Question about Fisher and Paykel DishDrawer DS605FDSM Stainless Steel 23 in Builtin Dishwasher
Dishwasher keep beeping F1 and F5
Dishdrawer goes to start & after about 30s beeps either F1 or F5 on both drawers. Any hints/solutions?
    New Friend:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 94 Answers
F5 is the fast and rinse LED
It simply means the lid motror current is to high during the start - The lid is jammed up or down. Or the electronic controller has failed!!
Posted on May 14, 2014
  • 126 Answers
SOURCE: my dish washer has a f1 code i put to much
f1 code indicates a leak.open bottom drawer,find the spring clips on side of tub where tub meets the front panel.push the clip and you will be able to slide the track back and remove tub. put tub on floor to left you should see a puddle,dry it up should be ok. Sensor is sensitive to moisture allow 24 hrs to reset if all visible water has been dried up. hope this helps ,please rate my solution :)
Posted on Jun 25, 2009
reg501
  • 413 Answers
SOURCE: F&P dish drawers model DD6031
It may be that the DW thinks the drawer may have been pulled open. On the right side, near the top. there are two light pipes on the drawer. One sends an infrared beam of light to a reflective area on the cabinet, the other receives this light. This is how the drawer senses whether the drawer is open or closed. Wipe these areas with a clean dry cloth.
Posted on Jun 26, 2008
vitg55
  • 78 Answers
SOURCE: Fisher Paykel F1 error / double dishwasher drawer
F1-water on bottom of dishwasher. Uselly it cost by broken drain hose. Need expert tech to fix the problem.
I’m happy to help further over the phone at https://www.6ya.com/expert/vitaliy_f406165329c75ede
Posted on Dec 01, 2008
  • 205 Answers
SOURCE: Fisher & Paykel DD601 top drawer won't start.
Most likely the micro-switch that tells the controller that the drawer is closed is broken. Its a tiny little black switch at the back of the left drawer slide, it had a metal actuator that is prone to breaking.
Posted on Jul 21, 2009
SOURCE: Fisher Paykel double drawer dishwasher DS6031
you have an overflow leak problem....shut off circuit breaker or pull fuse....let it dry out for up to 4 days; hopefully overnight; peak under dryer and feel metal drip pan and if wet you might be able to dry with a hair dryer...WHY? the lid did not seal when you put cycle on...the lid lowers and you had something..typically too bid glasses on second shelf that was above the seal lip of the tub...stack correctly after this and no worries...
Posted on Jan 05, 2010
F1 Error code
F1 is flood error. basically water has arrived at the bottom board. you can unplug the dishdrawer, remove the bottom drawer and dry the board at the bottom, maybe with a hair dryer carefully. this will reset the fault, but this is a fault that may appear again. replace the actuators that close the lid of the drawer that is leaking (look for signs of water running our of one of the drawers).
Jul 13, 2014 | Fisher and Paykel DishDrawer DS605FDSM...
How do I reset the f1 flood button . Dd603ss
Not sure if you have managed to fix the F1 problem with your dishdrawer. This is a common problem and occurs mainly due to water leaking into the base of the dishdrawer under the bottom drawer.
But if it is occuring only in one drawer then the power filter at the base of dishdrawer is faulty and needs replacement.
Otherwise make sure the mains power to dishdrawer is turned off. Pull out the bottom drawer and stack in some towels behind it if you can to remove the moisture sitting on the base. The flood switch is located there. Then take a hair dryer and run it down behind the drawer to dry things. Push drawer back and turn power back on. Now if you cannot reach the back of the drawer then you will have to pull the drawer out from its rail. Refer the installation manual for this. See link page 7.
You need to find the source of the lead, Fisher Paykel DishDrawer Installation Instructions ManualsOnline com
Jul 05, 2014 | Fisher and Paykel 24 in. DD603H W Built-in...
Dishdrawer: Does not start, just beeps once
Some sensors on the unit are telling the controller there is a fault.
Most likely the sensor checking the drawer is open or close is giving a fault. It is likely the drawer has come off the rail.
May 22, 2013 | Fisher and Paykel 23 in. DD-603SS Built-in...
F1 code
F1 is a flood sensor fault code. The problem sometimes comes from loading the machine above the top of the drawer. When the inside lid comes down before the dishwasher starts, it cannot seal completely and water can spray into the outer cavity. The water accumulates in the inner bottom where there is a sensor. The sensor protects the electronic components from getting wet by warning you of the water which you cannot see. The solution is to remove the bottom drawer and wipe out, then dry the compartment with a fan or a small space heater. Once dry, the machine will function as usual.
Jan 24, 2013 | Fisher DD603FCSS Dishwasher
Dishdrawers display F1 fault, what do I do?
The flood switch at the base of the dishwasher (under the bottom drawer) has triggered. This means water has collected at the base of the dishwasher housing. This can happen for many reasons, leaking drawer lid seal, broken drain hose, broken water inlet hose, etc.
