Question about White Rodgers White-Rodgers 1F85RF-275 Thermostat and Wireless Remote Sensor Kit
White-Rodgers 1E78-151 thermostat is stuck at 85 degrees & buttons (run, temperature, reset option, etc) don't work. Batteries have been replaced.
liteswink
  • 99 Answers
SOURCE: No Heat with new White Rodgers 1f85rf-275 Thermostat
The only way to resolve this problem and to distingush if its a thermostat issue on the system is to by pass the thermostat by putting a jumper between the hotwire and the heating wire if the system did run which happen most of the time. Call the HVAC technician to check your heating unit. Or call the White- Rodgers technical line at 18887259797 choose contrator division.
Posted on Oct 20, 2009
szanti
  • 36 Answers
SOURCE: How do I delete the program settings on my
Go to this web site.
Please let me know if this helped.
http://www.emersonclimate.com/Documents/White-Rodgers/0037-6175.pdf
Posted on Dec 06, 2009
liteswink
  • 99 Answers
SOURCE: white-rodgers 1c26-101 owners manual, does anyone
Link: Installation Instruction
Posted on Apr 07, 2010
liteswink
  • 99 Answers
SOURCE: Keeps going to 62 like it's on a program
You need to manually operate the thermostat by using the hold button. You did not specify the model number but try this procedure:
MANUAL OPERATION
• HOLD TEMPERATURE — With the SYSTEM switch set toHEAT or COOL, momentarily press HOLD button. HOLD will be displayed. Use UP or DOWN to adjust the temperature.The thermostat will hold the room temperature at theselected setting until you press RUN button to return to program operation.
If you need further clarification please cal hometechline 18002842925. I hope this will help you a lot...
liteswink
  • 99 Answers
SOURCE: We have the white and rodgers thermostat model
Set System Switch to Cool and lower setpoint below room temperature.
Verify thermostat and system wires are securely attached.
Diagonistic: Set System Switch to Cool and lower the setpoint below the room temperature. Within a few seconds the thermostat should make a soft click sound. This sound usually indicates the thermostat is operating properly. If the thermostat does not click, try the reset operation ( . If the thermostat does not click after being reset contact your heating and cooling service person or place of purchase for a replacement. If the thermostat clicks, contact the furnace manufacturer or a service person to verify the heating system is operating correctly.
Reset the thermostat by pressing , UP,DOWN and TIME at the same time.
Posted on Jun 28, 2010
The white-rodgers 1f78-144 does not work properly
Is it in the heat or cooling mode? Might try a new set of batteries.
Jan 22, 2014 | WHITE-RODGERS DIV 1f78-144 Digital...
My thermostat resets itself
BE absolutely sure the batteries are good. This is what usually causes this symptom, even it the 'battery indicator' isn't asking for a new battery. It happens a lot on systems that are being turned off with the breaker, safety or service switch; DON'T do that. When you put a set of brand new alkaline or lithium batteries, with the thermostat off the wall, leave NO batteries in it for about an hour. Be sure that the power is on 24/7 to the system. To stop the system from running, always use the "Heat--Off--Cool" switch.
Nov 02, 2017 | White Rodgers White-Rodgers 1F85RF-275...
I have a White Rodgers thermostat series 1F78-151 that is displaying we at the top?
Hi. This is Aaron Moratalla from White Rodgers. For 1F78-151, "WE" means Wednesday. If left side temperature is stuck at 67F and there's no Hot air coming out then try ressting your thermostat by:
1. set system to Heat mode
2. press simultaneously the Up, Down arrows and Time button for 2sec.
3. the screen should blank out momentarily then show 62F in the right side.
4. set a higher temperature in the right side than the left side of LCD to have a call for heat.
If you are still having problems please don't hesitate to call our Tech Support line at 800-284-2925. Thank you for choosing White Rodgers!
Jan 24, 2013 | White Rodgers White-Rodgers 1F85RF-275...
I have a 1F81-51 White-Rodgers thermostat that keeps resetting itself back to the factory default settings. I've chnaged the batteries, but it continues to automatically reset itself after I have...
I had the exact same problem. Even pressing the Hold button does not really help, because once it resets - the Hold temperature also changes to the default.
I fixed this by replacing the 470 micro-Farad / 10v capacitor in the unit (it's the grey-colored capacitor). To access the back of the circuit board, you will need to break 2 plastic rivets holding the front of the unit to the base.
After replacing the capacitor I've not had any resets for the past 3 days (it used to reset itself every couple of hours).
Hope this helps.
Noel
Aug 21, 2010 | White Rodgers White-Rodgers 1F85RF-275...
Please assit with White Rogers Thermostat Manual 1FS97-374. Why Check STAT comes? Thank you, Kumar
The display will indicate CHECK STAT if one of the following occurs.
• One of the buttons is stuck down or in. Check buttons, make sure nothing is pushing them in.
• The thermostat sensor is not functioning. If using a remote sensor, check connections, wiring and power.
• The humidity sensor is not functioning.
After checking the above, press PROGRAM RUN to reset the display. If this does not clear the display, disconnect power and remove the batteries for five minutes.If these checks fail to solve the problem, the thermostat should be replaced.
Jul 27, 2010 | White Rodgers White-Rodgers 1F85RF-275...
Thermostat resets itself to 85 degrees a couple hours after I set it to 74 degrees
To manually operate the thermostat set the system to cool and fan to auto then press the HOLD button one time then release, you will see the hold word on the screen after that up the UP or DOWN arrows is setting the desired temperature.
Jul 22, 2010 | White Rodgers White-Rodgers 1F85RF-275...
We have the white and rodgers thermostat model 1F81-261. The problem is that the ac unit will not work. We have reset and changed the batteries and set the point 4 degrees less than the actual room...
Jun 28, 2010 | White Rodgers White-Rodgers 1F85RF-275...
My white-rogers 1F81-261 model thermostat keeps rgoing back to a 62 degree setting after the furnace kicks on at a setting of 72 degrees. I have reset the program, but that doesen't seem to help. What can...
MANUAL OPERATION
program operation.
This is on page 6 of the manual
Feb 06, 2010 | White Rodgers White-Rodgers 1F85RF-275...
MANUAL OPERATION
Oct 29, 2009 | White Rodgers White-Rodgers 1F85RF-275...
White Rodgers White-Rodgers 1F85RF-275 Thermostat and Wireless Remote Sensor Kit Logo
308 people viewed this question
Top White Rodgers Home Security Experts
Nicholas Bannister
Tom Chichester
Heatmeister99
Level 1 Expert
Are you a White Rodgers Home Security Expert? Answer questions, earn points and help others
