Question about Samsung LN37B530 37 in. LCD TV
Ln37b530p7 master reset
TV keeps cycling on its own from no signal, to PV, to AV, to HDMI, to fuzzy screen
2 Suggested Answers
  • 12962 Answers
SOURCE: Samsung LED TV UN60EH6000 HDMI ports fail to recognize any signal and by this I mean the TV gives me an error message on screen that says no signal detected-check connections.
Sounds like a main board issue.
Posted on Jan 03, 2017
Testimonial: "Thanks for the quick response richie46! Could you elaborate on your troubleshooting logic? Trying to justify buying a replacement board."
Helppppp
change your tv mode av plug in or if you are using an HDMI connection then change to HDMI mode
Jun 05, 2013 | Video Game Consoles & Games
Plugged in hdmi from console to tv .went back to original cables [no signal] only works hdmi
try to reset it ..or ..open it 's settings ..using the hdmi cable ..and select the other one and restart ..after that plug the one you want to use and will work ...resetting it to the original factory settings will work too ..but will make you loose user data ..and such ..
http://www.tech-recipes.com/rx/2265/ps3_how_to_factory_hard_reset/
here is the video resetting and it will work too ..this way you will avoid the hard reset and loosing data ..
http://www.portfolioofpb.com/blog/ps3-blank-screen-switch-inputs-hdmi-to-composite-to-hdmi
You basically shut it down ..than when you power it up ..keep the power button pressed until you hear the second beep ..This was the signal telling you the video settings are reset . and it will work with the AV cables..
Aug 03, 2011 | Sony Playstation 3 (PS3) Console
Sony VPL-HS10 Please check Digital signal sel.
your projector might not be able to take this resolution
Jan 30, 2010 | Sony VPL HS10 Multimedia Projector
Green purple and blue bars rolling through screen
It is probably the main total assy needs to be replaced.
Jun 26, 2009 | Samsung LN32A550 32 in. LCD TV
No signal on my TV
try connecting the ps3 to the HDMI only, now when the ps3 is off and all but the single red light is on rest your finger on the on button for about 8 seconds, as soon as you touch it it will turn on but just wait a bit and you'll here the a second beep- this should reset your ps3's video output settings. Try it out, it works for me when i go back and forth from av to HDMI.
Please remember to rate my response if helpful.
May 30, 2009 | Sony Playstation 3 (PS3) Console
Av connections not giving signal to tv
you have to manually change the output in the settings menu back to ANALOG Using an HDMI TV or monitor 1st, when you select RCA, or AV output and restart, it will work, but when you switch back, you have to change it (back to HDMI output) on the analog monitor, or use analog TV inputs, then reboot PS3 and connect HDMI.
I do not know why Sony did not make this switch automatic and self scanning on boot, but alas I have had the same issue, so I know this is your problem, not the AV cables.
Please give a fixya rating if you find this solves your problem, Thanks for the question
Apr 12, 2009 | Sony Playstation 3 (PS3) Console
Reset HDMI on non HDMI tv
Put The HDMI Into your old tv then switch it to AV MULTI then put the av in then it will ask if you want to keep these setings then select yes and then put the AV MULTI into your new TV.
Mar 21, 2009 | Sony Playstation 3 (PS3) Console
If I tap the rca jacks in the back the screen gets distorted
You need a hdmi connector from your tv source to the TV. RCA connectors don't have the capability for HD signal transmission. You can use them for a connection but the picture will be fuzzy if trying to watch HD signal. Check your cable/dish box to see if there is a hdmi output. If so, buy a hdmi cable & that should solve your problems.
Mar 19, 2009 | Akai LCT4216 42 in. LCD Television
No HDMI signal
The Dvd player is not sending a High Definition signal,You may be able to change the output to high definition.
Please rate this a fixya
Feb 01, 2009 | Televison & Video
Samsung LN37B530 37 in. LCD TV Logo
66 people viewed this question
Jerry Greenberg
Jerry Greenberg
