Question about Archos ARNOVA 10 Android Tablet
Rca tablet says no command
When powered on it comes up no command and I have tried the options that come up and I tried those and none of them work
Just recieved a rca maven tablet. touch screen option worked fora day. now touchscreen option inop
It may be just locked up. Hold the power button until it shuts down, restart it and see if it works. If this doesn't work, return to place of purchase, you have only had it for 1 day.
Jan 28, 2017 | Tablets & eReaders
Reset rca tabl
1. Make sure that the tablet is actually powered off.
2. Press the "Power" and the "Volume Up" buttons, together, until you see the start-up logo on the screen.
3. Once you can see the logo, release the buttons and allow the device to enter the "System Recovery Mode".
4. Next use "Volume Down" button to get to the "wipe data/factory reset" option When in recovery mode the "Volume Up" and "Volume Down" buttons are how to can navigate and highlight what option you need.
5. Once you have selected the "wipe data/factory reset", press the "Power" button to select that option.
6. On the following screen, repeatedly press the "Volume Down" button until the "Yes - delete all user data" option is what is selected.
7. Then press the "Power" button to hard reset the tablet.
Jan 18, 2017 | Tablets & eReaders
If I reset my RCA tablet with a paperclip will I lose everything on it
try holding the volume up button and then power it on ( keeping the volume up button pressed in ) if you get a menu just click restart tablet. you will loose everything if you reset with pin but some tablets have a hard reboot option like i described but it wont delete anything
May 30, 2015 | Tablets & eReaders
I lost sound in my RCA 7
remove the mute with the buttons or with the touch on the volume control slide
Mar 10, 2015 | RCA CA 7" Tablet with 4GB eory 28458515
Model # rct6378w2 ... an rca tablet ... i cannot get it to function, i keep getting a "no command" message. I have already done a factory reset, it didn't work...help!
Have you tried this? http://rcatablets.com/sites/default/files/Tablet%20recovery%20mode%20to%20wipe%20data%20Android%204.1.pdf
Jun 18, 2014 | Tablets & eReaders
I turn on my RCA tablet and stay on the logo
This is the most common problem with tablets - its usually corrupt bootloader or OS and can be a nightmare to repair.
Sounds like its borked.
Have you pressed the reset button on the back - pinhole - press it with a pin its a long shot.
The real fix is to go into recovery mode using the power button volume up combo. Then select the restore tablet option.
If none of that works you will have to sideload or reinstall using an sdcard a replacement OS - Try cyanogenmod - your tablet will have to be rooted and have the cm bootloader installed however - tablets are not easy things to repair when the software goes belly up. Its actually a disgrace and I have been repairing computers and latterly tablets for the last 30 years and it is by far the most common issue with any tablet except Apple - there is a reason they are so expensive - lol
May 09, 2014 | Tablets & eReaders
RCA 7 inch table says no command
You may have to reset it. let if charge for about 24hrs, 10hrs may work fine too and With the device turned off, press and hold the volume down button, and then briefly press the power button. - Wait for the screen with the three Android images to appear, and then release the volume down button. - Press volume down to select clear storage, and then press power. - Press volume up to start the factory reset.
Mar 03, 2014 | RCA 7 DUAL TABLET DVD SYSTEM
How to unlock rca tablet
just make a factory data reset
To reset you tablet manually. you have to
1)switch of your tablet
2)hold volume down button and power button at the same time.
3)wait for 10 sec and you will enter into boot menu.
4)there in the boot menu you will find option named Reset factory default settings/reset user data. select that option
5) wait for resetting......
6)cheers your done.
Mar 01, 2014 | Tablets & eReaders
Archos ARNOVA 10 Android Tablet Logo
413 people viewed this question
Top Archos Tablets & eReaders Experts
Joseph Prosser
Kazim ERGUNEY
Kazim ERGUNEY
Are you an Archos Tablet and eReader Expert? Answer questions, earn points and help others
