Question about Bob Mackie Mackie Control Extender Pro PC Desktop
Mackie Control LCD brightness - Bob Mackie Mackie Control Extender Pro PC Desktop
How can I decrease brightness and contrast?
To help you change the brightness and contrast settings from the LCD monitor, please follow the instructions mentioned below,
The control buttons are located at front panel of the monitor. The Brightness Button is used to select the Brightness/Contrast adjust functions. Press to switch functions or adjust settings.
To decrease the brightness or contrast press (-) button & to increase (+) as per your adjustment.
GuruAid.com
Mar 29, 2016 | Dell E173FP 17" LCD Monitor
Fix p+g faders on mackie control
You might call mackie for a suggestion at 800-258-6883. Sometimes there may be older parts in stock at other Mackie distributers around the world. Here's a list of contact info Mackie International Distributors It doesn't hurt to ask and email is free!
I had good luck getting parts for various musical electronics out of Canada
Feb 01, 2015 | Mackie Music
How can I reset Emagic logic control to factory default firmware 1.0?
I don't know if this will help, but I dug up the pdf for you. according to the pdf:
Rebuilding Defaults
The Options > Control Surfaces > Rebuild Defaults menu
option rebuilds the factory default settings for all connected
Logic Control unit(s). This is required if the internal assign-
ment table has been changed.
http://stash.reaper.fm/2063/LogicControl_EN.pdf
May 01, 2014 | Bob Mackie Mackie Control Extender Pro PC...
Hi. I have a Mackie onyx 1640i. 2 days ago it was working, but now the computer sees only 2 output channels. There was no shock, etc... Thx
Check the settings in your computer in the control panel "sounds and devices" under the "Voice" and "Audio" tabs. Check that all are set to the Mackie instead of the computers default input.
Jun 08, 2011 | Mackie Onyx 1640i Mixer
I have a Mackie D8b hooked up to an HDR 24/96.... Everything works except the Jog Wheel and the locator buttons on the console... They just flash when you press play.and will not communicate with the cpu....
Do I need to upgrade my Mackie or Logic Control?
A.
Perhaps, but perhaps not. Really, it all boils down to what you are doing or plan to do with your Mackie Control or Logic Control. First, determine the Firmware Version of each of your units (main units AND extenders) - simply watch the display when you power up.
If you have a version 1.x Mackie or Logic Control (including extenders), there is a free MIDI download which will allow you to control all of the Mackie Control supporting DAWs AND Emagic Logic Audio.
If you have a version 1.x Mackie or Logic Control (including extenders) and wish to control Pro Tools via Mackie Control Universal's built-in HUI mode - you'll need to obtain a Mackie Control Universal Upgrade Kit.
If you have a version 2.0 Mackie Control or extender, we have a free MIDI download which will allow you to control all of the Mackie Control supporting DAWs, Emagic Logic Audio and Pro Tools.
If you have version 2.1.1 - you're already up to date.
Free for all existing Mackie Control, Logic Control, and MC or LC Extender owners, this download will update your control surface to have both Mackie Control and Emagic Logic Audio functionality. HUI support for Pro Tools is not included in this download. Instructions for updating your unit(s) are included as a Read Me file in the downloadable zip archive. 1. If you own a Mackie Control or XT with firmware version 1.x and you want to add Logic Control Functionality, download this free MIDI upgrade.
Mackie Control v1.2 (ZIP 13KB)
This upgrade is for those Mackie Control, Logic Control, and MC or LC Extender owners who want to update their control surface to the full three-mode Mackie Control Universal - getting HUI mode for Pro Tools along with the Mackie Control and Logic Control modes. 1. If you own a Mackie Control with firmware version 2.x and you want get all three modes: Logic Control Functionality, Mackie Control Functionality, and HUI Mode for controlling Pro Tools, download this free MIDI upgrade. Instructions for updating your unit(s) are included as a PDF file in the downloadable zip archive.
Mackie Control Universal v2.1.2 (ZIP 21 KB)
Note: the 2.1.2 firmware upgrade is new as of August 20, 2004.
  • Fixes Bug in Logic Control mode that caused lock-out of control surface on termination of software application
How do I upgrade my Mackie Control, Logic Control or Extender?
A. First, make sure that you DO need to upgrade (refer to the previous FAQ). Once you've determined that you need to upgrade your unit, you'll need to reserve an upgrade kit. Reserve your kit here.
Because there is limited supply of the upgrade kits, we are taking reservations. Once your upgrade kit becomes available, we will send you an email with instructions on how to obtain your kit. You will have 72 hours to respond before we release your kit to the next person in line.
The Mackie Control Universal Upgrade Kit includes a new processor chip, a Pro Tools Lexan overlay and installation instructions. You can either perform the upgrade yourself, or have a professional from the Mackie Service department perform the upgrade for you. You can also choose to have a third-party service technician perform the upgrade for you at your own risk.
Dec 12, 2010 | Computers & Internet
Acermointors color is to bright
try to adjust front panel button, for the brightness control + - sign, if not function the problem is the lcd ckt. and need service.
Mar 25, 2010 | Acer 22" X223w LCD Monitor
Hooking up powerd monitors to a Mackie 1604 VLZ3
Are you sending the main mix to the monitors or are you giving them their own mix? What about using the sub groups, use 1 for your monitor send.
Apr 04, 2009 | Mackie 1604 Vlz3 16 Channel Mixer
Mackie control universal
hello there
You can go to Ebay.com and type in power supply and they will put up a list 4 you and you can get one there. make sure you get the same one as you got and the same volts. it will tell you on your power supply what you have. good luck anymore question let me know.
best regards Richard
Feb 06, 2009 | Bob Mackie Mackie Control Extender Pro PC...
LCD monitor
Yes, you can control the monitor brightness up to +/- 7 steps.
Sep 04, 2005 | Olympus EVOLT E-300 Digital Camera
Bob Mackie Mackie Control Extender Pro PC Desktop Logo
398 people viewed this question
Top Bob Mackie Computers & Internet Experts
David Payne
David Payne
Are you a Bob Mackie Computer and Internet Expert? Answer questions, earn points and help others
