn tv aux to video1, Ask them do they still have owners mannel it tells you how to hook up vcr-dvds stereos
Dec 18, 2008 | RCA HD52W59 HDTV Projection Television
CHANNEL CHANGES BY ITSELF
The remote may be malfunctioning. Take the batteries out of the remote and see if the problem stops.
Aug 02, 2008 | RCA HD52W59 HDTV Projection Television
Menu rca hd52w59
i have seen this problem at the shop. a few times the front panel has become damaged. replaceing this has resolved it for me
Apr 04, 2008 | RCA HD52W59 HDTV Projection Television
RCA HD52W59 HDTV Projection Television Logo
347 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
