Projector isonic hd9100
How do I select input for HD 9100?
I connected my dvd player to my coby hd tv, and the movie still want play, maybe I have it on the wrong chanel. What chanel should the hd tv be on?
Are you using a HDMI cable? Push the SOURCE button & select the corresponding HDMI input with the HDMI input from your DVD player. The HDMI inputs on the tv should be numbered & you can then select the correct number HDMI on the source screen. Good luck.
Sep 02, 2013 | CobyElectronics Coby Electronics Coby...
How do u put tv on hd input
If this model has that it will be one of the rear sets of component jacks which will be marked as HD or 1080-----use the input button on the remote or the set if there to change to the correct input on the set. Hookup and select correct input.
Dec 03, 2012 | JVC AV-32S575 32" TV
47" vizio has sound no
Have you selected the proper input for how you have it configured? If using an HD connection, select the HDMI 1 input. If you are using the coaxial cable connection, then select TV input. If you are using the three RCA inputs (yellow, red, white) then select AV input.
Mar 01, 2011 | Vizio VO47L 47 in. LCD TV
How do i unlock inputs 1 2 and 3?
As soon as TV detects signal on input 1, 2 or 3 it will make an input selectable. Supply signal first then select an INPUT. In other words, something has to be hooked up to those inputs before you can select them.
Jan 05, 2010 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
I have an Olivetti HD 9100 calculator. The paper
My texas instruments TI-83 has a dark scrren i can barley see the numbers what is wrong with it?
Aug 06, 2009 | Olivetti Office Equipment & Supplies
TECRA 9100 LED FLASHING 01001110
What a work..... sry --
Find another Tecra 9100 and use that machine for spare parts.
They are very cheap today, 100 euro max second hand, perhaps without HD.
Its the system-board, a chip there.
Mar 20, 2009 | Toshiba Tecra 9100 Notebook
Never hooked up the HD
Have you tried selecting a different input( do you have the remote?), if so have you set your input to accept HD input ( you access this thru your 'Menu" button on your remote). I run my HD input from my game console (X-Box 360) and have to select HDTV input channel (there are 2 of them along with 2 cable inputs), and have not had a problem with this at all. good luck.
Mar 18, 2009 | Mitsubishi WS-55805 55" Rear Projection...
Toshiba Tecra 9100 won't boot or run
Did you remember to change the 1st boot device back to the hard drive after reinstalling the system disks?
Oct 05, 2008 | Computers & Internet
117 people viewed this question
 Grubhead
Grubhead