You will need to find the source of the leak. Also incorrect detergent can cause foaming which triggers the flood switch.
Turn the mains power to dishwasher off and take the cable out of the socket. You will have to find a way to take the bottom drawer out. Usually it needs a plyer to pull out the plastic fasteners one on each side. Slowly take the front cover out and lift the drawer off the rail and bring it out.Make sure the controller or display panel do not fall out. Use masking tape to hold these in place. Leave it on the floor without tugging too much on the cable and hoses. Dry the base with towels and hair dryer. The flood switch is mounted on a circuit board located in the base.
Put everything back and conne power and try again.
Hoses need to be replaced if these are source. Also lid seal can be replaced if this is the cause.
Use recommended detergent. (no power balls) or tablets.
good luck.
Dec 15, 2012 | Fisher Paykel Fisher & Paykel DishDrawer...
Hey got a set of dishdraws and when ever we turn on it starts beeping and flashing F1
F1 Error is the Flood Switch. This Usualy mens there is a leak that has Triped the flote switch.
There are many things that could be leaking to cause this.
You should have a pro look at this machine.
Aug 11, 2010 | Fisher and Paykel DishDrawer DS605FDSM...
F1 fault shows flood switch activated, how to
Hello there
This is how i did mine
saved about 300 dollars
First thing I did was pull the front panel off the drawer, batch%2010-23-04%200031.jpg
Fisher Paykel DD602 dishdrawer with the front panel removed.
With that front panel off, I pulled the wire harness connectors off the main control board (lower right-hand side) to inspect for gookus. None found--my quest continued.
The next step to remove the botton drawer from the unit so I could inspect the flood switch. In order to do this, I had to remove the wire harness cover on the underside of the drawer. This is what the underside of the dishdrawer looks like with the botton cover panel removed:
Fisher Paykel DD602 dishdrawer, looking at the underside of one of the drawers with the wire cover plate removed.
With the bottom cover off, I could unclip the wire harness, fill hose, and drain hose. Then I unclipped the linkage at the back of the drawer and lifted the drawer off the slider arms. All this to expose the flood switch, shown on the left-hand side of the bottom panel in the picture below:.
Fisher Paykel DD602 dishdrawer with the lower drawer removed. The flood switch in mounted on the base, left hand side.
After noting the positions of the wires on the flood switch and removing them, I unclipped the switch housing from the base panel. The switch housing contains one switch for each drawer. The switches are wired normally closed (NC) and each switch has three spade connections, so it's important to note where the wires went. With the switch housing out, I could ohm out both switches and both checked good. I inspected the contacts and noticed that one of them was oxidized, evidenced by discoloration.
and clean off the contacts. That'll restore the current flow for that circuit. ." So I cleaned the contacts and reassembled the dishdrawer. I ran the top drawer and...no F1 error code! I ran it several more times just to be sure.
May 15, 2010 | Dishwashers
Our F & P dishdrawer keeps coming up with f1 and a picture of a spanner have tried turning the machine of at the switch for 24hr but is still doing it
Water has collected at the base of the dishwasher under the drawer.
This triggers a flood switch and causes the F1 error.
Turn the mains power off and extend the drawer out as much as possible. Take towels to dry the base from inside. Also use hair dryer ot dry out the flood switch mounted at the base.
Turn the power on and see if there is any difference. The cause of water collection could be many. Foam in detergent or kink in drain hose or drawer door gasket leaking etc.
May 11, 2010 | Fisher and Paykel DishDrawer DS605FDSM...
Fisher and Paykel Dishdrawer beeping constantly
leave it unpluged to stop for now, the machine has detected a leak and is constantly running hte pumps within the drawers to try to remove any water.. problrm is the water detector is in bottom under the lower drawer and htere is no pump to remove that water ..canbge a fickle machine as far as leaks are concerned, but the easy reason is usually misloading of the drawer itself, was an item put in that was too tall , preventing the lid from coming down and sealing off drawer causing water to overflow down the side??? there should be(so logn as no previous repairmen have taken it) a tech/trubleshooing guide taped to teh back wall behind the lower drawer, which is easily removed by unlocking hte hinges on either side of the front of drawer, explained in your manual
Nov 03, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher-Paykel DD603 DishDrawer shows F1 fault code. The Flood Switch has been activated. I need instructions on how to re-set the flood switch. I have two drawers that are possitioned one above the...
Fisher-Paykel DD603 DishDrawer shows F1 fault code. The Flood Switch has been activated. I need instructions on how to re-set the flood switch. I have two drawers that are possitioned one above the other and the are both giving the error of the activated flood switch. Any advice or instruction is greatly appreciated.
Jul 22, 2008 | Dishwashers
Fisher and Paykel DishDrawer DS605FDSM Stainless Steel 23 in Builtin Dishwasher Logo
403 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
