Question about Adreno Graphics Neocore
Can I remove screen shot widget from home screen on Neocoren 10.1
I want to remove widget (clock) from the home screen so the picture is not obscured.
just touch the widget for few seconds...then on upper right or left side u will see the remove written on the screen.....now move that widget to that place and u will see no more widget over there.
Aug 19, 2015 | Cell Phones
How do I take useless widgets off of my home screen?
If your LG is running Android, just long tap any widget, and without letting go, drag it to the top of the screen where you should see an X. This X means "remove".
Oct 18, 2014 | LG Vu CU920 Cellular Phone
Widget Removal
Hi if you want delete anything from your home screen press and hold it for few seconds and you should see depends from your os bin or remove sign at the top or bottom of screen then drag it there and it's done.
Apr 14, 2014 | LG Xpression MobiPhone - Red at&t
Blinkfeed is hard to customize and would be better as a widget I could access so it doesn't take up my limited number of five screens. Can anyone help me remove BlinkFeed from my screen options?
With my phone I think blinkfeed is annoying. I just held the screen and opened the widget tab, put the home page as a blank page, put the clock widget and then added my own icons and widgets and such. Put blinkfeed far away to the left. works better for me looks more like my htc one x
Nov 07, 2013 | HTC One
HOW CAN I REMOVE WIDGET FROM MY SAMSUNG GT C6712 ON SCREEN
I think the Widget in the Home screen is in-built.
Just click the widgets button, you can see the bottom, available widgets appears... just drag and Drop widgets to keep in screen and remove from screen.
Jul 23, 2011 | Samsung B5722 Cell Phone
How do you add people to call on your htc cell phone
  1. Go to a part of the Home screen where there's space to add a new widget.
  2. Tap howtoimage.aspx?id=4415 or press and hold on the Home screen. The Add to Home options menu is displayed.
  3. Tap Widget > People.
  4. Choose the widget style, and then tap Select.
  5. Select the group you want to add as a widget.
  6. Drag the widget to a blank space on a Home screen, and then release. or visit this linkhttp://www.htc.com/uk/howto.aspx?id=3350&type=1&p_id=316 thanks
Jul 01, 2011 | HTC Wildfire Cell Phone
I accidentally removed the clock/weather widget from my home screen trying to pull down my notifications bar, and now I can't find it! How do I get it back?
It's actually a pretty simple way to add widgets back to your home screen.
Long press a blank area of your home screen. A dialog box to Add to Home will appear. Select Widget, and then select Clock [HTC]. You will be able to select from 12 different HTC Clock widgets. Select the one you like, and then press the Select button. It will appear on your home screen as long as there is enough room for it. You can move the widget around by long pressing on the widget and sliding your finger to the desired location on the screen.
Good luck.
Feb 01, 2011 | HTC Hero Smartphone
How do I delete widgets off home screen if I have put them on by mistake
Just tap and hold the widget you need to remove.Then you will get a remove option below the screen ,drag the widget and put in remove.This will remove the widgt you need to remove.
Thank You
Jan 05, 2011 | HTC Wildfire Cell Phone
How do I remove and manage widgets from my home screen? Also, how do I delete the photos and music that is already on my phone?
To remove widgets from your screen, long hold the widget, and drag to the Remove button at the bottom of the screen.
To move a widget around, long hold and drag the widget to a different part of the screen. If you want to drag it to a different screen, use your track ball while long holding the widget.
To add a widget, press on the (+) button and the select HTC Widget or Android Widget.
To remove music and wallpapers (which are stored on your SD card), you first need to connect your phone to the computer via a USB cord. On your phone, go to your notifications screen (swipe down from the top of your screen). Select "Mount" and your computer will now recognize your phone as an external storage device.
The music files are in the Music directory, and the graphics are located in the Wallpapers directory.
Remember to Turn off USB Storage by going through the notification screen again.
Hope this helps and good luck.
Jan 13, 2010 | HTC Hero Smartphone
Adreno Graphics Neocore Logo
54 people viewed this question
Top Adreno Graphics Apps Experts
Are you an Adreno Graphics App Expert? Answer questions, earn points and help others
