Question about Camping, Backpacking & Hiking
Kobalt 0498288 charge light not coming on when plugged in
Charge light not coming on when plugged in to charge
I turn on my razor E300 the lights comes on to say its on but dont work i plug my charger in and on the chager the green light comes on saying its full charged what could b the prblem ?
The green light will come on if the charger does not sense a low battery. In other words, if you plug it into the wall, and not the scooter, it will still show the green light. It will only show a low charge (and charge the battery) if it is completely connected completing the circuit. My guess is that the battery is dead, and the plug is not all the way connected. Also, I believe the scooter has to be turned off to charge.
Oct 18, 2014 | Razor E300 Scooter
Bon-Ton Greene Gray Portable Battery Backup for I Phone 4S Won't take a full Charge? Or Charge Phone
I can't see that anyone has commented so far :-(
Sounds like a dud battery, and if new should be returned. It would help if you can borrow a voltmeter and test that both the charger and the battery show a voltage. [a local electrics shop may help there]
Feb 10, 2014 | Bon-Ton Computers & Internet
My coolpix L810 won't turn on. Green light comes on but goes out. Can't see screen. Lense was frozen but plugged into computer and closed.
have the battery full charge? sometime the battery is not charged although the charging indicator is full charge, maybe the battery is shorted out.
May 04, 2013 | Nikon COOLPIX L810
PLEASE HELP!! I am going on a business trip tomorrow and ALL of my requisite files are on my Dell Latitude D610 that won't power on. PROBLEM: once I removed it from my docking station at work, it won't...
When you say you "tried turning it on with the battery removed", did you leave it plugged into the wall with the charging adapter at the time? Please clarify that you tried to use it while plugged in without the battery and it would not power up? When you plugged it in without the battery, was the green charging light on? Or did you get no power light at all?
With your battery in, try using a different outlet to plug into. Plug it into another outlet and when the green charging light comes on press and hold your power button on your keyboard and do not release it for 30 to 45 seconds. Tell me if this boots up the pc even if just for a moment?
There are three lights on your keyboard that should come on when the laptop is plugged in and turned on. One is the power light, the other is the battery charging light and the last one is the hard drive indicator that looks like a round cylinder on the picture. Tell me when you plug it into the outlet and the battery charge light is on, does the hard drive light come on and/or flicker when you try to power up the laptop? How many lights come on when you press and hold down the power button with the cord plugged into the wall?
Jan 09, 2011 | Dell Latitude D610 Notebook
When charging my jazzy, do I unplug any plugs that controls my jazzy, or leave all plugged in? the reaon ask, green light will not come on the charger, which is onboard charger, unless I unplug controller...
No JJR all the plugs need to remain plugged in. On the Pride chairs the light on the charger will only come on green when the batteries are fully charged. When you unplug the controller the charger thinks the batteries are fully charged and the light comes on. Now the problem is the batteries. If they are old or you have a bad battery then the charger never senses a full charge so no green light. Hope this helps
Aug 26, 2010 | Pride Jazzy Select 6 Indoor Power...
I have A vivicam 8025 I plugged into my pc A red light came on the camera is it now charging? it will not turn on while plugged in. If it is charging how long till its done charging?
Yes, the red light indicates that the battery is charging. The light will go out when the battery is fully charged. The time depends on how drained the battery was before charging, and also on the current coming from the computer.
Jul 03, 2010 | Vivitar ViviCam 8025 Digital Camera
I charged for 2 hours and when I hold for 11
Make sure the wall socket you plugged in is working. You may need to turn on a light switch, etc. The light should come on when you plug it in and go off when it's done charging. Try charging longer. Leave it plugged in overnight and try again.
Aug 03, 2009 | Motorola Mobility H500 Wireless Headset
Camping, Backpacking & Hiking Logo
129 people viewed this question
Top Camping, Backpacking & Hiking Experts
Tom Chichester
ray gallant
Are you a Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
