Dometic NDR 1062 Refrigerator
Problem for Dometic NDR 1062 Refrigerator
Dometic refrig,curcuit boards
By candypoke211 on May 19, 2009
hi i keep burning up curcuit boards about every 2-3 years,the last one has fuses in board,it blows fuses when you plug in ac power cord,like a dead short,even on bench test,when its not hooked to rerfig,its a demotin rm1303 refrig,thanks don
Solution #1
posted on May 19, 2009
Not Rated)
Jerico1234
Rank: Master
Rating: 91%, 8 votes
thats normally a problem of either parts wear and tear or spiking in the the AC line ... if something like a water pump or something that turns on and then off suddenly is on the same line as the refridgerator it can cause such a problem also if the wires in the wall outlet or panel box have begun to run slack it can cause such problems as well ....
Was this helpful?
Yes
No
Popular Solutions for Dometic NDR 1062 Refrigerator
Questions and Unsolved Problems for Dometic NDR 1062 Refrigerator
Do you recommend Dometic NDR 1062 Refrigerator?
Answer
Answer
Am attempting to calculate my power requirements while boondocking with my trailer. Can anyone tell... (More)
Answer
I have Dometic 1062 Refrigerator/Freezer, The Cooling Unit will Cool if I install a jumper to the... (More)
Answer
two questions Dometic NDR1062 is there a heating element for the frig cooling fins, they have been... (More)
Answer
unit not cooling checked and amonia leak outside
Answer
set at auto, gas off and the propane check light comes on, unit won't cool. i turned the propane on... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Dometic NDR 1062 Refrigerator:
Top Refrigerator Experts
Rank: Guru Guru
Solutions: 1220
Experience: installed and repaired audio/video equipment for over 23 years at 2 colleges and 3 businesses.
Ask Me
Find more Refrigerator Experts
Top Refrigerator Repair
(423) 303-3782
Refrigerator parts delivered overnight nationwide....
 Appliance Parts Pros.com
(619) 564-4488
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
